Question about Garden
Honda whippersnipper have new honda whippersnipper and no instructions on how to take head off put new line on, Need help thx
88 Honda prelude SI wont start?
U need to re-timed the engine. Check all four marks going across the two cam pully is lined up with the engine head surface.
Then check the crank pully alignment mark the single notche align to the mark on the timing cover
Apr 05, 2015 | 1988 Honda Prelude
Coolant leaking around new installed head gasket on a 83 honda gl1100 motorcycle. How do I fix it? Is starting it without coolant a good option?
You might have installed the head gasket wrong (Upside down or backward) or put the left head on the right side, You need to pull that head again and check that all the water holes line up with the gasket between the block and head, Also you should only use oil on the head bolts, the moly will allow the bolts to back off over time.
Apr 07, 2014 | 1983 Honda GL 1100 Innerstate Gold Wing
I have a stihl hs 45 hedge trimmer, It starts but wont run, idles on choke than as soon as i swap it to run it stalls, i start on run it fires and than stalls. I have changed the spark plug and dioframes...
Hi, re -check the fuel pickup line. To do this you need to stretch it at the ribbed section as they are renouned for perishing in this area between the ribs, especially if it is a black line. The new type is green. Hope this helps, regards Phil.
Aug 08, 2011 | Garden
What is the correct way to put a new head gasket on a d15b7 engine honda block?
By using a repair manual. Removing and replacing a
head gasket can be done but you need the step by step
instructions, which are numerous. Also try and buy
the parts from Honda. May come in a kit form.
Feb 07, 2011 | 1994 Honda Civic
Black lines across the page
hi there,
unplug cartridges and check its heads are clear if not take a tissue paper and cleane it very gantelly, intall the cartridges and run cleanning test from printer properties.
Jul 11, 2010 | Lexmark X2600 InkJet Printer
OVER REVVING HONDA YARDMAN, NEED EXPLODED VIEW OR INFO IDLE ADJUST ACCESS. new fuel, clean plug, air cleaner off, plug chop black. indicating excess fuel. any solutions out there, thx, duncan
it sounds like the govenor control isn't woring or the throttle on the carburetor is stuck. there is an idle adjustment screw on the top of the carb to adjust the idle.hondas are usually a black plastic philips head.
Apr 30, 2010 | Garden
How do i put on a head gasket for a 1995 honda
something like this, definitely calls for a trip down to the auto parts store to buy a shop manual. they've got step by step instructions with pictures and specifications. worth every penny
Feb 07, 2010 | 1995 Honda Accord
My 97 ford taurus 3.0l ohv had a cracked head, so
Flush your whole system you probably have an air lock in your cooling system.
Feb 07, 2010 | Ford Taurus Cars & Trucks
Need Help Installing U-Turn Trimmer Head on Echo SRM-210
It is ridiculous, there are a bunch of bolts, and then a multi-fit brochure showing a grid of nonsense.
There are instructions on the inside of the package, however that is how to string the line.
Sep 19, 2009 | Echo Rapid Loader, Trimmer Head
Garden Logo
399 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
