Question about Sanyo DS35510 35" TV
Went dead after power outage all other components ok
Went dead after power outage all other components hooked up still work.
  • 135 Answers
Hi there!
Power surges are common after the electricity is re-established. The reason some and not all are damaged is because the closest point or the weakest supply is normally taken out first. A job for a repair technician if your are not familiar with the inside of a TV. May just be a fuse if you are lucky. If the led comes on in standby only it is normally more serious. Good Luck,JUS004
Posted on Mar 05, 2008
Beocenter 9300 dead. Fuse OK
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jan 22, 2016 | Audio Players & Recorders
After a power outage my denon 2803 receiver will not turn on.
Hello. First unplug and replug in your receivers. When you push the power button, you should hear 1 click. Within 5 seconds, you should hear a second click. Can you please tell me the results?
Thank you.
Sep 15, 2012 | Denon AVR-2803 Receiver
Computer wont turn back on after power outage
Power surges are like Radiation poisoning: the effects are cumulative. You need to have it on a Surge Protector (not just a power strip with an over-amp cutout,) that is AT LEAST 1200 Joules. Much higher if you live in a lighting-prone area, or are subject to frequent power-outages. Your Power Supply Unit appears to be on the edge of failing. I suggest you get it replaced IMMEDIATELY. A PSU with issues such as yours have been known to damage one or more of the other components inside your PC when it finally the Hard drive, or a Memory module...even the CPU.
Aug 22, 2012 | Systemax Computers & Internet
I have a Sharp model LC-42sb45u that will not turn on since power outage.
Voltages sometime increase/decrease during power outages. This mainly afftects the power supply of a lot of electronics equipment.
1. Check the fuse.
2. Check primary components like; Bridge rectifier, filter cap, switching components etc.
3. Check secondary (cold) side once you isolate the primary side to be ok.
Please consult a professional technician if you are not skilled in electronics repairing.
All the best
Sep 20, 2011 | Sharp Televison & Video
I misplaced my instructions for my timer and need to re-set it after a power outage. Can you please send me the instructions? Thanks.
Question posted under Intermatic ST01C, but Timer is not 100% identified since ST01C is battery powered, and should not lose programming or stop working with ordinary power outage.
Most digital timers have a battery or capacitor back-up for power outage.
Add a comment with description of timer buttons, or open link below to see most brands of in-wall timer.
Open following link for to identify Intermatic ST01C and Ei600 and download instructions:
ST01C timer has a battery backup. Power outage will NOT cause battery-powered display to fail, but power outage and power surge can cause any electronic timer to fail.
So either the battery went dead, or power surge ruined timer, or you don't have ST01C timer.
If ST01c display is not showing, then replace battery and then reprogram current time -or- manually re-set timer and then reprogram timer.
Sep 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Hello, my HP Pavilion desktop PC m9177c went dead after a power outage. Right before the outage, it was on and connected to a surge protector. After the outage, it is completely dead as if there is no...
You may have to change its power supply however, try this first
1. change your UPS coz the old one may have been damaged.
if that still didn't work, change your power supply
Nov 28, 2010 | HP Pavilion a710n (PJ508AA) PC Desktop
Panasonic cordless phone no dial tone changed batteries -no help other functions work--menu light doesn't lite when phone rings
electricity went out for 10 hrs
decided to switch phones around----not phone problem
phone ok in all phone outlets in wall
it was plugged into fax machine--maybe electric power outage hurt fax phone connection for phone line
fax works fine, just can't work as did before with phone line into fax
will call brother #775 monday
all was plugged into power surge
maybe have to adjust something on fax or buy new one because of power outage????????????????
Nov 22, 2009 | Panasonic Lands Phones
My Wii remotes wont turn on.
try syncing them, it helps. or replace the batteries.
Jun 22, 2009 | Nintendo Wii Console
These recievers were infamous for the power transformers going bad(opening) if more than 2 speakers were hooked up and it was cranked up.Did it die while playing?Do you have 4 or more speakers hooked up?Was there a power surge?Let me know........
Jul 23, 2008 | Denon Audio Players & Recorders
Dead mother board
The problem with power surges, or low power (brownouts) causing excessive current draw can cause multiple problems to motherboards. Even if you were to pinpoint and repair one problem that appeared to fix the fault, several other components on the board may have been weakened, and prone to fail.
If you are certain that the power supply is 100% ok, then replace the MB.
The best power protection is to use a UPS.
Jan 05, 2008 | Intel Motherboard
Sanyo DS35510 35" TV Logo
192 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
