Question about Refrigerators
Admiral hmg 62186 freezer is working frig is at 55 degrees wont get colder
  • 833 Answers
SOURCE: frig won't cool, freezer works fine
Defrost unit completely. You're frosting up. Then, avoid leaving the door open, leaving liquids and food uncovered. Clean condenser coils. If it happens again, you need refrigerant.
Posted on Jun 09, 2008
docjohn174
  • 943 Answers
SOURCE: frig and freezer warm most of the time
HI thanks for your question, i think what your problem is . the compressor is over heating and cutted out. clean all the coils at the back of the fridge. if theres a fan motor at the back make sure its going check that thanks
Posted on Oct 17, 2008
aborcass
  • 2651 Answers
SOURCE: Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Posted on Oct 26, 2008
Sea Breeze
  • 4654 Answers
SOURCE: MATAG FRIG PTB2153GR FREEZER DOES NOT GET COLDER
Try turning the defrost timer clockwise until you hear it click. If defrost element and defrost thermostat are working properly, the refrigerator should begin to defrost. The timer is located inside the fresh food compartment behind plastic controls cover and also near the thermistat control.beb686d.jpg .I will be around if you need, just let me know,Sea Breeze
Posted on Mar 23, 2009
SOURCE: ice maker on Admiral HMG 62165 side by side
check the lever in the ice bin. if it is stuck in the up position it thinks the ice bin is full and will not make ice. Just wiggle it to the down position.
Posted on Apr 23, 2009
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
I opened up my frig and the temp said the freezer was -13 and the frig is at 55 degrees. When I presed it down it changed to 2 in the freezer and 32 in the frig part. Put after about 3 to 4 seconds it...
the damper vent door between the freezer and fridge compartments is frozen shut or if motor operated it broken or the motor is bad or power to motor is missing to open and close this door to let cold air into fridge from freezer also there is an evaporator fan near here make sure it is operating or cold air wont be moved
May 22, 2011 | Refrigerators
I have a admiral fridge designer series # HMG 62186 that I purchased in 1997. It has always had popping sounds and sparks behind the drawer in the freezer. A repairman told me this was normal, so I...
Hello WIntersno,
I understand that your refrigerator is sparking behind the freezer drawer and you would like to know if this is a fire hazard. In my opinion it would be a fire hazard as plastic and rubber is flammable and the repairman is not true in saying that this is normal. A refrigerator should never spark as this is also an electrical hazard. I would suggest having another repaid man come out and fix the problem or purchase a new box.
Thank you for choosing FixYa.com
Justin
May 08, 2011 | Admiral Refrigerators
Freezer portion doesn't freeze.
check settings. if good check if compresor is running. a relay on compresor could fail
Feb 10, 2010 | Maytag Admiral Top-Freezer Refrigerator
Freezer will not freeze solid. contents are cold, but not frozen. all settings are set to coldest setting. compressor will not kick on when freezer door is left open. I think the problem is that the...
Good day,
No real solution except to put it in a warmer location.
Understand, it is a refrigerator with the freezer just going along for the ride.
All manufacturers state the machine must be in an area that is no colder than 55 degrees.
The problem you have, is once the refrigerator section reaches temperature 34 to 39 degrees, it shuts the whole machine off. If the air temp surrounding the machine is near or approaching that temp, it shuts off, and may be off most of the day,
Domestic refrigerators are engineered to operate in area comfortable to people. Normally 70 to 95 degrees. Below that it will begin to unbalance.
Thank for using FixYa
Jan 12, 2010 | Refrigerators
Freezer works, frig doesn't
there is a fan on many newer units that blows cold air from the freezer side to the frig. If that fan is not working, the frig will be cool, but not 34° like you want it.
Nov 25, 2009 | Frigidaire Refrigerators
Feezer seems like it defrosts too long and ice cubes become wet, ice cream gets very soft, then they refreeze fine. thermometer shows 25 degrees above zero when it is happening. ADMIRAL MODEL HMG 19145, 15...
well its gone wrong now? 25 degrees "above zero?" wow,,, thats cooking!!!! lets be honest,, its 15 years old? its about time you invested in a new freezer you have had your moneys worth out of this one,, and it will cost you more than its worth to fix it up, it realy is time you treeted yourself,, get a new one!
Nov 17, 2009 | Refrigerators
I have an admiral model HMG 67184 side by side and I can't figure out why my freezer section still works but doesn't get cold enough to make ice cubes and the other side doesn't work at all. I do have...
1. Get the Food out of the Ref and Freezer. Unplug the power cord from the wall.
2. The cooling coil is in the back wall of the freezer side. Working from inside the Freezer.
3. Remove the back plastic cover to expose the cooling coil. It's called the Evaporator coil.
4. Use a hair dryer to melt all ice off the coil.
5. Put it back together. It should work for 3 - 5 days now at least.
6. Put a thermometer in there. After 24 hrs. the freezer should be 0 to 10 degrees F. and the Ref. side 37 to 44 degree F.
7. Check the door gaskets for tight fit, using a dollar bill for a gauge.
Shut the door on the dollar and try to pull it out in several places.
If it ices up again in a week or two, you have a defrost heater problem. There is a electric heat strip around the cooling coil. This heat strip comes on about 10 minutes every 8 or 10 hours. This heater melts the ice off the coil. There is a clock timer device under the ref. that cycles the heat strip. You may have a bad clock, fuse device or burned out defrost heater strip. The cooling coil must be ice free to work properly.
Jul 06, 2009 | Admiral 26 cu. ft. Side-By-Side...
FREEZER WORKS BUT FRIDGE IS 50-55 DRGREES
if all that is ok then you need to check the heater and bi-metal / if it starts frosting up you loose air into the refrig side and the freezer will start going down too / frig side gets tem from freezer ,,,,, i bet you have a bad defrost heater / larry
Nov 29, 2008 | Amana ARSE664BS Side by Side Refrigerator
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
155 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
