Question about Lexmark X340n All-In-One Laser Printer
I have a lexmark x340 and every time it prints the paper jams on the back cover.
Change sensor exit to the fuser unit
Posted on Jun 14, 2010
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
200.20 lexmark x340
My solution: I am in Europe, where we use A4 paper format. If the printer is set to Letter format, it will give this error. Go in menu and set the A4 insteed Letter. I found this simple solution after I dissansambled all printer and check paper path and sensors :)))
Jul 30, 2012 | Lexmark X340n All-In-One Laser Printer
LEXMARK IMPACT S 305 A 5 PAPER JAMMING, HOW DO I REMOVE IT, THEIR IS NO WAY IN VIA THE BACK.
Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path. Open the scanner unit or the printer cover.
  4. If you can see the paper jam, the cartridge area should give you enough space for your hand to reach on the jammed paper in the printer.
  5. Carefully remove the paper jam and make sure not to tear or leave torn pieces of paper in the printer. It can cause future paper jams.
  6. When the jam is cleared, close the printer cover.
  7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
  8. When the printer turns on, try to print again.
Aug 19, 2011 | Lexmark C533DN InkJet Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
LexMark x3430 printer
Here is a guide of all possible paper jam locations on the X340 printer. http://bit.ly/cS4lpm
If still no paper is found on any of those places then the printer has a faulty sensor. Depending on the paper jam numeric error is the sensor that may be failing.
Feb 12, 2010 | Lexmark X340n All-In-One Laser Printer
It show 84 replace photoconductor
I have problem in lexmark X340 , when I give any print command occur problem paper jam with this message error " 201.02 paper jam remove cartridge "
note: I am test sensor but not problem
Jul 07, 2009 | Lexmark Lemark E352DN Laser Printer
200.13 paper jam remove cartridge
The Lexmark x340 and x342n has 3 sensors that identify the path of the paper below it.
2 are below the feeder roll of paper and the other in fusion.
Clean the sensor or adjust the tamnho the paper tray to which the document is.
Vagner
Jun 19, 2009 | Lexmark X342n All-In-One Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Lexmark P6250 paper Jam
Don't know if it's the same problem i had but its maybe worth a try. Canon MP160
My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Jan 27, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark X2350 paperjam/top cover sensor problems
I thought I got all FOD out of my printer, till I turned it up side down.
Pencils apparently find the x2350 very comfortable.
Nov 30, 2007 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X340n All-In-One Laser Printer Logo
366 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
