Question about Cfm 802 Ecofan Table
The metal strip on the bottom, can it be replaced?
I have a Ecofan and the metal strip on the bottom, can it be replaced? The fan isn't turning and the strip is bent.
  • 39 Answers
There are no replacement parts for this fan available, however I managed to get mine spinning like new after it had died. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Posted on Nov 01, 2009
Compound plus a new motor. Home hardware for 15,99 . Work like new
Posted on Feb 24, 2014
Ecofan not working
The problem is most likely a bad TEG module or possibly a bad fan motor. The most common problem is a failed TEG module. Caframo will not sell replacement TEG modules as they require you to return the fan to them for rebuild but the repair is quite easy. You can find the exact replacement on eBay or directly through Thermal Enterprises. They even have a troubleshooting and repair guide for the fan.
Feb 24, 2014 | Cfm 802 Ecofan Table
How do i fix my Ecofan ?
Does the motor have bearings or bushings? If bearings, they likely need replaced. If bushings, clean with alcohol then lubricate with 3-in-1 oil.
Jan 24, 2014 | Dryers
When I go to SEAL, it burns a small hole clear thru the bag. One little metal peice on the sealing strip has burned right thru the white heating strip, therefore, it isn't sealing completely.
You need new tape to replace the one presently covering the heat element. You can get a roll of it for just US$7.99. Look at the FixYa question "where [or how maybe] can I get a new tape." I think that you have to be sure that the heat element is flat. I bought a used unit with that problem and the element had somehow gotten bent. Ordered the tape this morning and the cost is worth the hopeful fix.
Jul 30, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
What is the power system for ecofans - these are the fans / motors which run on electricity generated by temperature differentials in two different and adjacent metals. I would likt to build my own if...
The power source is a thermoelectric module (TEG). Failure of this module is the most frequent cause for fan problems. You can get replacement modules for these fans on eBay.
Mar 13, 2010 | Cfm 802 Ecofan Table
Our Eco fan does not turn. It fell on the wood stove once and bent the fram a bit , then it started working, now it doesn't at all. What is up?
It sounds like something is binding on it. Anything of this type (referred to as a heat engine or external combustion engine) need very low resistance. There may be a bent shaft or a small ding that is rubbing on one of the rotating parts. Good luck.
Jan 02, 2010 | Cfm 802 Ecofan Table
Fan just stopped turning, even if the fire is going good, what could be wrong?
Bushings dried out at rotating shaft. Clean and Lubricate with a high temp. dry film lubricant.
Dec 07, 2009 | Cfm 802 Ecofan Table
Refrigerator door gasket pulls down and brakes off on top corner
Look it over and see how it is held in place. A stripped screw or bent clamp depending on what holds it in place is the most likely suspect.
A stripped screw get a slightly bigger one or shrink the hole with tooth pics or match stick.
Bent metal strip remove and straighten possibly bending a little more in the opposite direction. And sometime 1 metal strip may be put on upside down or turned around backwards and not holding. look for similarity in the way these type of bracket/strips attach.
If this helps please rate me as high as possible.Thank you for using fixya.
Apr 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ecofan.going.slow
The most likely problem is either mechanical binding (lack of lubrication) or a bad thermoelectric module. You can get replacement modules for these fans on eBay.
Feb 02, 2009 | Cfm 802 Ecofan Table
My ecofan quit working. Blades rotate rough
Sounds like a bad thermoelectric module. This module is what generates the power to run the fan. You can get replacement modules for these fans on eBay.
Dec 14, 2008 | Cfm 802 Ecofan Table
Ecofan only turns slowly
These fans can be rebuilt! Like many others, our fan died after being placed in the center of the stove top. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Nov 28, 2007 | Cfm 802 Ecofan Table
Cfm 802 Ecofan Table Logo
1,073 people viewed this question
Top Cfm Dryers Experts
Pranavendra Pranav
Pranavendra Pranav
Level 1 Expert
 Russ Hill
Russ Hill
Are you a Cfm Dryer Expert? Answer questions, earn points and help others
