Question about Brother HL-2040 Laser Printer
I have a paper jam and I do not know how to undo it. I tried pulling the paper out,but that is not working. Please help
HOW DO I RELEASE THE JAMMED PAPER PAPER JAM E
destroy the paper that is jamming it then it should work again.
May 27, 2014 | Epson Aculaser C1100 Printer
Paper jam - I can see the jam, but don't know how to remove the paper.
Hello
Open the top cover of the printer.
If you can see the jammed paper, take one or more sheets of paper and pull them toward you.
While pulling the paper, press the RESUME button to turn the paper feed rollers.
If the paper needs to be fed in the opposite direction, release the RESUME button and then press it again.
If the paper is still jammed, turn the printer off or remove the power cord from the printer. Then turn the printer back on or plug the power cord in.
The printer will run through a reset cycle, which may clear the paper jam.
If the paper is still jammed or if several (8 to 10) sheets are jammed, take hold of a sheet in the middle of the stack using both hands.
With firm, even pressure, pull the sheet toward you.
Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
Make sure no scraps of paper are left in the printer.
Close the top cover of the printer.
Try printing again.
Apr 16, 2011 | HP PSC 750 All-In-One InkJet Printer
How do I undo paper jam
you can't undo paper jam , but you can fix it, please open the printer and remove the paper, this depends on the Epson model
Mar 30, 2010 | Epson Office Equipment & Supplies
Paper jammed. Tore as I tried to open door and pull it out.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 07, 2010 | HP Photosmart C3180 All-In-One InkJet...
How do I pull out jammed paper?
Hello there
Mar 01, 2010 | Canon PIXMA MX300 All-in-One Printer
Printer has paper jam error. there is no paper jam. clear the jam reload the paper it pulls the paper in and jams again.
Hello there
Jan 12, 2010 | HP J4680 Office Jet All-In-One Printer
HL-2035 Paper jam top sheet has gone half-way through - can't move it from front (over paper tray). Can't access it from back.
I am forwarding you a link from the brother solution center which gives the detailed information on how to clear paper jams:
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000000/000026/faq000026_016.html?reg=eu&c=eu_ot&lang=en&prod=hl2035_eu
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Sep 17, 2009 | Brother Office Equipment & Supplies
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
Paper jam
open the front and rear access door and try to pull the paper gently you can also unplug and replug your print so it would spit out the paper.
May 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Brother HL-2040 Laser Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
