Question about Pentair Minimax Ch 400,000 Btu Propane Pool Heater Millivolt Ignition
Do not know how to start pilot light
I do not have the manuel for my pentair minimax ch 400, the heater will not ignite. i do not know where or how to try to start it help>
  • 366 Answers
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Posted on Oct 27, 2009
Pilot does not light
these pilots are pesky they clog with rust and junk replace the unit
Jun 28, 2014 | Pentair Minimax Ch 250,000 Btu Natural Gas...
I have a Pentair Minimax CH 250M pool heater. When I opened my pool, the heater started up fine and heated the pool initially. However, since the initial heater it has not come back on, and the pool is...
Do you have 24V at the brown wire of the gas valve? If you do then it is probably a bad gas valve.
If you don't have 24V on the brown wire it is probably the ignitor.
Jun 04, 2011 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Pentair Minimax CH Propane Millivolt Ignition Heaters error E05 what is it?
If you are firing, and then going off and getting an E05, your igniter is to blame. It may be glowing but it's getting weak. The diagnostic goes further but that is usually the fix.. With inactivity, the igniter is always to blame. You really need to fire it off weekly to make it reliable and make sure that your heater is serviced at least one time a year to keep all the internal components operating as designed.
  • PILOT ASSY LP MV CH150 IID
  • Manufacturer: PENTAIR WATER POOL AND SPA INC
  • Manufacturer Part #: 471291
  • Description: Propane pilot assembly for heaters with millivolt ignition.
  • Retail Cost: Approximately $65.00
Dec 08, 2010 | Pentair Minimax Ch 200,000 Btu Propane...
My pentair lp 400 heater service light is on. How do I service it?
Check the continuity accross the pressure switch, it il located on the right side above the header behind the panel with 2 or five screws.
Mar 06, 2010 | Pentair Minimax Ch 400,000 Btu Propane...
My pool heaters starts to hum and the service light comes on
millivolt heaters generate their own power from the flame on the pilot max is usualy 750 millivolt, check all connections clean and secure.
Mmake sure the pilot is lit
Dec 31, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
New ignitor..still won't light
Clean out the pilot assemby or replace it. It is probably blocked by rust and/or spiders and is not letting enough gas (if any) through.
Jun 18, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Pentair Minimax 250M
how many times it blink will tell you what is wrong check at the codes. unplug thermostat check fo homs 10 k around is fine at 80 degrees pressure switch require a by pass but DO NOT RUN THE HEATER WITH A BY PASS ANY CONTROL!!!!
Jun 17, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
Pentair 250 CH LP will not ignite. Pilot works
to test the presure sensor jump the wires that plug in to the sensor if it turns on the presure sensor is bad and the the thermostat do you mean thermo sensor the one that checks the water tep follow the wires to were they plug in turn power off get your finger wet and put it were it plugs in on the 2 prong and turn it on the heater will light up if the sensor is bad
May 11, 2009 | Pentair 250k Minimax Ch Lp Mv Heater
Pentair Minimax Ch 400,000 Btu Propane Pool Heater Millivolt Ignition Logo
419 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
