Question about Flip Video MinoHD 4 GB Camcorder
When I try to record, I am told that my Flip camcorder is full. When i try to view the videos existing on the camcorder, I am told the camcorder is empty! I can't record, and I can't view any videos.
Try this.
Connect to your PC.
Go to MY COMPUTER.
Right click on the Flip Video Drive
Select PROPERTIES from the pop up menu.
Press the DISK CLEANUP button
When the Disk Cleanup window appears press OK
Posted on Jan 03, 2010
Flip video instruction manual
Had the same problem. After trying everything, this worked:
From a command prompt, list directories. You might see one called ".Trashes\501" -- this is the directory where I found all the videos hiding that we tried every trick in the book to delete. If you see video files in this directory, simply delete them using the command prompt. Then exit the command line interface and check your camera. You should have a full 60 minutes of recording time restored.
Hope this works for you!
May 01, 2014 | Video Cameras
When I press the power button on my ultra hd 2nd generation camcorder, the screen lights up with the flip logo and verbage that says hold the record button for setup. It also makes the correct sound for...
Will the camcorder let you go ahead and complete "SETUP"?? if so, go ahead and redo the setup maybe some glich and maybe doing setup again may get the camera going again? hope so!! I have one also and knock on wood, no problems so far. it may be worth a try:
when camcorder turns on: when Flip Video Logo comes up press and hold RECORD button, to enter setup mode use the + and - to adjust current setting and the left and right arrows to select other settings
good luck!
Apr 25, 2011 | Pure Digital Flip Video Ultra Camcorder
After removing the movies from my flip video camcorder it says camcorder empty, but the time left says 00:00. If I try to record it says camcorder full.
Your videos may still be in the Recycle Bin/Trash. Try plugging the device back in to your computer, then check the Recycle Bin to see if the movies are there. If they are, delete them from the Recycle Bin (or empty the bin completely) and they will be permanently removed from the device.
Mar 02, 2011 | Pure Digital Flip Video Camcorder
When we try to record video it says camcorder full and when we view videos it says camcorder empty
try reseting the camera by holding the button for 30 seconds or whatever since there are no videos on there you dont have to worry about the reseting process deleting any videos
Jan 03, 2011 | Flip Video Flip UltraHD 8GB High...
Lost record time due to corrupted video files
I have the same problem....someone please post solution!
I've tried systematically deleting each of the database type files on the Flip (while keeping a saved copy on my computer hard drive). This doesn't seem to help. I've just got one minute of video it will allow me to shoot!!!!!
Jun 21, 2009 | Pure Digital Flip Video Ultra Camcorder
To regain record time we are told to re-format the flip video ult
I had the same problem so I tried the thing on the website and it didn't work so I looked it up on Youtube and someone figured out how to do it. I tried it and I got all 60 minutes back. You should try this, it probably works.
PS instead of 5 nines it's 6 nines.
Feb 03, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip video problem
I have had this exact problem. The Flip Camera read "empty" however if I tried to record something by pressing the red button, the camera read "full." I started having this problem and kept on seeing fewer and fewer minutes available to record. Today, I was trying to shoot and then uploaded three videos. I could use the camera no more. So, I did as you suggested...plug the camera in to my Mac and then emptied the trashcan. It WORKED!! I got all sixt minutes back.
Jun 02, 2008 | Pure Digital Flip Video Camcorder
Flip camera problem
ok Have same problem, literally just fixed in less than 5 mins ago, figued I would come back on this fourm I was searching on for a solution and post my soultion,,, Simple solution!!
Plug in flip to PC
go to my computer
right click on Flip
click Format
Click quick format
Solution!! My 60 mins was restored!!!!!
Hope it helps some one!!
Apr 05, 2008 | Pure Digital Flip Video Ultra Camcorder
Lost time/inaccessible files on flip
This may sound risky, but I did this and my Camera is working perfectly again... If you don't have any videos on it you need to salvage too badly this should do the trick.
1) Plug it in (obviously)
2) Go to My Computer and right click your video camera
3) Click Format
4) I clicked restore device defaults because it sounded safe (but may not be necessary)
5) Click start and begin the reformatting
After this i went from my incorrect 27:11 min. remaining on the camera to the full 60. Still records perfectly and the software is still on it and works correctly. Hope it helps some of you out there =)
Mar 09, 2008 | Pure Digital Flip Video Ultra Camcorder
Flip Video MinoHD 4 GB Camcorder Logo
135 people viewed this question
Top Flip Video Video Cameras Experts
matt
matt
Are you a Flip Video Video Camera Expert? Answer questions, earn points and help others
