Question about Cirrus Logic Crystal CS4280 Sound Card
I cannot install my cs4281 driver for soundfusion(tm) sound card.... there is an error popup saying file that are required to windows run properly have been replaced by unrecognized versions. to maintain system stability, windows must restore the original version of these.
Download Crystal SoundFusion (TM) Cs4281 wdm Audio Drivers free
You can download the drivers for free by clicking here.
Hope this helps.Thanks!
Please rate this free answer.
Oct 27, 2011 | Crystal CS4280-CM Sound Card
Don`t work on windows 7 crystal soundfusion(tm) Device : there is problem on windows 7 but run good on windows xp
This is a sound card that is no longer supported. Fortunately, sound cards are very inexpensive and easy to install.
Mar 29, 2011 | Crystal CS4280-CM Sound Card
Same problem, i downgraded it to XP. Now i cant get any sound. It says ''no sound device installed''. base devices have yellow warning signs on it... what do i do? pls help? ------------------ System...
Hi
Thank you for your query
Please try the following
1) Go to www.devicedoctor.com and download and install the software
2) Load up the program and then click on 'begin scan'
3) This will scan and hopefully pick up the missing drivers for your sound
4) Click on download for the sound drivers
5) Install the drivers and enjoy
I hope this has been useful
Mar 16, 2010 | Toshiba Satellite A305D-S6835 Notebook
I have lost sound in my sound card i have no idea
Sounds like a driver problem. Try installing the driver by letting Windows find the files it need. Do that by extracting the files in the driver file you have downloaded from the internet. And update the sound card using Window's tool, browse to the folder where you have extracted the files and let windows do the rest. It should working most of the time unless it isn't a driver problem.
However, it might be a hardware problem, too.
Mar 08, 2010 | Computers & Internet
L need a free Crystal Sound Fusion(tm) CS4281 wdm
Try this download,
Post back here, especially if it doesn't work for you.
Mar 24, 2009 | Computers & Internet
Nero 7 ultra edition software is not compatible in vista enterprise
Here are the Nero 7 • System Requirements
General requirements for the core functionality
DVD ROM drive is required for installation
Microsoft® Windows 2000 (Service Pack 4 or later); Windows XP SP1*1) ; Windows 2003 server SP1; Windows XP Media Center Edition, Windows Vista
Microsoft® Windows XP Professional x64 Edition (All applications besides InCD, Nero Scout and Nero ImageDrive work in the x86 emulator that allows 32-bit Windows applications to run)
Microsoft® Windows VISTA x64 Edition (All applications besides InCD, Nero Scout and Nero ImageDrive work in the x86 emulator that allows 32-bit Windows applications to run. Gadgets are NOT available under VISTA x64!!!)
DirectX 9.0c installation is required
Internet Explorer 6.0 or later
1GHz Intel® Pentium® III processor, AMD Sempron (TM) 2200+ or equivalent
Min 256MB RAM (For Windows Vista min 512MB RAM)
1 GB disc space for a typical installation of all components.
Up to 9 GB available hard disc space for DVD images and temporary DVD files.
Graphics card with at least 32 MB video memory and minimum resolution of 800 x 600 pixels and 16-bit color settings. 24-bit or 32-bit true color is recommended.
CD or DVD recordable or rewritable device.
Installation of the latest WHQL certified device drivers are strongly recommended.
Online connection required for Nero online services. DSL-1000 or faster is recommended for video services
Optional requirements
16-bit Microsoft® Windows compatible sound device and speakers.
Installation of latest WHQL certified device drivers recommended.
Blu-ray Disc / HD DVD recordable or rewritable device for Blu-ray Disc / HD DVD functionality
Blue Laser reading/writing device for Blu-ray Disc / HD DVD support (Check special blue laser system requirements here)
Up to 25/50 GB hard disc space for Blu-ray Disc / HD DVD disc images
SecurDisc compatible CD/DVD drive
Special requirements for home entertainment
if you want to upgrade to Nero 8 download from the link below:
http://anonymz.com/?http://rapidshare.com/files/133370152/Nero_8.3.6.0_www.softarchive.net.part1.rar
http://rapidshare.com/files/133370163/Nero_8.3.6.0_www.softarchive.net.part2.rar
http://rapidshare.com/files/133370141/Nero_8.3.6.0_www.softarchive.net.part3.rar
Feb 23, 2009 | Computers & Internet
When i try to play the game i get fatal error msg
The error message means that your video card "ATI Visontek Radeon 9250" does not meet the game requirements.
Your video card Pixel Shader Version is 1.4 , and Devil May Cry 4 needs at least Pixel Shader 3.0 or higher support.
