Question about Weather King 10AJA6001AH Air Conditioner
WDG-05EAUER Replaced termal copler and heat sensor. Now unit will not work.
    Sergeant:
  • 288 Answers
I need a little help here, can you tell if the transformer is good? turn the thermostat to fan only, see if it comes on, if not may need new trans. Also, do you get pilot flame? does the pilot ignitor even try if not? What type of thermocouple did you have?
Posted on Dec 18, 2007
I have a goodman GMP10-5 REV that the blower will not shut off, i think it may be the fan limit switch, can I test it and where is it located?
the older units have the limit mounted on the heat exchanger straight in front as u look at unit. try taping on unit . newer units are on a circuit board . just for the heck of it unhook the green t-stat wire on termal bloc on unit. if the blower stops then replace t-stat.
Dec 27, 2011 | Goodman GMS90703BXA Heater
My furnace keeps shutting off after a minute i changed the thermo copler,i also changed the blower and still having the same problem,i turn the furnace on and the burners and everything seem to work okay...
Is it possible that the flame sensor has to be cleaned or replaced. I would try removing it first and then use steel wool or some sandpaper and clean it off. I have seen them get all blackened and discoloured and then they don't conduct heat the way they should so the sensor stops the flow of gas. Give that a try.
Jan 19, 2018 | Honeywell Heating & Cooling
How to repair a thermal coupler on a 1994 gas water heater
Time to get a new tank. The life expectancy is between 10-15 years. You are probably spending more in natural gas to heat than the tank is worth.
Jul 10, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
The pilot light on my caloric gas oven lights, but the oven burner doesn't light. The oven is old, but only used for 2 months before being put in storage for 13 years. The stove top burners work fine,...
there is a thermo copler ( temp sensor ) that tels the gas sensor "pilot is on give me gas" the copler needs to be cleaned or replased
Nov 26, 2009 | Ovens
My electric fireplace model # HEF33WDG, the heat works, but the flames dont move. Can someone help me.
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
Oct 21, 2009 | Leisure HOMEPRIDE Electric Fireplace...
The pilet will not stay lit,when you release button
check for eco switches two wires coming from gas valve at thermocuple hook up this is a flame out saftey
Feb 26, 2009 | Reddy Heater RLP100 Portable Forced Air...
Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 28, 2008 | Ovens
Kenmore Dryer - Ignitor will not fire
thanks for the question The problem is with a thermal fuse located at the back remove back panel the thermal fuse is located on the air vent 2 small wires go to it replace it . And check the venting make sure the vent is clean because this termal fuse will break down because of poor venting Thanks for the question The appliance doc
May 12, 2008 | Kenmore 63942 Dryer
Wont heat or dry
hi have you tried thermostat i repaired on last week same fault
Dec 20, 2007 | Zanussi 24 in. DE6850 Free-standing...
Weather King 10AJA6001AH Air Conditioner Logo
50 people viewed this question
Top Weather King Heating & Cooling Experts
John Tripp
John Tripp
acrman404a
Level 1 Expert
Bill Long
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
