In control panel - printers. The default printer says ERROR under it and a test page will not print.
  • 58 Answers
Delete the pending document:-
Goto run command type services.msc that will opena services window, look for print spooler. RIght click print spooler and click stop, right click again and click start. Turn off your printer unplug the USB and power cable replug it. Try printing. If the issue still persist follow the steps mentioned in the below link to clean the print driver and that will surly resolve the issue.
http://members.shaw.ca/bsanders/CleanPrinterDrivers.htm
Posted on Sep 27, 2009
How to install destop printer in ubantu
1. Just hook up your printer to your linux machine and reboot your system
2. your system will automatically detect and installs your printer.
3. If not, then goto control panel .. find printers settings from there and manually add the printer. You may have to select your exact printer model while adding your printer manually to the linux machine.
I hope this is helpful to you.
Thanks
Mar 14, 2010 | Epson Stylus C86 InkJet Printer
NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Jul 05, 2008 | HP Photosmart C6280 Printer
My kodak printer is not printing my word documents
HAVe you tried to print on other application?
try to do some print test page using you computer. If your using windows XP you can print a test page under control panel and printer and faxes, Just click the icon of your printer then properties. If the test page printed the test page it means computer is fined
Just check the settings of word document. make sure your printer is selected as default printer
Nov 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Will not print
Make sure you select the printer has the default printer under the Printers and Faxes option on control panel.
Simply right click your printer and select the option "Set as the default printer"
To make sure it is solved, go to the printer properties under the right-click menu and hit "Print test page"
Good luck
Jun 21, 2009 | Canon BJC 80 InkJet Printer
HP 4180 SERIES STOP PRINTING
Is it set to "default printer?" Right-click the printer icon and set it to default. Also, right click the printer icon and go to properties, then click "print test page" to test your printer.
Apr 14, 2009 | Computers & Internet
My x5470 won't print and error message says
Hi
Please do the following:
1) open the printer
2)remove the cartridge.
The problem is in scheme from printer that touches the cartridge from behind. You must clean this scheme from ink with a soft cloth dipped in spirit/kleannex.
Use the klennex/spirit and clean off those contact on the holder and printer will work again.
Then before you print anything, you should run cartridge alignment from control panel- printers and faxes-> right click on default printer-> properties-> printing prefrences(general tab) and also print a test page. Align the catridge and then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex/spirit on those holder contact panel
Please ask for further assistance and Do rate the solution as "FixYa" if you found it useful.
Thanks
Rylee
Mar 17, 2009 | Lexmark X5470 All-In-One InkJet Printer
I've put ink into the printer and printed the test page it works, but it wont print off anything else apart from the test page
Your printer is not set as default printer, open up the printers folder--- Start -> control panel -> printers and faxes -> right click your printer and select set as default. if you have more than one printer in there, but you only own one printer, find the correct one and right click and delete the other ones.
Oct 19, 2008 | Office Equipment & Supplies
Samsung CLP-315
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Sep 16, 2008 | Samsung CLP 300 Laser Printer
Printer will not print
And.....
How about telling is what the make and model of the printer, what operating system you have, any error messages that pop up etc etc etc
Sep 16, 2008 | Office Equipment & Supplies
51 people viewed this question
jasbo
jasbo
