Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
I had 5 people in my hot tub today at different times. Would you shock the tub? I checked the bromine level and it was low. 20 minutes approx. per person. Thanks
    President:
  • 1,714 Answers
Could you restate the question/problem. I'm not sure I got the details?
Posted on Sep 27, 2009
  • Craig Butler
    Craig Butler Sep 27, 2009
    Do not add any more chemicals for five people, the normal solution will take care of it.
The hot tube foams when turned on and has awful odor how do I fix
First you will want to "Super Shock" with Chlorine and Bromine the water and run - the smell is a bacteria buildup inside pipes and other areas so you will want to kill all germs... Do Not Use while being supershocked! Drain your water and refill as per required You will need to visit a spa shop... You can get a Defoamer liquid but heavy foaming will require water change
May 08, 2017 | Cars & Trucks
What chemicals to use
you should use Bromain to keep it stable and a water clarifyer as needed, stay away from those "aroma therapy" things, they cloud the water and change the PH/Alkalinity. After you fill the tub you can take a sample to any pool supply store and they will test it for you.
Apr 16, 2014 | Therapure Four Person Inflatable Round Hot...
I have a walk-in jacuzzi-type bathroom tub. When the automatic blower comes on it sends out a mildew smell. How can I get rid of it?
First of all, after each use, refill the tub with warm water and run the jets for about 10 minutes to clear out any excess debris etc.
To eliminate the smell/mildew/mold. :
-Fill the tub to above the jet level with HOT (over 140deg.) water
-Add two tablespoons of low sudsing dishwasher detergent and five cups of distilled white vinegar
-Run the jets for 20 minutes
-Drain the tub and use a tooth brush or any small brush to gently clean inside and around all of the jets and nozzles, remove all foreign material you can from the areas inside (disassemble the outter rings to do so) and around the outlets. Be as thorough as possible.
-Rinse and refill the tub with CLEAN COLD water and run the jets for another 20 minutes.
-Drain the water and the smell and mildew should be eliminated.
To prevent future mildew build up/odors once a month fill the tub with HOT water (again) and four to five cups of vinegar (no detergent) and run the jets for 20 minutes. Drain and fill with clean cold water running jets another 20 minutes. If the tub is used very often you can increase the scheduled flushing of the system to every two to three weeks. The mildew/mold flourishes in the warm wet areas inside the jet tubing and nozzles. Diligent maitenance is the best way to make sure you're not bathing with any unwanted guests in your bathwater!
-Take care
Mar 01, 2012 | Washing Machines
My saltwater system produces chlorine but disappears fast
first of all your problem is a few things combined.
First lets learn what consumes chlorine
Heat,sun,rain,sun tan oil 3 of swimmers
you may need to run your generator 12 hours some nights it all depends on what kind of day it was and what the chlorine was to start with
Also if you do not have your salt as close to 3000ppm as you can then you are also not generating enough chlorine even if you are not triggering an alarm for low salt
you can not be below 2800 and no higher than 3800ppm
a test kit is available get the strips that reads #'s not the color strips for salt reading
Also you should be using a chlorine stabilizer to help hold the chlorine level this is only a help situation. it will not completly remidy your chlorine level going low if all the elements I mentioned are happening at the same time
Also be carefull not using the pool that is the worst thing you can do. You may go green quick without people in it stiring it up
I also recommend you use a non foaming algaecide every 5-7 days just follow directions for your gallons of water
By the way bromine tests are really not for pools they are designed to work with the hot water and chlorine level of a hot tub
your ph is fine, about in the middle alkalinity is what drives your ph so worry about the ph level and chlorine and you are good to go
Jul 09, 2010 | Intex Automatic Salt Water System for ...
How to change 20 liters per minute into volume in liters per hour
If you want to convert liters per minute into liters per hour you multiply your current rate of flow(liters per minute) by time(60 minutes) and you get 1200/lpm. This holds true for any amount of time. 15 minutes is 300 30 is 600 and so on.
May 24, 2010 | Mathematical Technologies Inc. MTI Tristan...
Intermittent jet problem on Spa form hot tub - low speed jet works, when button is pressed for high speed, it starts runs for a few minutes then switches back to low speed, then back to high speed again - ...
Hmm, that's an odd one. It could be either a fault with the PCB or the pump.
The first thing to check is the voltage to the twin speed pump. If that's ok the motor is probably the cause of the fault.
As always, with anything electrical you need to be very careful with what you're doing and if you're unsure seek professional help.
Regards,
Ian.
http://hottub.synthasite.com
Apr 14, 2010 | Pool & Spa
Cooling issues (low refridgerant?)
Make sure both the evaporator and condensor coils are clean. After the unit has been off for a couple of hours, start it back up and measure the temperature difference between the air entering into the unit (room air temperature) and the air blowing out of the unit and into your room. You should have approx 20 deg......take this measurement after approx 5 minutes of run time. If the temperature difference less than 15, you may very well have a refrigeration problem. If it is approx 20 degrees, then it could be a dirty coil or an electrical problem.......inspect all of your electrical wires and controls for any signs of overheating.....tighten all connections.
I hope you find this to be very helpful in your diagnosis. :-)
Mar 23, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
JACUZZI HOT TUB J365
Hi JOEY JIGSAW,
I'm Harvey the Master Plumber.
Your problem is: 2ND MOTOR ON TUB IS HUMMING BUT NO WATER MOVMENT REPLACED WATER TODAY #1 MOTOR IS WORKING IN LOW AND HIGH SPEED BUT #2 MOTOR IS NOT KICKING ON
Definately an electrical problem. First check the switches, if you find a bad switch replace it. Check the wire connrctions. A bad connection will cause great frustration. If you've been carefull with the first two steps and it's still not working it's time to see if # 2 motor has siezed up. Do this only if you know what you're doing. It requires disconnecting the wires to the motor and applying 110 volts from another source directly to the motor wires. If the motor just hums and gets hot, it's time to replace it or take it to a small motor repair shop. It might be wise to check the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 06, 2008 | Home
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
22 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
