Question about Panasonic PT-47WX49 47" Rear Projection Television
Tv went black
Change convergence chips today. took care in doing it right (I thought) turned the tv back on. It worked great for about ten minutes. the blue and green seperated and a couple of minutes later the tv went black and the power lights will just blink.
  • SD Tech
    SD Tech May 11, 2010
    Does the power light blink 3 times and pause?
  • 647 Answers
Did you check or change any of the resistors - Check in the area near the STK IC's for burnt resistors.
Posted on Sep 27, 2009
Convergence problem Panasonic PT-53TW53G
First I know this set well, did you pull out the board or the light box to replace the chips?
Convergence problems are usually easy to see...
see attached photos and tell me as much as possible.
SD TECH
Nov 10, 2011 | Panasonic PT-53TW53 53" Rear Projection...
Hitachi ultrasound hd
voltages to IC's There's a shielded module near convergence IC's It could be bad too. Check voltages to It.. I had simular problem /replaced IC's did not fix..Replaced module & did convergence.. TV was fine so try this 1st k
Jan 29, 2008 | Hitachi 43FDX01B TV
Sony KP-57WV700 Convergence Repair Failed - TV won't stay on
Sorry ur convergence ICS are shorted and dead.Because u put in solders and take out solders to many times.The heat of ur soldering iron,and the electrostatics will kill the ICS,if keep putting heat in the ICS legs alots times.Buy the convergence kit again,replaced every componnents in that kit to ur tv.Because,the kit been research and put together.What the most common componnents that burn and dead in the convergence circuits.
May 04, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
D52W19 about 4yrs old. Recently after being on a short while, the screen will go erratic or black and then the tv will shut off. I can not get it to turn back on until about ten minutes. I removed the...
depending on what type of erratic video it is before shutdown it can be either the Small signal board or the Deflection board are what usually cause those type symptoms. You can get replacement parts from www.tvrepairworld.com
Mar 28, 2010 | RCA D52W19 52" Rear Projection Television
Hey guys I have a pretty interesting one for you. I researched all the convergence issues a few months ago, and new I needed to buy new IC's. I bought the C5AA00000203's from Partstore.com, which were...
Bad IC is my guess...
On anotehr note convergence is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Dec 04, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Convergence Issues...
Yes the Ics are easially replaced if you can solder. You will need two STK392-560 Convergence ICs and possibly the 12 4.7 ohm 1/2 watt resistors as Sony sets will usually weaken the 4.7 ohm. You can get the replacement ICs ad resistors at the following link and they provide free instalation instructions with picture as well as free online tech support in case you need additional help. Here is the link.
http://servicemanuals.vstore.ca/
Jul 13, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
TV wouldn't stay converged them went black
There are also fuses that goes with amps and return resistors to that need replacing. To be precise you need live chat!
Oct 04, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Update and a few questions (Convergence Problems - VS-55601 55 in Projection)
yes, they go bad interment because they have a large current go thru them and they generate heat, they are mounted on a heat sink with white silicone to help disapate heat. replace both not just one, try MCM Electronics get heat sink compound also
Oct 06, 2006 | Mitsubishi VS-55601 55" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
