Question about Refrigerators
It is shocking me - when looking at the box with wires attahced to it under the refrigerator, the green wire is not attahced to anything. Is the ground wire and where do i reattach it?
  • 220 Answers
One attaches to the frame,anywhere the wire will reach a screw,and one usually attaches to the compressor near the relay usually left side where all the wires attach,if there is a hole in on of the legs next to the rubber mounts attach it there,if you attach it next to the realy(there are holes there) don't use a screw that is long enough to puncture the relay or the cover.
Posted on Sep 27, 2009
Hanging green wire inside refrigerator is not connected to anything
the green wire is a ground wire and only needs to be in contact with a metal surface, more likely than not there should be a silver colored clip on the end and this clip should fasten on the outside edge of the panel you removed to access the coils if not then just just secure it to some other metal surface behind the panel .if you can't ,don't worry about it more likely than not it'll come in contact with the back of the panel when you put it back in place.
Dec 04, 2013 | Refrigerators
I have volvo s40 2000, the alarm doesn't start when the car shocked, where i can found the shock sensor???
the shock sensor is mounted under the dash and is sometimes part of alarm box or separate unit, look for module under the dash and trace wires, it separate box it is often tie wrapped of a set screw, box it 1x1 to 2x2 box usually 3 wires, often attached to steering column or metal strut
Jun 09, 2012 | 2000 Volvo S40
I changed my air ride system to shocks and springs on my 1993 lincoln mark 8 now my air ride system wont stop beeping
take out ur glove box and there is a green wire u have to cut to make ur car stop reading air ride off. be carefull u cut the right wire
Dec 15, 2010 | 1993 Lincoln Mark VIII
I found this fridge. When I turned it around, from the power cord comes a green, white, and a black wire. The white is not conected to anything. When you plug the unit nothing happens. Where the white wire...
The three wires are your Power (blk), Neutral (white) and Ground (grn) The three wires should be connected to a plug. The black and white wires to the flat spade terminals, and the green to the round prong. Hope this helps
Jul 23, 2010 | Haier HSB03 Compact Refrigerator
Two slots on back of dimmer. one has single black the other has black AND ground (green) wire. Is this correct???
Yes, this is a single pole dimmer switch. Connect the green wire to the ground wire in your electrical switch box and connect one black wire to the power (common wire) in the switch box and the other to the wire going to the incandesant light fixture. (Standard dimmers cannot be used with CFL type bulbs).
You should be working fine! Remember to turn off the power to the wiring your connecting this dimmer to to prevent both getting a shock and from damaging the dimmer during installation.
Hope you found this very helpful and best regards!
Aug 07, 2009 | Leviton Decora Light Dimmer Switch
Wiring schematic for plymouth grand voyager 1995
Is there green corosion on the tip of the wire ? Chances are the answer is yes. You will have to detach the fuse panel/box and run a new wire and connector to the fuse panel. Splice into the wire you can see, but make sur you cut enough of the wire off to get rid of the corrosion.Hope this helps.
Jul 30, 2009 | 1995 Plymouth Voyager
Will not operate until wire is moved
If you mean a small gray plastic box under the right side rim, that is your lid switch and it will need to be replaced.
Post your model number and I can assist your further if you need it.
Mar 25, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
If my car is blowing air but it isn't cold what's wrong?
Either the compressor is not coming on or your low on refrigerant. To check under the hood on the suction line (line that gets cold and sweats) by the fire wall usually on the passenger side you'll see a metal cylinder. On there is a lead with two wires coming from it remove this and jump it with a small wire or paper clip or bread tie anything metal this will not shock you. With the motor and a/c on if your compressor clicks in than your low on refrigerant, if it doesn't your compressor is bad.
Sep 29, 2008 | Heating & Cooling
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
