Question about Brother MFC-5440CN All-In-One InkJet Printer
LCD shows figure "7" no matter what button I press
Suddenly, no matter what button on my MC-5440CN I press, I get the figure 7 appearing on the LCD and nothing else happens.
I can operate all functions (print, fax, scan and copy) from my computer, but the manual options (including Start, Finish, Power Save - everything) only give me a "7"
I have tried disconnecting, rebooting etc but the machine will only work from the PC, not from the control panel.
Any ideas??
  • 286 Answers
Your control panel has gone bad, or you have a stuck key.
Make sure all your keys move freely. If theyp're good, call your local service centre and get the price for a key keyboard assy. They're not expensive and are fairly easy to replace.
Posted on Dec 30, 2007
I have placed a detailed description in Details below.
You will need to use two columns to prevent a same number from showing up twice each time you need a new number just drag the two columns down.
just fill in the second a value with wherever that column ends with a $before the number. or leave as is and it will just continue to check. also use the decrease decimal button to make sure you have a full 6 digit number each cell.
If your really worried about making sure the number is not a repeat a logical test could go in third column.
if you get a yes just drag the two columns down one more
Hope this helps.
This needs more explanation and snap shot of the cells in question and more about what you want.
doesnt matter the size of the number you want a chosen number how is this number chosen??
to appear somewhere else??
Nov 15, 2016 | Cars & Trucks
What causes a dirty background?
1) - Power ON printer while holding both the + & - buttons until "OKIUSER" message appears in LCD.
2) - Press + or - button until "ENGINE DIAG MODE" is displayed.
3) Press "ENTER", displayed will be "DIAGNOSTIC MODE XX.XX.XX S-MODE"
4) Press + or - button until "NV-RAM INITIAL" is displayed.
Half way, dont stop too long it will time out....
5) Press "ENTER" again.
6) Will appear "TABLE 1" message.
7) Press "ENTER" until "EXECUTING RESET" message appear. ...............the "NV-RAM INITIAL" message will BLINK.
Tada....This procedure reset TONER, DRUM, FUSER and counts
8) power OFF printer, wait 10 sec, and power ON again..
To access Service Mode in C9300 power ON printer with 0, 1, 6, 7 at same can do some good damage in there!! (I warned ya!)
Resetting consumables for OKI C7300,C7500,C9300 printer I think!
1. Hold buttons 0 + 1 + 6 + 7 on startup.
2. Press button 0 several times until "DIAGNOSTIC MODE xx.xx.xx" shows.
3. Hold buttons 2 + 3 until "ENGINE DIAG LEVEL 4" shows.
4. Press button 1 to scroll to "COUNTER SET".
5. Press button 2 to scroll through menu items (button 6 scrolls backwards)
6. To alter the value of an item, first press button 3 to select the digit to be altered. The selected digit will slowly flash. (Button 3 moves to the right through the digits. Button 7 takes you to the left.)
7. Then press button 2 to increase the value of the selected digit. Press button 6 to decrease the value.
8. When the changes have been made hold buttons 1 + 3 + 5. The screen will flash three times and then an * will appear on the right of the screen. The new value is set.
9. To leave the counter set menus, turn the printer off.
Each colour toner counter shows life as percentage used. So a toner showing 30% has used up 30% of its toner. 100% would indicate a near empty toner. This is the reverse of the toner life shown from the "usage menu" when the printer is in normal operation, which shows the toners as a percentage life remaining. You will want toner showing 00%. note:this is oposite of what you see in user mode
Some models exhange these steps
3) HOLD 0 + 4 "ENGINE DIAG LEVEL 2" shows
4) Press 1 to cycle to "fuser unit"
5) 2 to scroll to TONER
Jun 10, 2014 | OKI C9600hdn Laser Printer
Can not print ,shows in lcd "unable to print 4F"
Hi there you'll need to reset the printer.
Try this solution:
1.) Unplug your printer.
2.) Plug your printer press the MENU + MONO + ARROW UP. (Press it rapidly one press at a time)
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
email me if I helped you. .
Sep 07, 2013 | Brother DCP-J125 All-in-One Inkjet Printer...
How do you set the clock
This is on page 23 of the manual for your device... This is the web link...
If the unit is on, press the STANDBY/ON switch to turn it standby
2 Press and hold the TIME SET button for more than 3 seconds and release it when "12H" or "24H" appears on the display. "12" or "24" blinks. If you want to change the hour mode, press the .or/ button.
< If you leave the unit idle for 7 seconds, the time setting mode will be cancelled.
3 Press the TIME SET button once more. The "hour" value blinks.
4 Press the SKIP button (.//) to set the current hour.
5 Press the TIME SET button. The "minute" value blinks.
6 Press the SKIP button (.//) to set the current minute.
7 Press the TIME SET button. The clock starts.
Mar 12, 2011 | Teac MC-DX32i Shelf System
How do I set the time on a sports air warch
Q. How to set my watch A. The A and M button are located on the back of the watch LCD screen. When looking at the watch right side up the A button is the one on top and the M button is located below the A button.
