Question about Dynex 20" TV/DVD Combo
I insert a DVD into my Dynex 20" TV DVD combo, Display says loading, I can hear the disk spinning around, and then display will say no disk
  • Dynex Master
  • 8,457 Answers
Ur DVD disk,scratches that might effect it or it dirty like fingers prints or dirts and grims to the laser surface.Clean it with some dish washing soap.
Posted on Sep 27, 2009
I have been playing DVDs without problem for several years on my RCA 20F510TD 20 in. TV/DVD Combo. Now when in the DVD mode, with a disk inserted, the screen comes up with no disk found. What can I do
NOT much you can do---It is a bad optical unit inside the DVD unit---they do not see parts----only the complete DVD portion----much cheaper to go out and buy a DVD player and connect it to the audio and video jacks this unit should have.
Mar 22, 2012 | RCA 20F510TD 20 in. TV/DVD Combo
DVD DISK STUCK IN THE TELEVISION SET.
In the front of the Tray of the DVD is a small hole using a paper clip or similar piece of straight stiff wire, insert it into the hole, push in until you hear/feel a click, keep pushing gently and the tray will pop open.
Feb 20, 2010 | Symphonic SC520FDF 20 inch TV/DVD Combo TV
Panasonic PV-20DF64 20 inch TV/DVD Combo TV can not read disc
If the disc loads up and you can hear it spin, then you get the error, more than likely the optical lens has been damaged. This will have to be repaired by a local shop if its worth the cost. if the part is available it would probably run anywhere from 130-165 to repair
Good Luck!
Ruben
Jul 23, 2009 | Panasonic PV-20DF64 20 in. TV/DVD Combo
Wont play dvd's.
If this happens when you insert a DVD disc then most likely the laser assembly is failing in the DVD drive. In most cases it will probably still play CD's. The part number needed is LSVQ0087 and isn't cheap as seen on the following ebay posting. Please take a moment to rate my answer. Thanks.
http://cgi.ebay.com/Panasonic-LSVQ0087-BLOCK_W0QQitemZ390013781267QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5acea20513
May 10, 2009 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
"No Disk" message on front display
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Dec 27, 2008 | Pioneer DV-343 DVD Player
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
DVD disk will not stay in the unit
USE DVD LENCE CLEANER, ITS AVAILABLE IN MARKET
Mar 30, 2008 | Emerson EWL20D6 Television
Cd's are ok but no dvd's...
Had similar problem. Found the disk was not rotating. Adjusted the torque on the hold down screws of the drive unit allowed the disk to spin. Still had some motor noise, but DVD would load.
Apr 09, 2007 | Toshiba SD-2800 DVD Player
Disk is "shot" out from the player still spinning fast
Maybe got damaged during shipping?? Try also to clean the lens. Theres not alot the consumer can do with a cd or dvd player as you need special equipment to work on these units as there are no user serviceable parts inside. If its a good unit maybe it would be worth a look at by a pro. Good Luck
Jun 26, 2006 | Pioneer DV-533 DVD Player
Dynex 20" TV/DVD Combo Logo
478 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
