Question about Sharp AL 1631 Copier
Flashing p and paper will not feed it jams
Sharp AL- 1631 flashing p and paper will not feed it jams
  • Sharp Master
  • 1,297 Answers
Clean the paper feed roller under paper tray use izopropilic alcool.
Posted on Sep 27, 2009
Why does it indicate a paper jam when there isn't any?
Normally paper jams dont' prevent the machine from turning on you have a serious problem have tech come out you might need to have the firmware re-flashed or a board replaced.
Apr 16, 2015 | Sharp AL-1631 Digital Laser Copier
I have a Sharp AL-1631 Copier. The 'P' Light comes on indicating a paper jam, however when I open the machine there is no paper jammed. Any suggestions?
Check the dash and see if the lower tray is selected or the by-pass tray on the side. If the side tray is selected change to the bottom tray.
May 13, 2011 | Sharp AL 1631 Copier
Sharp AL-1631 bottom paper feed will not pick up paper.
A few things could be the problem.
  1. The paper in tray could be damaged
  2. The drawer separator pawls (metal taps on the right side of tray where paper touches)
  3. Paper backstop not in or in wrong spot (green plastic piece at back of paper)
  4. Feed tires are worn or dirty
Does the copier try and feed from tray 2? If it tries but the paper doesn't leave the try look and see if there is a dark mark on the page (top middle towards the right). If so then most likely the feed tire is worn.
Oct 12, 2009 | Sharp AL 1631 Copier
Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
May 19, 2009 | Sharp AL 1631 Copier
MISFED INDICATOR LIGHT FLASHING
There is no code to run.
Did the paper come out as an entire sheet? Or was it torn? There is either a small piece of paper that remains in the machine, or you dislodged a paper switch in removing the jam.
Apr 23, 2009 | Sharp AL 1631 Copier
IN MX-M350N SHOWS "REMOVE PAPER FROM TOP TRAY" AND DOESN'T PRINT
You probably have a paper jam in the auto feed unit. Open the auto feed and check for bunched up paper and if you don't find any open the side doors and check for paper jams there. Let me know what you find.
Feb 13, 2009 | Sharp AL 1631 Copier
Paper Jam light on, but no paper jam
A piece of paper torn from copy paper is caught around registration switch, exit switch or feedshift switch.
so check theme.
Jan 18, 2009 | Sharp AL 1631 Copier
Top paper feed jams
if your feeder is jamming you need the roller & pad replaced and usaaly the internal feed roller cleaned this is a repair that should be done by a sharp tech about a $150
Jun 30, 2008 | Sharp AL 1631 Copier
SHARP AL-841 Paper Misfeed Error? The little paper mis-feed symbol is flashing - though there does not seem to be a jam ANYWHERE. The copier will not re-set.  Can someone help? Thanks, Ron...
open right door and look on top there should be a littl lever there check carefully to see if there is a paper crumbled inside.
remove tray and look where paper feeds out.
Nov 19, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
286 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
