Question about Kitchen Ranges
Transformer burning in power board ( model # plef398cca )
I checked an electric range Model # PLEF398CCA ( FRIGIDAIRE )
Found power board's transformer burned out, I check range could not find any other problem. After installing a new board, It burned out again within two minutes. I recheck most basic components again I could not find any other problem. What am I missing? can you help me?
Thanks Jose Cano from Florida.
My E-Mail address is: advanceappliance@bellsouth.net
catriver
  • 878 Answers
SOURCE: Oven Control not working
Vahid, is the display black, nothing there? Try pressing the bake and broil pads together for 3 seconds until display shows SF. Then press clock. If this doesn't work try the ERC test by doing this; Kill the power to the range for 10 seconds. Press the cooking time, delay start and number 8 pads all together. The display should show the word test. Give this a shot first....Catriver..post back.
Posted on Nov 12, 2006
jsrock516
  • 5911 Answers
SOURCE: Range goes into lock out mode
I have experienced this with a Maytag model before. What I was told by the technical assistance folks, is that fluctuations in power coming from the line voltage being fed into the home, electrical storms, or even ham radio (high power RF) operating in the area, can cause some electronics to appear to have problems when they don't. The theory is that these circuit boards are so sensitive that even the slightest noise or interference on the line voltage coming in can cause the board to go into a lock out mode. I was able to clear the problem I had by resetting the computer. There is an actual procedure for this if you haven't figured that out already. If you haven't figured out how to reset the unit, you may need to call the technical support department for your model to see if they can provide you with better answers. I hope this sheds some light on this problem for you.
Posted on Jul 09, 2007
  • 126 Answers
SOURCE: Problem codes for self-cleaning ranges
e2 f3 oven to hot
e1 f5 check door / latch switch
if its working now dont worry
Posted on Dec 10, 2007
  • 979 Answers
SOURCE: apex GT2715 TV, burned resistor
Wire wound 190 ohm 10 watt should do the trick if that's all that's wrong with the set...accordianman
Posted on Mar 21, 2008
SOURCE: GO VIDEO DVD + VCR model: DV 1130 I want only the basic connection
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Posted on Aug 10, 2008
HOW DO I GET RID OF F11 ERROR ON FRIGIDAIRE ELECTRIC RANGE MODEL ES305
Hey Kenneth, I understand that you are receiving an "F11" error message on your Frigidaire Electric Range. Before considering contacting a service provider, I would recommend resetting the range by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the appliance to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
Oct 12, 2015 | Frigidaire 30" Self-Cleaning Freestanding...
Bought a replacement control board for frididaire oven but it doesn't hook up with power strip but it looks like I can jump it but how
Hello friend, thank you for your post!
From my understanding you have a replacement control board for your Frigidaire range and the power strip doesn't hook up properly so you would like to jump it over. I would not recommend doing so because you would be unsure what kind of electrical miscommunication that could cause. The part you have ordered maybe incorrect. If you can provide me with your model number I can double check your parts manual. You can locate your model number on the door frame of the lower drawer. I look forward to assisting you. -Matt
Feb 18, 2015 | Frigidaire Kitchen Ranges
I own FRIGIDAIRE ES100/105 (electric stove and oven). Yesterday I was using the oven and suddenly I heard a loud sound. I went to check it I found out the both the oven and stove were off. And not working....
HI. The actual issue will be with the main logic board, which is where the main element control relays are mounted. These very important relays are damaged. The main board will need to be replaced, asap.
With that said, if you could be so kind; Please post the entire model number so that i may pull up all necessary part numbers needed, as well as, service manual links and diagrams to help with your repair.
Dec 02, 2011 | Frigidaire PLEF398AC Electric Kitchen...
My Frigidaire Classic Range, Model # FEF366CCB popped and now it doesn't work, at all...as if there is no power to it, but it IS still plugged in??!!! Is there a way I could check the FUSE and replace it...
check to see if the unit has 240 volts going to the unit if it does take the back off after removing the power look for a black or burnt spot at the wire connection and on the control board repair or replace that wire or component
Apr 05, 2010 | Frigidaire FEF366BC Electric Kitchen Range
Frigidaire Model ES200 White Electric Range f1
F-1 USUALLY MEENS THE MAIN PCB OR CLOCK ***. I WOULD RECOMEND REMOVING THE POWER AND PULLING IT AWAY FROM THE WALL .TAKE THE BACK PANNEL OFF AND LOOK FOR A BURN MARK. THAT SHOULD SHOW WHAT BLEW.
GOOD LUCK!
ERIC
Mar 05, 2010 | Electrolux Kitchen Ranges
Where can I get a HV transformer for Microwave?
I went on-line and found a site that gave answers to similar problems. I found that no power to the the control board usually meant a transformer issue. I checked the leads on the transformer (with a meeter) and found that it was shot. Now I need a replacement transformer, at a reasonable price, or else I will purchase a new Microwave.
Kenmore model 665.68682891
Mar 30, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Instructions for frigidaire oven
Thanks for the question. remove the back panel. first cut the power to the stove .remove the clips that hold the board, install new one. install the wiring on the new one. thanks the appliance doc.
Sep 27, 2008 | Frigidaire FEF366 Electric Kitchen Range
My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Nov 10, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
275 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
