Question about Kodak EASYSHARE M1063 Digital Camera
I believe the battery went died and it is still on.
I can't shut it off to charge the battery.
    President:
  • 2,761 Answers
Removing the batteries while the camera is ON will not cause any damage. When the new batteries are inserted the camera should be the OFF mode, and it will reset when powered up. Make sure that your replacement batteries are the correct ones for the camera, and I also recommend cleaning the battery contacts inside the camera. With the batteries removed, wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then insert the new batteries. If the battery replacement does not clear the problem, your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
My battery died today i got a jump when i drove it home i shut the vehicle of went to turn it on it went pop the top of the battery case blew off. Any idea what happened
Well. When battery is charging it emits hydrogen. In combining with the oxygen in the air it gives you detonating gas. That can be easily fired up by any sparkle when you start your engine.
Jun 24, 2015 | Cars & Trucks
Generator malfunction VW Jetta 2007
You have a alternator going out if you get the car going pull the + cable off if the car dies right away the alternator is bad . (Ase) cert auto tech
Nov 03, 2012 | 2007 Volkswagen Jetta 2.5 Sedan
Battery died now wont start
the security system need to be reset, plug your charger back on the battery then turn the ignition switch on and leave it on untill the security warning light turns off (about 10 to 20 Min) then turn the key to off wait 5sec then turn the car on it should be good to go, this solves this kind of problem 9 out of 10. good luck
Apr 07, 2012 | 2006 Saturn ION 2
My battery light came on then my power steering went out. any ideas on what the problem is or how to fix it?
When the battery dies and the engine shuts down, the power steering will stop working. I would have the battery tested first, if the battery tests ok, then the cause may be the alternator is not charging the battery causing the vehicle to run on what charge is left in the battery till it dies. I would have both of those checked out by your local Auto Zone, or local Auto parts store, usually they will do this free of charge.
Hope this helps...
Sep 17, 2011 | 2001 Ford Escort ZX2
When driving the radio died then the car died wouldnt start again wont even turn over
It sounds like your alternator went bad. The alternator is responsible for keeping your battery charged and at full power. If it goes bad, your battery eventually drains and things start to shut down.
Get your alternator and battery tested, I'm sure you'll find the alternator has died.
Oct 19, 2010 | 1994 Nissan Altima
I went snorkeling with my olympus 780sw camera last weekend and was taking photos just fine. It was nearing the end of the battery life I believe and when i went to try to turn it on, nothing happened so I...
I have the same problem with my 770 SW. The funny thing is, some outlets in my house will allow it to charge, some will just make the light flash. I found your question looking for a better solution. Try all the outlets in your house with the charger, I know it sounds silly, but it works for me.
Mar 05, 2010 | Olympus Stylus 790SW Digital Camera
LG enV touch keeps shutting off when charging
I would replace the battery and see if that helps with this problem
Mar 30, 2017 | LG enV VX9900 Cellular Phone
Battery not holding charge...
YOu may not be charging it long enough, or one of your currents could be off. I just went through this today. Take the battery into a battery store and have them test it. They will tell you what is wrong with it. My battery was fully charged, but the voltage was shot so it didn't matter.
Jun 19, 2009 | National Little Tikes Hummer Yellow
Craftman model#973.113050 drill/driver. Lost manual.Both batteries are reading yellow and red indicator lights in charger. I find it hard to believe that both batteries 'went' at the exact same time. What...
Batteries do go bad. They sorta die on an age and number of charges basis. I have several sets of DeWalt 18 volt tools. Comes to a total of 8 batteries. I always write the date purchased on the battery. Well, since last December both of my 2006 batteries went bad. I expect the 2007 batteries will go bad this year sometime.
With the NiCad batteries, they are good for a certain number of charges. Which is one reason to run the battery down till it begins to affect performance of the tool. Don't "top off' the charge by putting a battery that is not worn down in a charger, cause you effectively use up one more charge.
I have never had batteries last much more than 2 and a half years.
Now, the Lithium batteries are supposed to have fixed all that --
May 07, 2009 | Craftsman Drills
I have questions for any ipod user
What is your problem? The ipod doesn't die. Believe it or not but there's a battery inside of the ipod that if you want it to be repaired. Don't send it to the apple company, they'll charge you a **** load to replace the battery. You can find an ipod battery $10-$30 easy on the net&the proper instructions on the net you can replace the battery yourself!
Jun 28, 2008 | Apple iPod MA446LL/A MP3 Player
Kodak EASYSHARE M1063 Digital Camera Logo
48 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
