Question about Panasonic Televison & Video
My Panasonic DLP television suddenly lost picture, went to snow and lost audio. What is wrong?
  • 647 Answers
If you have snow that means you've either lost the signal source (cable satelite antenna) or the TV tuner is bad or your not on a recievable channel. Try hooking a signal to one of the video inputs of the TV.
More info on what you have hooked to the TV would help.
Posted on Sep 27, 2009
My Panasonic DLP had yellowish lights in the center and just one night the picture just went off. What do u think is wrong.
Couple things. If the color is going out, you probably need new bulbs. Easy to change, get em on Ebay for pretty cheap. I had an LG DLP and the pic would go out with big changes in the barometric pressure, and also from over heating. Call manufacturing and let them know you're not happy. They extended my warranty for me.
Sep 18, 2012 | Samsung HL-S6187W 61 in. HDTV
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
PHILIPS 50 Inch HD DLP Projection TV the picture went out suddenly and there is not sound but a loud humming-buzzing coming from the set...any ideas on what could be wrong or if it can be fixed?
It's the optical block (color wheel) and the same thing happenned to our Philips 50" DLP. From what I've read, it's not worth the trouble & $$ to fix. Dig a hole!
Oct 16, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
RCA XL100 20" Snow on screen
you have lost one of 3 things,Antenna/Cable, Tuner or part of your tv's power supply
Sep 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Replaced lamp; still have no video yet have audio
Did you replace the lamp because the picture went out (black)?
May 21, 2009 | Panasonic Televison & Video
Vizio P42HDe Plasma TV - Audio, but no picture
check the backlight inverter and the Y-sus board the one to your left. if those are fine check the bottom right buffer board
Mar 03, 2009 | Vizio P42HD Television
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
Feb 02, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Panasonic PT-53TW53G
Mikey,
There are any number of possible failures that can cause the symptoms you're describing. For example, C509 a .47uf/250v mylar cap has been known to fail in those units causing the wavy lines. On the other hand convergence amp failures can do the same thing. That unit uses two STK392-110 Sanyo amps at pos# Ic7001,Ic7002 Panasonic p/n# C5aa00000203 and more in that circuit needs to be tested and signal traced to isolate all of the problem if the amps are the culprit. In short, I don't think this is one you want to tackle with less than a 20 mhz scope and some serious background in electronics.
Bill
Dec 11, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Color seems inverted!!! please help!!!
CHECK OTHER TYPES OF VIDEO INPUTS. IF USING COMPONENT VIDIO CHECK YOUR CABLES ARE ALL MAKING GOOD CONNECTION, YOU CAN USE AN AUDIO CABLE TO CECK INDIVIDUAL COMP. VID. CABLES TO MAKE SURE THE CABLES ARE GOOD.
Oct 26, 2006 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Televison & Video Logo
102 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