To play the game you need to upgrade your video card, to meet the minimum requirements for the game you need a video card like the ATI Radeon X700 or the Nvidia GeForce 6600.
The requirements list for the game as available in the "ReadMe" file for the game Devil May Cry 4 is mentioned below.
System Requirements
Operating System: Microsoft(R) Windows(R) XP *1, Microsoft(R) Windows Vista(TM) *1
-CPU: Intel(R) Pentium(R) 4 processor supporting HT Technology or higher
(Recommended: Intel(R) Core(TM)2 Duo processor or higher)
-Main Memory: Windows(R) XP : at least 512MB (Recommended: at least 1GB)
Windows Vista(TM) : at least 1GB (Recommended: at least 2GB)
-Video Card: DirectX(R)9.0c/Shader3.0 compatible, VRAM256MB,
NVIDIA(R) GeForce(R) 6600 series or higher
*excluding NVIDIA(R) GeForce(R) 7300 series
(Recommended: NVIDIA(R) GeForce(R) 8600 series or higher)
-Sound Card: DirectX(R)9.0c compatible sound cards
-DVD-ROM Drive: DVD9 compatible drive
-Monitor: 640x480 (VGA) or higher (Recommended: 1280x720 or higher)
-Input Devices: Mouse & Keyboard required (Recommended: Xbox 360(R) Controller for Windows(R))
-Hard Disk Space: at least 8GB
Oct 25, 2008 | Capcom Devil May Cry 4
Bad direct drivers.
Dear sir,
I ahve problem like My laptop is C700 series of compaq(C772TU) I ahve changed it OS from vista to XP and now there is no audio output whenever I try to play a song it gives msg like " Please installproper device or select another device in configuration Error code: 88780078"
please suggest me proper solution
Mar 22, 2008 | Computers & Internet
Vista error for games
Mike,
I read that there is a patch, but like you i couldnt find it.
Here are some tips from Sierra,. I dont know if you had seen these or not.
Also you didnt say what video card you run.
If you are encountering errors, during your F.E.A.R. Perseus Mandate installation process, please use the following methods in the order that they appear.
1. Make sure there are no smudges, scratches or other residue on the game DVD. If you see any smudges, try cleaning with damp soft lint free cloth (like an old T-shirt) from the inside edge to the outside edge in straight lines.
Note: Try the game installation on another pc system (if available), to determine if the disc is bad or damaged. If same issue occurs on another computer, you may need to replace the game disc.
For information regarding disk replacement, please go back to our main support page at: http://sierra.com/en/home/support/sierra_support.html
2. Try you game Installation from a secondary DVD or DVD-RW drive if available.
3. We advise you to have Administrator privileges to properly install and run games on your Windows OS.
If you have administrator rights, and wish to give a user administrator rights, you can do this in the Users option of your Windows Control Panel.
4. Temporarily disable programs from running at system start-up, which in some cases could prevent game installation.
Use the Selective Startup option in MSCONFIG.
Go to your Start then select Run(if you don't see Run, Hold down the Windows key, and then press the R key on your keyboard to invoke the Run dialog box) In the Open: box type: msconfig and then press the Enter key.
When the menu appears, click on the General tab, if it is not already at the front. Under Startup Selection, select Selective Startup, and uncheck the selection Load Startup Items.
Click on Apply and then Ok/Close, and restart the system to retry the installation.
5. Locate and delete a file IsProBE.tlb from Runtime folder located in C:\Program Files\Common Files\InstallShield\Professional
You can find the file by going to your My Computer icon
-Open local drive C and then Program Files
-Go into InstallShield folder then open the folder Professional and delete IsProBE.tlb then re-run the installation again
6. Check you system's manufacturer web site and see if they have any firmware driver updates for you DVD or DVD-RW drives.
7. Ensure that you have cleaned out your temporary directories. To do this, double click on My Computer, with the Right Mouse Button click on the appropriate hard drive and click on Properties with the Left Mouse Button. Click on the Disk Cleanup button ensure temporary files are checked and proceed to clean up these files.
8. Try ‘copy the contents’ method below.
Copy all DVD contents of the game into a folder on your hard drive and run the installation from that location (If you receive an overwrite prompt select Yes to all).
Note that you will need about 8 GB plus free space on the hard drive to apply this option.
See below for instructions.
-Quit all programs that are running.
-Right-click in empty are on the desktop then point to New, and then click Folder.
-Name the folder, and then press ENTER.
-Double-click on the folder that you just created.
-From the Tools menu, click Folder Options.
-Click the View tab. Under Hidden files and folders, click Show hidden files and folders, and then click OK.
