Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
French doors - when you close one side the other pops open especially when the door is closed hard
  • 220 Answers
This is normal operation,the new units are very efficient and air tight so when you close one door especially hard you are forcing air into the inside that has to escape somewhere therefor it forces the door that is stationary open just enough for the air to escape,as long as the door closes back afterward you have no problem if the door opens and swings out,then you would have a leveling problem the fridge would be leaning too far to the front.
Posted on Sep 27, 2009
The freezer door pops open when the side by side doors are closed.
I have this problem with another French Door refrigerator. We just put a stool in front of the lower drawer to prevent it from opening when the upper doors are shut.
I know this may sound kind of like a simple idea, but it works without modifying the refrigerator.
Good luck on this.
Jan 19, 2011 | LG LFX25960ST Stainless Steel French Door...
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
One door pops open when opposite side is closed
it can as the air inside is pushed by one door pushing the other. if it popsit open and stays open, level the fridge backwards.
Feb 07, 2010 | KitchenAid KBFA20ER Bottom Freezer French...
Right door opens when I close left door
This happens because the two sides are ducted together and when you close one hard enough the air is one chamber is pushed int the other and it forces the door open, All you can do is be sure the gaskets are clean and seating firmly on the frame and adjust the front slightly higher so the doors re-close.
Eric
Sep 15, 2009 | KitchenAid Architect KBFA25ERSS Stainless...
Our French Door model after almost 2 yrs pops open the one door after closing the other, and it doesn't set off the door alarm because it doesn't pop it open far enough to trigger the alarm. This causes...
We solved this problem by replacing the plastic parts on the top & bottom of the door that 'latch' the door closed.
On the top of each door is a white plastic 'cam' that latches into a receiver at the center point of the refrigerator chamber. One of mine was broken.
Additionally, on the bottom edge of each door is a white plastic hook-shaped 'stopper' that provides spring tension. I replaced both of those and now all is happy.
Got the parts from RepairClinic.com
Item #: 1266811
Description: Door hinge cam (left)
Price: $2.40
Item #: 1266810
Description: Door hinge cam (right)
Price: $2.40
Item #: 1267543
Description: Stopper,door
Price: $2.40
Aug 16, 2009 | LG LRFD25850 French Door Refrigerator
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
Freezer door opens When you close refir. door
The freezer door is relatively light weight, and when the fresh foods door closes, the air has to go somewhere and the easiest escape route is to momentarily pop the freezer door open. The door should close again quickly. If is does not, make sure the freezer door liner is not touching the top or bottom, causing dragging resistance, and make sure that the front leveling legs are raised up so the door closes by it's self when released from a 45 degree opening. Sometimes the hinge side gasket rubs and holds things up also, especially if that area was cleaned. If that is the case, rub a film of wax on the hinge side gasket to lubricate it. Additional weight in the freezer door will also help.
Oct 27, 2008 | GE Profile Arctica Stainless Steel Top...
French doors
There is a drain in the bottom of the box to allow water to run out into the pan under the unit. Sounds like it is plugged up causing air pressure to be able to build when you shut either door.
Jan 27, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
524 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
