Question about Harman Kardon AVR 510 Receiver
When reciever is turned on it shut's right back off. It will not stay on. Also it would loose volume. Why is this and can it be repaired?
    Sergeant:
    Champion:
  • 232 Answers
This is a main power issue and the only way to fix it is to replace the main board which is the heart of the reciever . costly exercise . sorry to hear that
Posted on Sep 27, 2009
Reciever shuts off after turning the volume up
You will have to change the volume controller and its circuit board.
F150 Accessories
Aug 12, 2012 | Audio Players & Recorders
I get my receiver to about 65% volume and it turns off
Check the ohm load for the reciever, then check to see what ohms are of the speakers. make sure they match. 4ohm to 4ohm, 8ohm to 8ohm. If unit feels hot when it shuts off, it's a themal overload, put in to keep the reciever from getting damaged. It comes back on when cool right? Overload could be on its way out and shutting down at a lower temp too
Jan 05, 2010 | Yamaha RX-797 Receiver
MY YAMAHA RECIEVER KEEPS SHUTTING OFF
The unit is going into protection mode. The message is a generic one and usually means that the output section is drawing too much current and has been shut down. Defective speakers can cause this, but in this case, I suspect that there is a problem in the front end that is allowing DC current to pass to the output circuits. This will cause a problem that will shutdown the system. Yamaha designs are not the most straightforward nad I would not suggest you attempt this repair without prior repair experience. Take this to a service center and request a detailed repair estimate and report the results here. Armed with that info, we canguide you further.
Dan
Jul 19, 2009 | Yamaha RX-V663 Receiver
My reciever is shutting down completley when i try to turn on the second zone. i tried rewiring it but it still does it could it be the reciever or do i just have the settings incorrect?
if the reciever shut down with zone 2 on, zone 2 volume at -3 and nothing connected to zone 2 it needs repair if not reconnect the speakers to zone 2 speaker connections and make sure you do not have more than 4 pair of speakers with impedence matching volume controls or a impedence matching speaker selector box
Jun 15, 2009 | Denon AVR-785 Receiver
System shuts off when the volume is moderate to high, now the system shut off and will not turn back on.
unplug the reciever for at least 15 minutes. then replug in all of your speakers making sure there is no bare wire showing. if the reciever doesnt ower on replace the fuse inside(make sure unplugged from wall)
May 17, 2009 | Yamaha RX-V661 Receiver
Reciever won't stay on
Do you have too much of a load on the amplifier? Or as SallieJohns mentioned, is it getting adequate ventilation?
Apr 02, 2008 | JVC RX-6018V Receiver
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
Avr 3806 power shuts off when volume turned up
Hello david 420
It looks like your receiver's high-speed protection circuit is being activated. It is definitively not a fuse. When a fuse pops, you have to physically replace it. When the protection circuit is activated, the speaker output is cut off and the power supply indicator flashes. There are a few reasons why this happens:
1.- Your speaker wire connections are loose. Whether they are banana plugs or bare wire ends, make sure the speaker terminals on the back of your receiver are tight using clockwise turning.
2.- Verify that your speakers have an impedance between 6 and 16 ohms. Your receiver was designed to work with that impedance range. Any impedance lower than 6 ohms will activate the protection circuitry.
3.- The receiver is used at high volume levels over a long period, which results in an
extreme temperature rise. Improving the ventilation conditions around the unit might help alleviate the problem.
If after complying with these suggestions, problem is still present, you might need to have the unit checked by a professional for possible circuit failure.
Hope this helps. Let me know.
cancerags
Dec 31, 2007 | Denon AVR-3806 Receiver
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Yamaha RX-V995 5.1 problem playing DVD's loudly
try using the analog mine had a problem with the dac. have any questions email me at facukoff@hotmail.com
Aug 13, 2007 | Yamaha RX-V995 Receiver
Harman Kardon AVR 510 Receiver Logo
225 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
