Question about Samsung 226BW Monitor
I have a samsumg 226bw that is acting up. When I turn on my computer, the monitor blinks once to show that the computer is booting, then after that no display. If I turn monitor off and on again, the display shows only for about a second and then nothing. I cannot see the menu or anything. what could be wrong?
  • Samsung Master
  • 32,281 Answers
You could have a faulty inverter board or faulty CCFL lamp.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Posted on Sep 27, 2009
Testimonial: "Appreciate your advise. I will look into the website. Hopefully I can fix this unit."
  • 34 Answers
- This is how it went for me..I have a Samsung SYNCMASTERI have a samsumg 226bw that is acting up. When I - 2.gif 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A SYNCMASTER 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for a day with no glitches whatsoever. So I have resnapped mine back together. I hope you can too. - I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps.
Posted on Oct 24, 2009
226bw does not turn on flashing power button
A flashing power indicator is a common symptom of a failure in the power supply board filter capacitors. If you can do a little soldering then you can do the repair it yourself. Here is a link to repair information:
http://www.ccl-la.com/catalog/product_info.php?products_id=138
This video shows how to open the monitor to get to the power supply board. It is for the 225BW but the case is the same.
I hope this helps you get your monitor going again.
BuddyMc
Nov 23, 2012 | Samsung 226BW Monitor
Samsung 226BW screen takes a long time to show anything
This model may have defective capacitors in the power supply. I normally replace the 2 or 4 bulging caps and normal function is restored.
Monitor Mike
Apr 20, 2010 | Samsung 226BW Monitor
The monitor either stays blank when the pc boots up or displays briefly and then goes blank. It will sometimes display properly if I turn it off and on after the computer is fully booted up. It has been...
First place to look will in the power supply section, look for bad caps with bulging top/bottom seal, post back what you see inside so we can help you further, see example of failed SAMSUNG monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 27, 2010 | Samsung 226BW Monitor
Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
Aug 26, 2009 | Computers & Internet
Problems with a samsung 226bw lcd monitor
This problem may be due to various reasons. I advise you to visit a service center. they will replace the faulty part,( You may call them and explain them by giving the serial number and model Code).
Jun 29, 2009 | Samsung 226BW Monitor
Samsung 226BW won't turn on until a few minutes.
This is an indication that the power board in the monitor is bad.
Mar 02, 2017 | Samsung 226BW Monitor
Samsung 226bw weird display problems
At first you should clarify if your GPU or LCD is broken.
Do You have any chance to try another monitor with your Graphicadapter or to try your monitor on a different PC?
Moreover you should try it with a new cable.
The symptom of weird symbols sounds most likely like a overheated or wrong-plugged Graphicadapter
Nov 20, 2008 | Samsung 226BW Monitor
What about the blue circle LED on the power button ? still blinking or not ?
For the record I've had some problems with this screen too, sometime I had to unplug and replug my Video Card (and the DVI Cable) and everything was back to normal
Hope it helped you
Nov 07, 2008 | Samsung 226BW Monitor
Samsung 2232bw monitor
this shows the internal circut problem, need to consult a technician
Oct 28, 2008 | Samsung 226BW Monitor
Movie on monitor
Hi, Normally I would suggest that you first lower your laptop's screen resolution, refresh rate and color quality and verify that you have enabled the external monitor or dual view in your Display Property Settings as well as the Fn key + F?. However, this kind of problem should not exist with an LCD Widescreen monitor with specs and features as your Samsung 226BW. If trying the reco on the first paragraph and you still have no movie display (but all other laptop display shows), perhaps it is a problem with the Samsung 226BW. To my knowledge, this particular brand/model uses no less than 3 different panel display, some not as good as the others. Verify that you have an original Samsung panel display in your Samsung monitor by looking at the sticker at the back of the screen, it should say Model: 226BW [R] S. If it says A or even a C, then perhaps the display panel is not living to its specs/claimed capacities. You of course can request a replacement from your dealer and cite your problem but insist that it be an "S". Most instances (but not always) an "S" would mean panel screen by Samsung, "A" by AU Optronics and "C" by CMO. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 23, 2007 | Samsung 226BW Monitor
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
1,841 people viewed this question
Top Samsung Computers & Internet Experts
asber
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
