Question about LG Vu CU920 Cellular Phone
LG VU Does not work with 4GB card
When I leave a 4 gb card in my Vu the phone freezes until I pull the battery
  • sufiakamal May 11, 2010
    GENERAL PROBLEM
    » Nokia Solution » Motorola Solution » Sony Ericssion Solution » LG Solution » Samsung Somution
    UNLOCK CODE
    » Nokia Unlock Code » Motorola Unlock Code » Sony Ericssion Unlock Code » LG Unlock Code » Samsung Unlock Code
    sufia10
  • 8 Answers
SOURCE: Memory card format for lg vu 920
Usually to format a disk, memory card; anything, you need to be plugged into a computer.
Which requires a USB cable for your phone, or a card reader. If you don't already have a USB cable, it's usually easier to come across a card reader simply because everybody uses them. With a USB cable, most stores don't carry them and have to order, because it's specific for a phone.
Now if you have a USB Cable or a card reader already, plug it into your computer. (With the phone, make sure the "USB Connectivity" settings are set to "Removable Disk". This way, it won't read the phone's memory, just the memory card.)
Once the memory card is detected, right click on it, and there should be an option that says "Format". Click it. You should get a popup asking if you're sure or not. Obviously you're serious about formatting the card, so click yes.
There's a check box for "Quick Format". It's a sort of way of half-assed formatting; it's faster, but not as thorough. Whether or not you do that is up to you.
Posted on Nov 24, 2008
  • 3 Answers
SOURCE: 8gb micro sd card does not work. lg vu cu920. is there a fix
I HAD THE SAME PROBLEM AND KEPT ON MESSING WITH THE 4G MEMORY CARD AND FOUND OUT THAT I HAD TO FORMAT THE MEMORY CARD ON MY COMPUTER AND NOW IT READS THE CARD..ON THE SIDE OF THE SD ADAPTER HAS A SLIDING PIECE THAT SAVES YOU FROM DELETING THINGS ACCIDENTALLY BUT IF YOU SLIDE IT INTO THE MIDDLE POSITION THEN IT WILL ALLOW YOU TO FORMAT THE MEMORY CARD BUT YOU WILL LOSE WHATEVER THAT IS ON THE MEMORY CARD AND WILL HAVE TO DOWNLOAD IT ALL OVER AGAIN..I HOPE THIS IS CLEAR ENOUGH FOR EVERYBODY TO UNDERSTAND BUT THIS IS HOW I GOT MY MUSIC AND PICS ON THE MEMORY CARD
Posted on Feb 13, 2009
SOURCE: Where do you put the memory card for a LG Vu
you slide off the back of the phone. Remove the battery. Then take out the sim card. Right beneath that is where the memory card is supposed to go. You can easily tell if it's in or not because you have to push it down and hear a pop. Hope that helps, I've had mine for three weeks now!:)
Posted on Feb 23, 2009
ginko
  • 19396 Answers
SOURCE: unlock code for lg vu cu920
Nope.
Try first calling the manufacturer to get the subsidy code.
If you do not want to call the manufacturer , then try the method on link below, but it does not work on all cu920:
Subsidy unlock instructions for the cu920
Posted on May 21, 2009
cubataman
  • 178 Answers
SOURCE: i want unlock my lg vu att
Try this website
www.mobileincanada.com
They will send you an unlock code based on your phone's IMEI number.
They are fast and cheap.
Posted on Aug 31, 2009
LG VU memory card not reading 4GB or 8GB
push the memory card in until it clicks into place.
Sep 09, 2009 | LG Vu CU920 Cellular Phone
Lg vu memory card is not showing as installed Just put in a 4 gig memory card but the phone is not recognizing, says the memory card is not ready
Try loading the card with songs. I've read that the VU won't accept SDHC of 4GB, until you load it with a min of 2GB of stuff...songs, movies..etc.
Aug 02, 2009 | LG Vu CU920 Cellular Phone
Phone shuts off
if you droped the Vu than you could have damaged the insides and that might cause the repeating of it shuting off but a easyer way to get music onto your Vu is to get a Micro SD and get an adaptor for it and put music on that and then plug the SD into your phone its alot easyer and faster than useing the cord
hope this helps
May 27, 2009 | LG Vu CU920 Cellular Phone
Just bought an LG Vu and 8 gb sd card. The AT&T rep said it would take it, but my phone won't recognize it. I find mixed answers as to whether the phone will only take a 4 gb max.
The LG Vu will only recognize up to a 4GB memory card. For more information check out PhoneScoop
Anything larger will not be recognized by the phone and your best bet is to take it back and see if they will refund you the difference for a 4GB
Feb 02, 2009 | LG Vu CU920 Cellular Phone
Jan 26, 2009 | LG Vu CU920 Cellular Phone
LG VU IS SHUTTING DOWN AND AND THE BATTERY DRAINS IN 8 HRS
Take the memory card out if installed. Supposedly this is a known issue that is causing the LG CU920 to shut down. That is what was explained to me by a sales guy at Best Buy. I replaced my phone once before getting that bit of info and have not had a problem since. Unless you count not being able to use a expanded memory card.
Jan 03, 2009 | LG Vu CU920 Cellular Phone
Lg vu cu920
How big is the memory card? Some of the older versions of the Vu don't support anything above 2 GB. My phone is a newer version, so it supports 4GB.
It all really depends on whether or not your phone is new, and what version it is...it varies depending on the age of the phone and what network it's on.
Nov 22, 2008 | LG Vu CU920 Cellular Phone
LG Vu CU920 Cellular Phone Logo
27 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
