Question about Xerox WorkCentre M20i All-In-One Laser Printer
PAPER JAM 2 CHECK INSIDE - Xerox WorkCentre M20i All-In-One Laser Printer
  • Gilbert Gonzalez May 11, 2010
    Can you provide some more details?
    Paper feed but stops in tray, or
    paper goes half way almost to fuser, or
    paper fed out to exit transport?
    Thank you, we can have idea what is going on with the copier.
Throw the printer.
Posted on Feb 20, 2014
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 29 Answers
I can only guess withou the code...open right door and look in fuser area for fan-paper or partial piece..... look in exit area for partial paper??
Posted on Oct 19, 2009
  • discount copiers inc
    discount copiers inc Dec 16, 2014
    make sure your guide setting are correct. clean the feed tires with a soft cloth and 99% alcohol. does it jame the same thru bypass? is the paper clean and undamaged and the proper size and weight?
  • 220 Answers
SOURCE: PAPER JAM 2,CHECK INSIDE(SCX-4521F)
paper jam 2 is your fuser sensor error,need fuser replaced.
Posted on Jul 02, 2009
SOURCE: Paper Jam Error 2
Samsuing SCX 4200
would not give up [Paper jam 2 - Check Inside] alarm
no jam, nothing broken, turning off etc. no help
Finally put a sheet in halfway through the manual feed slot
- had door open doing it so I could make sure sheet went far enough so that the little two-pronged black flag right at front of the paper feed opening was kept pushed down by the sheet.
Then used Copy to copy the sheet - this got rid of the false alarm. Prints ok again.
Posted on Feb 22, 2008
SOURCE: Its saying paper jam and its no paper in the
check front and rear paper sensors. Maybe they damaged. Clean optical sensors.
Posted on Sep 30, 2009
SOURCE: Paper jam 2 on Samsug ML-3051N
There is a door around the very back of the printer, if your printer is slightly encased in as mine is you can't see it. That is where the Paper jam 2 is
Posted on Jan 05, 2010
rickead1
  • 1998 Answers
SOURCE: HOW DO I CLEAR A
its right here in your manual http://www.office.xerox.com/userdoc/PE16I/PE16_Web/pdfs/UserGuide_en.pdf
on page 8.5
1 Open and close the front cover. The jammed paper
automatically exits the machine.
If the paper does not exit, continue to Step 2.
2 Pull the paper tray open.
3Remove the jammed paper by gently pulling it straight out
If there is any resistance and the paper does not move
when you pull or if you cannot see the paper in this area,
skip to the fuser area around the toner cartridge. See
page 8.7.
4 Insert the paper tray into the machine until it snaps into
place.
5 Open and close the front cover to resume printing.
if you have any further questions please message me back and please remember to rank how this opinion has helped when our chat is concluded thanks again Rick
Posted on Jan 05, 2011
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
I face a paper jam a lot, what is the right steps to release it? I keep getting a paper jam message. I have opened up the case and inspected; removed the cartridge and inspected; no paper/paper jam found....
Turn printer upside down (yes), and check that there is no small paper or foreign objects inside the printer, ensure all door are closed, unplug printer power cable for 2 minutes to reset.
Jul 29, 2008 | Konica Minolta PagePro 1350W Laser Printer
Paper jam 2, check inside
You should troubleshoot jamming error message by removing toner cartrige, check if the little plastic sensors on the paper path are not stuck somehow, reinsert toner,close door, open back door check if the fuser sensor is ok ( and not broken), clean the papertray roller, restart printer and it should work. If that doesnt fix your problem it can be a faulty sensor or some tiny paper left somewhere you can't see and sensor detects .. Hope it helps.
Apr 07, 2014 | Samsung SCX 4521F All-In-One Laser Printer
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Display reads paper jam 2 check inside
Open the Top Half of the Copier. The Scanner Section pops open by pushing up.
Underneath the Scanner Section is the Fuser Unit. Check in the Fuser Section, you will find paper Jam in the Fuser Section.
Apr 27, 2010 | Samsung CLX-6210FX Laser Printer
Says jam 2 check inside but there is no paper inside
make sure all paper is removed from paper cassettes. check all doors covers it is telling you to check. check fuser. you may have a swithc broken, bad or knocked out of position.
Oct 19, 2009 | Savin Office Equipment & Supplies
Paper jam-2
samsung scx-4521f paperjam2 check inside
Mar 22, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper Jam
1-fan the papers many times befor you put in the machine.
2-keep the paper inside its cover in dry place.
3-check for any foreign object droped in paper path(pins-a small pieces of torn paper).
4-check for good condition of paper detecting switches in paper path inside the machine.
Jun 19, 2008 | Canon FAX-L350 Plain Paper Laser
Problem
Paper jams can be real or false. The all-in-one may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same.
To fix the paper Jam errors please try the following steps:
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
Regards
Malik Khan
Jan 26, 2008 | Canon PIXMA MP160 All-In-One Printer
Xerox WorkCentre M20i All-In-One Laser Printer Logo
1,820 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