1. Press A button twice, the month figure appears, press M to adjust the month.
2. Press A button once, the date figure appears, press M to adjust the date.
3. Press A button once, the hour figure appears, press M to adjust the hour.
4. Press A button once, the minute figure appears, press M to adjust the minutes.
5. Press A button twice to finalize the settings!
sports air watch
Dec 13, 2010 | Watches
Error code C2557
Error code c2557 means "ATDC Sensor abnormality".
It appears due to following reasons,
1-Imaging unit (Drum unit) parts life is expired,
2-Developer's life is expired,.
3-Developer tank is hard, gears of the unit are not moving
For best results and smooth functioning of machine, simply call your technical services representative and he will help you in this matter.
if you want to do it yourself, you have to do this.
1-Press "UTILITY/COUNTER' button on the machine's panel.
2-Now press "check details" button. (appeared on the lcd screen)
3-Now press these buttons,
4-now press "Tech representative choice" button on LCD screen.
5-now press "PRINTER" button.
6-press "ATDC GAIN"
7-Now press the "c" button to clear the value, after clearing the value enter new value by using numeric pad.
Enter new value by adding 10 to the previous value. For example if the previous value was 150 you have to enter 160 now or 165.
8-Enter the new value and press the End button on the LCD screen and exit.
9-Now restart the machine..
Nov 04, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
No instructions need to know how to operate
The Nikon MC-EU1 Remote Cord is an accessory available for the Nikon COOLPIX 880/885/990/995 4300/4500/5000/5400/5700/8700 cameras. The MC-EU1 Remote Cord is 80 cm long and allows the camera to be fired remotely like a cable release for a film-based camera.
The MC-EU1 Remote Cord's main function is to prevent camera shake. As well as the shutter release function, the MC-EU1 has the following functions.
1. operate the camera's zoom remotely,
2. advance or return images in the playback mode,
3. Controlling interval photography, automatically fire the cameras over a given interval.
Note this is the only Nikon remote cord available NIKON COOLPIX cameras and is only compatible with the cameras listed.
The Nikon MC-EU1 remote cord has two Interval modes, A and B
In Interval Mode A: the first photograph is taken at the start; and subsequent photographs taken at the specified time intervals, thereafter.
In Interval Mode B: the first photograph is not taken until the specified time interval has passed and subsequent photographs taken at the specified time intervals.
These modes can be selected by pressing the MODE button. The device cycles through settings in the order, Remote Mode, Interval Mode A, and Interval Mode B. When the Remote Mode is selected, the LCD panel displays Remote; when Interval Mode A is selected, Interval appears together with the letter A and Interval Mode B is indicated by Interval and the letter B.
The interval Modes, allow you to take photographs one after the other at a selected interval, which can be set in increments of one second to any value from two minutes to twenty-four hours. Interval modes are only available when the camera is in recording mode and cannot be used when the camera is in playback mode.
Setting the Interval
1. Setting the camera to recording mode and the remote cord to Interval Mode A or B, the interval setting will be shown in the remote cord LCD display. Items currently selected for editing will flash. Each time the selection (SEL.) button is pressed, the item selected will change as shown below.
Select the desired time by altering the settings (second [S], minute [M], or hour [H]) one at a time. While the item is flashing, press the down button to decrease the time set, or the up button to increase the time set. The value displayed will change by one each time either button is pressed.
2. After adjusting settings, press the selection button until the display is no longer flashing.
Starting Interval Mode Photography
• Half-pressing the remote shutter-release button has the same effect as half-pressing the shutter-release button on the camera, readying the camera to take a photograph. If the interval is set to less than two minutes when the shutter-release button is half-pressed, the interval display will flash. Choose an interval of two minutes or more.
• Full-pressing the remote shutter-release button has the same effect as full-pressing the shutter-release button on the camera, starting interval mode photography.
• When the camera enters interval mode, it will either take a picture and then begin the count to the next photograph (Interval Mode A), or begin the count to the first photograph (Interval Mode B). The Interval indicator in the LCD display will flash while interval mode is in effect.
Ending Interval Mode Photography
• Half-pressing the remote cord shutter-release button while an interval mode is in progress stops the interval photography.
• Photography will also stop should you run out of available space on the compact flash card; In this case, the number of exposures remaining displayed in the LCD panel will be 000.
The MC-EU1 has a feature that when the zoom button is pressed twice in rapid succesion, the camera will start zooming until this function is cancelled by pushing the button a third time. If this function is not cancelled, no other function is possible with the MC-EU1. If the MC-EU1 does not respond as expected please ensure you have not activated the zoom function.
Jan 02, 2010 | Nikon MC-EU1 LCD Remote Control
Error message one brother mfc-5440cn
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number
is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the
annoying cannot clean message.
Oct 28, 2009 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
44 people viewed this question
James Cagle
James Cagle
Jim Keysor