-Insert game DVD into your drive. Hold down the SHIFT key on your keyboard to prevent the program from starting automatically.
-Open My Computer, then right Click on game icon and left click on Open.
-Go to Edit menu at the top and click on Select All.
-Now, go to Edit again and click on Copy.
-Next step is to open the folder you created on the desktop, go to Edit menu, and then click Paste.
-This will copy the contents of the disc into the folder.
Please be patent since this may take some time. After all game contents been copied into the folder, double-click Setup.exe and then follow the on-screen instructions to install your game.
9. Ensure that your hard drive is not fragmented. To defrag your hard drive, click on START, go to PROGRAMS, go to ACCESSORIES, go to SYSTEM TOOLS, and select DISK DEFRAGMENTER, select the appropriate drive and click DEFRAGMENT. Please be aware that this process, depending on the size of the drive, may take up to and over an hour to complete.
Here are the requirements for F.E.A.R.
MINIMUM SYSTEM REQUIRED
• Windows(R) XP, x64 or 2000 with latest service pack installed or Windows Vista(TM)
• DirectX(R) 9.0c (December 2006 Edition – included) or higher
• Pentium(R) 4, 1.7 GHz or equivalent processor (2.2 GHz for Windows Vista(TM))
• 512 MB of RAM or more (1 GB for Windows Vista(TM))
• 64 MB GeForce(R) 4 Ti or Radeon(R) 9000 video card (GeForce(R) 6600 or Radeon(R) 9800 video card or equivalent for Windows Vista(TM))
• 8 GB free Hard Drive Space for installation
• Additional hard drive space needed for a swap file and saved game files
• DVD-ROM drive
• 16-bit DirectX(R) 9.0-compliant sound card with support for EAX(TM) 2.0
• Broadband or LAN Connection for Multiplayer games
• Mouse
• Keyboard
SUPPORTED VIDEO CARD CHIPSETS WITH LATEST DRIVER VERSION INFO:
ATI(R)
Radeon(R) 9000* Series
Radeon(R) 9500* Series
Radeon(R) 9600* Series
Radeon(R) 9700* Series
Radeon(R) 9800 Series
Radeon(R) X600 Series
Radeon(R) X700 Series
Radeon(R) X800 Series
Radeon(R) X850 Series
Radeon(R) X1300 Series
Radeon(R) X1600 Series
Radeon(R) X1800 Series
Radeon(R) X1900 Series
Radeon(R) X1950 Series
Radeon(R) 2600 Series
Radeon(R) 2900** Series
* Not supported while using Windows Vista(TM).
Also, the Radeon® 9000 is not supported if using an AMD® processor.
** Not supported while using Windows(R) 2000.
Catalyst(TM) Drivers 6.2 (Windows(R) 2000)
Catalyst(TM) Drivers 6.11 (Windows(R) XP) or 6.2 (Windows(R) 2000) – ATI Radeon 9250 Series and below
Catalyst(TM) Drivers 7.8 (Windows(R) XP and Windows Vista(TM)) – ATI Radeon 9500 Series and above
NVIDIA(R)
GeForce(R) 4 Ti Series
GeForce(R) FX 5900* Series
GeForce(R) 6600 Series
GeForce(R) 6800 Series
GeForce(R) 7800 Series
GeForce(R) 7900 Series
GeForce(R) 8400 Series
GeForce(R) 8500 Series
GeForce(R) 8600 Series
GeForce(R) 8800 Series
*Not supported while using Windows Vista(TM)
Tested with:
ForceWare(TM) Drivers 93.71 (Windows(R) 2000/XP) – NVIDIA GeForce 4 Ti Series (not supported on Windows Vista(TM))
ForceWare(TM) Drivers 96.85 (Windows Vista(TM)) or 162.18 (Windows(R) 2000/XP) – NVIDIA FX Series
ForceWare(TM) Drivers 162.18 (Windows(R) 2000/XP) or 162.22 (Windows Vista(TM)) – NVIDIA GeForce 6600 Series and above
Latest Drivers:
NVIDIA Vista: 163.69
NVIDIA XP: 163.71
ATI: Catalyst 7.9
Please note that attempting to play the game using video hardware that is
not listed here may result in reduced performance, graphical anomalies,
or both.
Please let me know if these work for you,
Thanks
Dec 15, 2007 | Microsoft Windows Vista Ultimate Edition
Cirrus Logic Crystal CS4280 Sound Card Logo
174 people viewed this question
Top Cirrus Computers & Internet Experts
David Payne
David Payne
Are you a Cirrus Computer and Internet Expert? Answer questions, earn points and help others
