Question about Craftsman Garden
MY TILLER HAS 4 ROUTATING BLADES IN THE FRONT,
MY TILLER HAS 4 ROUTATING BLADES IN THE FRONT, THIA IA FOR SMALL GARDENERS, WHEN I TRY TO PULL THEE CORD TO START IT IS NOT CATSHING
  • 582 Answers
Under the housing where the pull cord is found is a latch type item with what they cal daugs, when you pull the cord the daugs fly out and catch into slots which will loch to start the engine, try some WD40 spray lube to free the daugs if this dosn't do the job you may end up getting a new housing or starter assembly
Posted on Sep 27, 2009
Do you have or can you find Agrator Rototiller Gears ?
Agristore USA ' Replacement Parts ' Agrator Tiller Blades
www.agristoreusa.com/collections/agrator-tiller-blades
Tiller Blade for AGRATOR D-UR $6.75 · Tiller Blade for AGRATOR D-UR $6.75 · TillerBlade for AGRATOR D-UR $8.50 · Tiller Blade for AGRATOR D-UR $8.50.
Sep 25, 2015 | Garden
Where can i buy a pull starter for a gardeners choice lawn mower
Gardeners choice makes multiple brands. Look at the engine make and repost
Mar 11, 2013 | Garden
The oil seal where the tiller attachment fastens to the tiller is leaking how do i remove the seal
IF THIS IS A WALK BEHIND TILLER OR FRONT TINE TILLER. THERE SHOULD BE PINS OR BOLTS HOLDING THE TINES ON THE DRIVE SHAFT REMOVE THESE AND PULL THE TINES OFF THE TILLER. THEY MAY GIVE YOU A HARD TIME GETTING THEM OFF SO DON'T GIVE UP. ONCE YOU GET THE TINES OFF YOU SHOULD SEE THE SEALS YOU CAN POP THE OLD ONES OUT WITH A SCREW DRIVER CLEAN OUT THE SOCKETS WHERE THE NEW SEALS WILL GO REPLACE THE NEW SEALS GENTLY WITH A SMALL HAMMER TAPPING THEM IN EVENLY AND TRY NOT TO BEND THE SEAL
Feb 05, 2011 | Garden
How to change primer blub on craftsman mini tiller?
I suppose this is on the 4-stroke mini tiller. There is a circular retaining washer with "tangs" on it in the bulb housing area. Clean the area well and you will see it. It is black probably. Use a very small screwdriver and reach in and pry it out in a few different spots and it will pull free and so will the bulb. Insert the new bulb and the the retaining washer making sure the tangs on it are all nice and flat. Press it back into place with the same small screwdriver being very careful not to puncture or tear the new bulb.
Nov 07, 2010 | Craftsman Gas Mini - Tiller/Edger
Blades turn slow and dies out under load
Is the engine running good or misfiring with no load ? Dieing under a load maybe a sparkplug or bad fuel you possibly have water in the fuel ... as far as your tines not turning fast enough this sounds like drive belt related
Aug 08, 2009 | Mantis 4-Cycle Tiller
Mantis tiller blades
Common problem with these small tillers.
The gear box needs replaced or repaired.
But first try removing the muffler and see if it helps any as it could be the muffler is stopped up since it runs a gas/oil mix.
Jun 24, 2009 | Mantis 2-Cycle Tiller
Motor run but blades don't
mine is doing the same thing
May 14, 2009 | Mantis Tiller
How do I remove the tiller blades from a small walk behind front tine tiller. Do they pull off or do they twist off
when you pull the pins,they should come straight off.sometimes they need a little help with wd-40 and a hammer.
Apr 27, 2009 | Garden
Garden Logo
102 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
