Question about Jensen VM9510 Car DVD Player
I am changing the track on a SkiDoo 2009 XP snowmachine and cannot get the brake rotor off. Any suggestions?
2009 Chrysler 300 vibration when brakes applied
have the disc rotors checked for warp age
they warp from heat or too thin
have it done in a brake specialist shop
the fix will be new rotors
Feb 01, 2016 | 2009 Chrysler 300
2009 gmc acadia replace rear brakes
this is on a bigger truck but its the same procedure for changing your brakes if you dont have a piston tool you can use a c-clamp with an old pad to depress piston (s)back or most auto stores will let you borrow tools
Yahoo Web Search
Aug 07, 2015 | 2009 GMC Acadia SLT-1
How to change stator on 1994 skidoo 580 grantouring snowmachine &what tools will I need
Why do you need to change the stator? If this was bad, you would not be getting any electrical power.
I'd change the HT leads/coil leads first & then maybe the coil. If you can get a loan of a coil & leads just to see if this solves your problem before buying new ones.
Dec 16, 2014 | Tank Motorcycles
How do I change Rear rotors on a 2009 Mercedes e350?
remove wheels. remove brake calipers. pop off torx screws that secure the rotor on hub. use a copper or brass hammer and smack the rotor and it should dislodge off the hub. smacking the rotor with a hammer will dislodge the rust that built up on the contact surfaces of the rotor and hub which causes the rotor to be stuck on hub surface.
Oct 11, 2014 | Cars & Trucks
Why does my 2009 equinox brakes lock when i go over 60 mph?
it gets hot and thight , replace with new springs and put a larger gap between drum and shoes , oil the pad racings and track of caliper to rotor .
Jul 29, 2014 | A.B.S Computers & Internet
Toyota corolla vibration
could be worn down rotors (the big metal disc). The thinner rotor will not dissipate heat during braking and the pads get too hot to be able to grip the rotor and while braking you get a shudder effect
Check also the rear suspension as this can cause font tire wear un evenly
Nov 05, 2017 | Cars & Trucks
2009 Honda Pilot - steering wheel shaking
You have warp front brake rotor's, have repair shop **** the rotor, to make sure there thick enough, or they will warp again if to thin, if rotor's thick enough have them cut.
Jul 23, 2010 | 2009 Honda Pilot
Jensen VM9510 Car DVD Player Logo
496 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
