Question about Garden
Bought an old Homelite YardVark wheeled leaf blower at an estate sale. Does it use a gas/oil mix and if so, what is the ratio?
  • 22 Answers
SOURCE: Gas oil ratio
normaly 20 to 1
but with some of the newer oils you need to follow the instructions on the the oil bottle the newer cleaner fuels are now mixed at 50 to 1
Posted on Nov 27, 2008
sparksflyin
  • 47 Answers
SOURCE: oil/gas ratio for a modle UTO8110 homelite leaf blower
you can run 32:1 if you want to it wont hurt it but it may foul a plug since its more oil, 50:1 is the best ratio for your blower
Posted on Feb 05, 2009
  • 279 Answers
SOURCE: What is gas-oil ratio for homelite leaf blower
Unless you know better, I would use 40:1. That will give you more oil than needed if it is 50:1 but wont hurt the engine. Do some more checking to get the actual ratio...Lee
Posted on Nov 03, 2009
  • 203 Answers
SOURCE: I have borrowed a small Homelite leaf blower with
If you go about 32:1 you will be OK. It may be a 40:1 unit, but better safe than sorry if you are not certain.
Posted on Mar 08, 2010
Testimonial: "Thank you for your prompt response."
heatman101
  • 43501 Answers
SOURCE: What is the Oil To Gas Ratio on my 2 cycle
The oil to gas ratio is 50 to 1 or about 2.8 ounces of oil to a gallon of prem. gas
heatman101
Posted on Jan 19, 2011
I have a homelite 26b leaf blower and need to mix the gas and oil. I have 1gallon of gaa and 8oz of 2 cycle engine oil
read the instructions on the 2 cycle container for your mix ratio I.E. 50:1 may equal 4oz oil to 1 gal gas etc
Oct 26, 2016 | Homelite Garden
What is gas ratio 50 t0 1 for homelite leaf blower
50:1 is the gas ratio... thats about 2.6 ounces of 2 cycle mix to one gallon of gas
Sep 14, 2014 | Homelite Garden
I have a Homelite YARD BROOM II 170 mph Blower.what is the oil to gas ratio?
I usually mix at 50:1 useing klotz two stroke oil,or 44:1,klotz is high performance zynthetic oil,also has nice sweet smell when running,keeps the neighbors from complaints on bad smell.
Feb 11, 2011 | Homelite 'Yard Broom' Leaf Blower
What is the fuel gas ratio for a homelite yard broom ll 170mph blower
The mixture should be at a 50:1 ratio, using Premium Exact Mix™ 2-cycle engine oil. If Premium Exact Mix™ 2-cycle engine oil is not available, use a high quality 2-cycle engine oil, mixed at a 50:1 ratio.
You can get the manual on the link below if you need it also.
https://www.dixiesales.com/ipl/338/ut08120b%20manual_254_eng.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jun 27, 2010 | Homelite 'Yard Broom' Leaf Blower
I have a homelite yardvark blower and I want to change the fuel filter. How do I change the fuel filter? Yardvark runs fine at beginning, but begins to run eradicatly after a short time. What's the...
could be fuel lines, fuel filter, or your carburetor needs to be rebuilt. The carb has thin rubber diaphragms that get hard over time, hot weather, or stale gas. Need more assistance,
email desertairrepair@aol.com.
Jan 31, 2010 | Homelite 'Yard Broom' Leaf Blower
My redmax eb7001 emits white smoke while running, the more power...the more smoke
Your fuel-oil mixture has too much oil in it. The standard ratio is 40:1 which means one of the little bottles of 2-stroke oil (about 2.6 fluid ounces) is added to 1 gallon of gas. Homelite recommends a 50:1 ratio but 40:1 is better, at least in my opinion.
The last time you made the mix, did you pour the oil into the gas or did you pour the oil into a little bit of gas in the gas can, shake well and then fill it with a gallon of gas? The former can give you lots of smoke as well because it is not mixed thoroughly. The latter is the best way to mix because the agitation and the flow of gas mixes the oil better.
Other possible causes to this problem are: how old is the mix you are using? Did this mix sit all winter last and you sre using it now? If so, did you add some Stabil to the mix before storing?
Depending on your answers to the above questions, you can determine why you are getting so much white smoke.
My recommendation to you is to:
(a) Empty the blower gas tank.
(b) Mix a fresh batch of oil and gas in an approved fuel container.
(c) Pull the spark plug and inspect it, if it is black/sooty replace it.
(d) Pour the new mix into the tank and start the blower.
This should get rid of the excess smoke, if it doesn't, let me know here. Good Luck!
Oct 22, 2009 | Homelite 'Yard Broom' Leaf Blower
Need a Manual for HomeLite Leaf Blower Vacuum Model Ut08934B, specifically for fuel mixture ratio.
Most 2 stroke engines.......99% now use 50 to 1 mix in the fuel.
Others are close to this ratio.
Older....over 20 to 30 years old ........that may have had 20 to 1 ....or other ratios run happily on a 50 to 1 ratio using the newer 2 stroke oils.
And......BONUS.......they have increased engine life because of reduced semi burnt oil build up caused by "too much oil".......particularly around the rings on the piston(s) etc.
Aug 31, 2009 | Homelite Garden
Gas oil ratio
normaly 20 to 1
Nov 24, 2008 | Homelite Consumer Products MightyLite...
Garden Logo
781 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
