Question about Naxa Electronics NX-671 Car CD/ MP3 Player
Wont turn on I have good power sources and grounds but stereo wont turn on or eject CD clock is working
  • 54 Answers
Hit the source button that might work
Posted on Sep 27, 2009
Wire diagram vw caddy van for stereo
As you have power to the eject and cd, it would seem to be a problem with the Power switch on the head unit.
Jul 14, 2013 | Vehicle Parts & Accessories
Ford 500 stereo no volume and put in cd and says no cd clock works
sounds like internal problem with stereo....may need to replace ??
Aug 18, 2012 | Ford Cars & Trucks
Intrigue stereo shows clock and gets power but doesn't light up and play CD or radio
There can be up to three separate power lines to the radio - ignition, dash light and auxiliary (always on). Check the ignition power wire for good connection and possible blown fuse.
Jan 03, 2018 | 2000 Oldsmobile Intrigue
I got a new stereo, granted for free from my girlfriends father, now i connected all the wires properly (I think) but the problem is that the only function i get from the stereo is the clock, and only the...
Interesting enough! One thing that I can say is when what you described happens, its usually when the player is not actually powered on. Meaning, I can load and unload cds from my player when the car is turned off and it will show me the clock and all that you described. That is because I still have power going to it when the car is not on. Therefore, the only thing that would be missing is the power wire that powers the player when the car is on. (try to follow me on this lol!) The YELLOW wire is usually the constant power from the battery to the unit, that would allow the unit to perform as you say, the RED wire is what powers on the unit when the car is turned on. It sounds like the problem would lay somewhere in there. One way to check this, (BE careful not to blow anything), take your cd player out of the car, put the red and yellow wires together, place the black wire to the ground on the battery and the red and yellow wire to the positive side of the battery. This will be all the power you need. Try to operate the cd player now and if everything works, you know that your just missing the Red wires power. Hope this helps.
Jun 26, 2010 | JVC KD-S5050 CD Player
Glitch???
sounds like you don't have power going to the red wire. should be a switched power source so it turns off with the key.
Apr 29, 2010 | JVC AM FM CD DET FACE CAR STEREO
I put a new stereo im my 1996 seville and it wont get power
sounds like its wired wrong .. there are three power inputs to the radio .. one is on all the time .. its for the clock only ... the second is from the panel lamp dimming circuit .. it turns on when the panel lights are on ... the third is the main power to the radio .. it is only on when the ignition is on or in accessory mode ..
Feb 19, 2010 | 1996 Cadillac Seville CA Value
Cd in car stereo won't eject. I have a 2005 Chrysler T&C van and there is a CD in my stero that won't eject. Any suggestions?
Try turning the radio off and disconnecting the battery for 2 min then reconnect the battery and turn on the radio. This may reset the radio to default so you can eject the CD and reset your station preset and clock. make sure the radio is off before disconnecting the battery or your going to be prompt to program a radio code. Good luck and this should work.
Jan 02, 2010 | 2005 Chrysler Town & Country
Radio/clock will not work. fuse 10 amp is good
There is usually 2 power sources to that stereo, one for when key on & one constant for radio memory & clock, you know that right? Check for that& Make sure it has good ground also. Use another ground source from back of stereo to metal just to be sure, if no luck, probably time for new stereo.
Jun 20, 2009 | 1994 Plymouth Voyager
Illumination?
you need to splice the + wire into the Acc wire. the with power only when you turn the key. and the - wire into the black ground wire. hope this helps
Jan 29, 2009 | iLO XM-MP3-CD Car Stereo
My JVC KD-S25 will only turn on when I press the eject button, and then it shuts off in 5 seconds.
I just bought this stereo and installed it the other day. I had the same issue. Hook the Yellow power wire and the red accessory power wire to the same power source. That solved my problem.
Oct 11, 2008 | JVC Car Audio & Video
Naxa Electronics NX-671 Car CD/ MP3 Player Logo
249 people viewed this question
Top Naxa Electronics Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Are you a Naxa Electronics Car Audio and Video Expert? Answer questions, earn points and help others
