Question about Onkyo TX-SR674S 7.1 Channel Up-Converting A/V Receiver Amplifier
Onkyo amplifier everytime turn on the power about 1 second it rurn it off than going to standby mode I check all the fuse and check the speaker wire nothing wrong with it i even check the power input to the transformer it have power going in don't know what going on
  • 1 more comment
  • Anonymous Dec 25, 2007
    when i increase the volume it goes in stand by mode
  • Skippies Mar 20, 2009
    When I switch the amp on it works for about 30 sec to 1 minute and the it switches back to standby mode. I switch it of and back on again and the same problem will occur time after time
  • tbass45 May 02, 2009
    My receiver cuts off & goes to stand by every time it has output high frequency sounds. How can I fix it?
  • 54 Answers
Is power coming out of transformer at the right voltage. Also may have a power i.c. shorting to ground.Final anp i.c. may have a place to go to ground through a shorted capacitor.
GOOD LUCK
Big Red
Posted on Dec 29, 2007
My onkyo tx-rz810 keeps going toDet.pretction mode how do I get it out of that mode
Does the display show you are in protect mode , or is a light indicating that? The unit automatically switches to standby when the
"Hardware" - "Power Management" - "Auto Standby"
setting in the Setup menu functions are set. The protective circuit function may have been activated.
If this has occurred, "AMP Diag Mode" appears on the
display when the unit is turned on again, and the unit
enters diagnostic mode. If the results of the diagnosis is
that there is no problem, the "AMP Diag Mode" display
disappears and you can use the unit normally again. If
"CHECK SP WIRE" appears on the display, the speaker
cables may be short-circuited. Make sure bare speaker
wires are not touching each other or the back panel of
the unit, then turn the unit on again. If "NG" is displayed,
immediately unplug the power cord from the wall outlet
and contact your dealer.
• The protective circuit function may have been activated
because the temperature of the unit rose abnormally.
If this happens, then the power will continue to turn off
after you have turned the unit on again. Make sure the
unit has plenty of space for ventilation around it, wait for
the unit to cool down sufficiently, and then try turning it
on again. This is out of your users manual.
General suggestions are to remove all speakers and speaker wiring with unit off. Turn on and see if problem has stopped. If not, let unit cool down if warm and try again later. If problem is still there it needs repair shop work. I fht problem went away, shut off power and connect one speaker at a time and testing. Keep adding speakers one at a time with power off and see if a bad speaker or wire set can be located
Aug 20, 2017 | Onkyo Audio Players & Recorders
A-SV640 KEEP GOING TO PROTECT MODE
Hi, try powering up the unit with out any speaker connected if it still goes to PROTECT try factory reset if possible.
To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter standby mode.
If this does not fix your problem you should take your unit to service . :)
Dec 12, 2012 | Onkyo Audio Players & Recorders
I have a Lanzar 4000 watt amplifier hooked up to 2 12inch MA Audio subs. When I crank my car the green power light on the amplifier comes on, but after a second or two it changes to protection mode. I have...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to get an old school Opti Drive. .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-4000-watt-amplifier-hooked-up-2-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Jan 29, 2011 | Lanzar VIBE286 Car Audio Amplifier
Amp pulses from power to protect
check it without the speakers if they go to protection,and if not check the speakers
May 27, 2010 | Power Acoustik PS4-800 Car Audio Amplifier
Won't turn on.standby light on,fuse under cover is good.what next? onkyo tx-sr605
The only thing to test would be to disconnect all speaker wires at the receiver then turn it back on. If it still won't turn on, it's an internal power supply issue and will need service. If it turns on, post a comment and I can walk you thru further troubleshooting. Hope this helps
Dec 19, 2009 | Onkyo TX-SR605 Receiver
Onkyo ht-r500 no speakers attached goes directly into protect mode, standby light blinking..
I have a HT-R520 - First thing stated in the manual is 'Do Not Apply Power to the System Until All the Speakers Are Connected to the Receiver.' This practice avoids any hot connects to the speakers. As with any high-outpiut system connecting spreaker wires to the system while in operation can spike the speakers as well as the amplifier curcuits. Hook up your speakers first and give it a try. Good Luck!
Jul 14, 2009 | Onkyo HTR500 Receiver
Power will not stay on
Activated protection circuitry means that the amplifier is seeing conditions it does not like and is shutting down the power to prevent further damage.
Either you have a short in your speaker wires, in your speakers, or a blown amplifier.
Disconnect both speakers and turn on the amplifier. Does it still give the error message? If it does, your amp is blown. If it does not, carefully inspect your speaker wires and their connection. Make sure all looks good and reconnect the speakers and try it again. Still get the error message? You likely have a problem in your speaker cabinet(s).
Apr 21, 2009 | Onkyo HTR500 Receiver
The receiver goes on standby mode when volume is high
Your receiver is basically going into protect mode.
The SR 605 contains a microcomputer for signal processing and control functions. In an unlikely event, it may cause it to lock up. Unplug the power cord from the wall outlet, wait for 10 to15 seconds and then plug it back again.
Please also check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem. If you still can’t resolve the issue yourself, try resetting
the AV receiver/AV amplifier before going on to opening the Receiver.
To reset the Receiver to its factory defaults, turn it on and, while holding the [VCR/DVR] button, press the [STANDBY/ON] button. "Clear" will appear on the display and the Receiver will enter Standby mode. (note that resetting your receiver will delete your custom settings as well as your radio presets).
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck. Thanks for using FixYa!
Mar 13, 2009 | Onkyo TX-SR605 Receiver
Just bought refirb. Onkyo 805, hooked up front l&r plus sub and getting no sound. I set up am and fm as per manual and connected a cd changer thru the cd in via rca cables. Radio shows a signal but no...
After few sec when you turn on your receiver did you hear a click noise ? if yes your receiver is OK not in protection mode if no click noise is output protection in that case you must return where did you buy for service and update firmware a lot of update
However you can reset your receiver and debug the DSP section ( digital signal processor ) as follow
To reset
1. Press and hold down VCR/DVR button, then press STANDBY/ON button when the unit is Power on.
2. After " Clear " is displayed, the preset memory and each mode stored in the memory are initialized and will
return to the factory settings, and turn to Standby mode.
Now turn back on and check if it work or not and make sure check input mode such as analog or coaxial or optical input if stil no sound then debug DSP as follow
To set in DSP debug mode
1. Press and hold down DISPLAY button, then press STANDBY/ON button while the unit is powered ON.
The version number of m icroprocessor is displayed only for 3 seconds.
Main:
8 1.05/07903A
2. Press TONE+ button within 3 seconds above, the version number of 1st DSP is displayed.
DSP 1st:
SR8051:07601A
3. Press DISPLAY button while the 1st DSP version is displayed. The status of DSP and DIR will be displayed.
E1A48K0N/0FFPo
FFFFFF0 0 000
To exit
Press STANDBY/ON button.
Then unplug the unit for 30 sec then plug in it should work now if not you need to return it to 1 of the service center Onkyo in your town to repair it
Good luck
Nov 30, 2008 | Onkyo Audio Players & Recorders
Onkyo TX-SR674S 7.1 Channel Up-Converting A/V Receiver Amplifier Logo
212 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
