Question about Ruud Central System Air Conditioner
Tempstar 2.5 ton airhanhdler fan not coming on, replaced 1yr ago
Along w/cap. also replaced compresser fan 3 months ago w/cap. has been working great cold!!!!! checked coils in unit all is well and cold clean. what do ya think ? relay,,,low voltage switch??
My ac is not working good
Posted on Sep 27, 2009
1999 grand cherokee laredo overheating when idling for 15 min. or so. Not when driving, everything ok. radiator replaced about 8-9 months ago, water pump pretty new, and extra electric fan worked on about...
Chanches are it is probably the fan. Anything over 15 miles an hour the fan is no longer needed. I would get a cheap hydrometer and make sure your antifreeze is still good.
Oct 18, 2012 | 1999 Jeep Grand Cherokee
Jeep Liberty 2004 sport gas cap not sealing
You can get the silicone grease at automotive and hardware stores. Apply to rubber seal on cap about every 2 to 3 months. This will ensure a seal so that the engine light doesn't come on. Worked great on My 2008 Liberty.
May 30, 2012 | 2004 Jeep Liberty
4 year old goodman 3 ton residential air conditioner is not working properly. Air handler is running, evap fan is running but compressor is not coming on. Had similar problem a month or so ago and it...
If the fan is running and the compressor is not running then you should be getting power to the compressor...
Often the dual capacitor will go bad and then the compressor will not start.
I usually change the cap to make sure that is not the problem.
If the compressor still does not start then check the start amps and you will find that you are probably getting locked rotor amps. or no amps... (open windings)
Either way you will have to replace the compressor...
heatman101
Jul 07, 2011 | Heating & Cooling
I have a 1.5 ton Tempstar condenser that keeps dropping the fan motor out after about 40 minutes.Have replaced all electric components except for the pump itself.Cap,contactor,motor,and the fan speed...
check the fan speed control,(should have a little dial on it or u have the wrong color wire pluged in)sounds like its on the wrong speed. motor is getting hot and shutting off due to thermo overload switch.
Aug 12, 2010 | Heating & Cooling
Fan always running
vacuum out air ports/power supply fan or use compressed air in a can to clean out dust.
yes this is bad, life is greatly reduced.
clean dust out once every other month or as needed.
Oct 02, 2009 | Computers & Internet
Ac do not drop down the tempture of room.
I have the same problem. Sounds like the unit is stuck in "Dry Mode". Dry Mode runs the compressor for short intervals (like one minute at a time). Mine is only 2 months old and worked great until a few days ago.
Jun 25, 2009 | LG Heat cool Window Air Conditioner
Need info. on a Tempstar Comfort 2000 unit.
This is a 2 speed condenser fan control board, the tempstar part number is
1086071, if you google tempstar 1086071 you will receive 1 listing for the part for something like 44 bucks, but if you go to sears parts direct and enter the part number they have a factory authorized substitute part number 1088977 that you can order from them for $17.49, some tempstar units were shipped without this control unit and the 2 speed fan just runs off the contactor on high speed only to do that disconnect the control unit and connect the black and orange wires that ran from contactor to the control unit previously together, and then the fan should come on in high speed when the condenser is on. there is a kit that they shipped these control units http://icpindexing.mqgroup.com/documents/086477/48201222001.pdf, (just for you to look at) so all you really need to do is get the new part from sears or run the motor in high and get rid of the part all together, hope this helps.
May 30, 2009 | Heating & Cooling
Over heating
I would suggest you to check the heatsink and cpu fan,
it could be dirty, if it is dirty, clean it and it should work fine.
To see heatsink and cpu fan, open 4 screw on the back of your laptop.
remove the cover, remove the fan screw (3), remove fan,
remove 4 screw on the cpu heatsink, remove the heatsink.
if your heatsink and fan are clean, it could be something else cause the shut down.
in this case you should send it for repair.
Oct 07, 2008 | Computers & Internet
2006 H3 Hummer Ac/Heater fan motor will work great and run, the next time I start and drive not come on at all. Then sometimes after driving about 15 min just kick on and run and do great.
I brought my 2006 H3 in to the dealer for the same thing. My blower stopped working all together but it started as an intermittent problem. He said he had to replaced a diode or resistor either behind the switch on the dash that controls the fan or on the fan motor itself. Have not had a problem since but that was only about 4 months ago.
Sep 10, 2008 | 2006 Hummer H3
27 in Magnavox Smart TV
problem in vertical circuit 100uf 35 volt cap also could have poor solder connections on vertical ic
May 02, 2008 | Philips Magnavox 20MS233S 20" TV
Ruud Central System Air Conditioner Logo
186 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
