Question about AmcorAire UCHW-H12AF2 Split System Air Conditioner
E4 message no cool air. Heat is fine, fan and
The piping is freezing but still no cool air.
  • 358 Answers
If the fan inside works , the unit is probably low in refrigerant , or the filter is clogh with dirt.
Posted on Sep 27, 2009
Pipe to my concept 1000 air conditioner was frozen and no cool air was distributing, fan to outside unit is running and I removed frost off pipes what else do I need to check?
It has to completely thaw first. If indoor fan is running and the filter is clean it is freezing up because of a lack of refrigerant .
Jun 10, 2017 | Heating & Cooling
I have a carrier ac moddal 38HKC48DS3002 4 ton that will run for about 10 mintes before off the coppreser and than displing show E4
If unit displays "e4"
1? Check whether the winding resistance and
operation current of the compressor are normal.
2?Check whether the high and low pressure is normal
when the unit is running.
3?Check (whether the coil pipe sensor is normal)
whether the contact of the inserter on the circuit
board is well, the coil pipe temperature sensor is
fixed, the evaporation of the indoor unit is well,
the key is to check the evaporator temperature
detected by the coil pipe temperature sensor has
reached the cooling or heating temperature.
4?Check whether the surface of the condenser is too
dirty, it should be cleaned when it is too dirty.
5?Check whether the capacitance of the outdoor motor
and the fan is damaged, it should be replaced when
it is damaged.
6?If the above items are normal, the electric control
board should be replaced.
Air Condition Fort lauderdale
Apr 12, 2015 | Carrier Heating & Cooling
Error code e4 on daikin split system ducted air conditioner - what does it mean?
This is stating that there has been a low pressure error on the system.
This could have been caused by a blockage in the pipe work or a possible shortage of refrigerant. It could also be due to a fault with the low pressure sensor/switch.
Jan 31, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
What is a E4 code mean
Error Code:
E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System
will shut down.
E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling
operation will be locked out. Fan operation can continue to operate.
E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
Pump operation will be locked out. Air Conditioner, Fan and Furnace operation
E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation
will be locked out. Furnace, heat strip, heat pump and fan mode of operation can
continue to operate but displays the last temperature set-poi
Dec 18, 2012 | Dometic 3313192.000 White Single Zone LCD...
AIR IS NOT WORKING. hAVE SYSTEM SET AT 72 AND STILL SHOWS 85 DEGRESS IN HOUSE. PIPES AT THE TOP OF UNIT SEEMED TO BE FROZE
There are two things that make a central air conditioner freeze up, they are poor air flow, that means check your air filter, and your system is low on refrigerant, and that will take a serviceman to fill on refrigerant. For the time being set your thermostat cool/heat switch to off, and turn your fan switch to on. This will thaw out your cooling unit, and when the ice is gone you can switch the heat/cool switch to cool to resume cooling until you have figured out which problem you have.
Jun 24, 2009 | Heating & Cooling
E4 error message. a/c option will not work.
i have carrier ac and it showing E.4 it is not cooling at all please help to solve the problem
Jun 10, 2009 | GE APH10AA Air Conditioner
Small pipe running from outside unit freezing up
SOUNDS LIKE THE FAN SPEED MAY BE TO LOW SO AS THE AIR GOES THROUGH THE COIL IT WILL START TO FREEZE HAVE SOMEONE CHECK THE FAN SPEED MAKE SURE IT IS ON HIGH ALSO MAKE SURE IF THAT IS THE ONLY FILTER ON THE SYSTEM
May 03, 2009 | Heating & Cooling
My 2004 v6 lincoln ls air conditioner freezes up the climat control works just fine with the ac turned off when you are in auto with the ac on it freezes you out and after a while the air flow stops you...
One of 2 problems,either the system is low on freon or most likely the problem is a bad evap temp sensor. This vehicle does not use a cycling switch to cycle compressor on and off like a conventional system does but instead measures the temp at the evaporator core itself.
Mar 20, 2009 | 2004 Lincoln LS
Unit Won't Cool Or Heat Just Blows Air and Displays FP
fp means freeze protection when gets too cold out unit comes on by itself so pipes dont freeze
Jan 17, 2009 | Amana PTC093B50AJ Electric Heat Air...
WRAC has E4 on display
E4 means return air sensor error, if the error cannot reset may be the return air sensor is out of range or defective. But if the sensor is ok you need to replace the control board itself. The reading of return air sensor is 8k to 10k ohms @ 25deg. C temperature.
Jan 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
AmcorAire  UCHW-H12AF2 Split System Air Conditioner Logo
327 people viewed this question
Top Amcor Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
