Question about Refrigerators
No instructions to put together kingsgate oak vanity base kv4821-D
  • tonymj44 Sep 27, 2009
    osage brand out of kansas city,mo. bathroom vanity ,kv4821-d 48 inch.
    President:
  • 1,462 Answers
Can you give me more detial about this product so we can provide furthur assistance..
Please leave the product details and the instruction you need with this preodut in detail, do we can help you furthur in assistance
Please leave it as comment
RNJ VINODKUMAR
Posted on Sep 27, 2009
I have two heritage live oaks. The larger one is surrounded by tree seedling about 5 ft. Around the base. My grass can't grow there. How do I prevent and remove these?
Hello, Carolyn -
The lack of grass growing around your Heritage Live Oak trees is most likely due to the shade from the trees themselves.
Source of information:
https://www.southernstates.com/commercial-agriculture/news/acorns-and-oak-leaves.aspx
As for the oak seedlings, see the question and answer here from the National Gardening Association:
https://garden.org/frogs/view/62405/
Best wishes.
May 25, 2018 | Garden
How do you remove right hand drawer from foremost vanity?
Release the drawer glides by lifting tabs on either side.
May 12, 2014 | Senza Fresca Potenza Gray Oak Modern...
Need instructions in how to put oak breadboard breadbox together
Go to a wood working magazine, THIS OLD HOUSE; THE HANDYMAN, etc are 2 examples where they have step by step instructions
Jan 24, 2014 | Baby Gear
Old granite headstone is loose from base just gravity holding it together .
I take it it's a headstone and base made from the same material and has it been removed and put back? If so the headstone sometimes works loose from the base, the only way is to repoint using neat cement, no sand in the mix you can mix some into a wet slurry and pour in the joint and point the rest with wet mix use a little washing up sponge and clean water to clear up when done, it won't fall over there is 3-4" dowels inside. Don't wobble it after you have repointed it to check else it will break loose, leave it and check it the next day!
Oct 31, 2013 | Stone Clearance: Black Granite Vanity ...
Assembly instructions for dw7350 mobile base
You are correct...the base is not pre-assembled as stated in the instructions. However it is a very easy task. The four base parts slot together in a fairly obvious way. The bolts to use are actually packaged separately and marked as "Bolts for Base". There are four bolts in total. One bolt goes in each corner of the base assembly. I put my bolts through from the bottom with the nuts and lockwashers on top. I did this to minimize the ground clearance although now that it is assembled it probably wasn't necessary. Once the four base pieces are together you can follow the instructions as printed. BTW, when bolting the four upright channels to the base, two of them use the same bolts as the ones holding one end of the "U"-shaped wheel supports. The instructions didn't mention this. It is also fairly obvious. In the end, no problems putting this extremely sturdy stand together. I'm glad I bought this to go along with my planer!
Feb 26, 2013 | Dewalt DW7350 Portable Planer Stand
Putting the base together
When i put my Fieldcrest Armoire together the base connected fairly easily to the other 3 pieces. Are you sure that you followed the instructions very carefully and haven't mistakenly mixed up some of the wooden pieces? I would re-read the instruction manual very carefully again and if you are sure you've followed the correct steps, you can contact the place where you bought it as maybe they gave you a wrong piece. Good luck.
Sep 29, 2012 | Foremost Fieldcrest Armoire - Espresso
I just installed this royal oak hunter fan model number 23668 last weekend. It worked great until yesterday when it would not come on. I checked power to the fan and it was there. I took it back a part to...
yes there is a diod in the fan its like a fuse but smaller if you open the modules in the fan you may see a diod burnt or dicolered this does happen alot these control differnt parts of the fan light fan itself, good luck
Aug 06, 2011 | Hunter Fan The Royal Oak 23688 Ceiling Fan
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
