Question about Poulan Garden
Can not get it to crank batt is good new switch
  • mickey813
    mickey813 May 11, 2010
    what do you have is the moter locked up can you turn it by hand
  • 157 Answers
What are we talking about
Posted on Oct 26, 2009
No crank 99 grand prix half the dash goes out somtimes
It could be the key switch, or the neutral safety switch.
You would need to know if you have power on the small wire on the solenoid that comes from the key switch when the switch is in the start position. The neutral safety switch is in the circuit between the key and the starter.
Feb 06, 2013 | 1999 Pontiac Grand Prix
WillNot start batt., good starter, good all fuzzes good
If the engine is not cranking over, it could be the clutch safety switch
(standard trans), Neutral safety switch (automatic) or ignition switch.
If the engine is cranking but not starting, it is not the starter, battery
or alternator. Check fuel supply, ignition and compression.
Sep 27, 2012 | 1997 Chevrolet Cavalier
Won't crank has new battery
if the lights come on you'r getting juice from the batt,if they go out when you crank the motor over batt is bad or you have bad batt connections
Aug 27, 2012 | 2000 GMC Jimmy
90 vette, ZR-1, Engine won't crank. Solinoid won't click. Worked fine since new. Washed engine, started & drove into garage, 2 days later won't crank. Has 30,000 miles, owned since new. Batt....
Never wash engine in zr-1,starter is in center of engine,drain hole is usually plugged up,starter has shorted out,will need new starter,clean drain hole out when it is changed
Nov 06, 2010 | 1990 Chevrolet Corvette
2000 xterra wont crank. just a click when i try to crank. new starter batt is good. ??????
check your postive and neg,cables to the starter ,if there is alot of corrision on the wires you wont get a good signal
Sep 20, 2010 | 2006 Nissan Xterra
Starter clicks but engine won't crank, starter tested ok. 1991 cadillac seville. bypasskey system recently by passed `1 month ago. no ecm or bcm codes.
is the battery weak?if good ck all grounds,then ck voltage from batt. down to starter.also make sure solenoid isnt loose on starter case.If you did bypass and it cranks then neutral switch or ignition switch could be worn.good luck
Jul 07, 2010 | 1991 Cadillac Seville
I was driving my 2002 dodge caravan i turn the car off and it would not turn back on.i got no power. then i got a jump an it came on but the battery light came on.
Check your battery connections first. If thats good do a load check on your batt. When its dark turn your headlights on with car off. Are your lights really dim. If so you might need a new batt. Also make sure that your nuetral safety switch is working. Move the steering column shifter around when you crank the motor. Any change?
Sep 19, 2009 | 2002 Dodge Caravan
Have new proper batt.Have new starter celenoid,new
Remove spark plug and attempt to crank. If it turns faster (without compression) it may be valve adjustment. If it still turns over slowly with plug out check battery ground for tightness to mower body. If the ground is good check the starter by removing battery and atttaching jumper cables to pos and neg battery terminals first, then the pos jumper to starter terminal (where red wire attaches). Then touch the neg jumper to a good engine ground (I use shroud bolt). Be careful as this last connection will cause some arcing. If it still cranks slowly with the plug out, it is probably the starter.
Apr 11, 2009 | Craftsman Garden
New starter good batt. only clicks wont turn over 1995 montero
The Batt does not have a full charge or it is the wrong cranking AMP's for the car... find out if it is the right Batt and also that it is put on a "slow charge" over night or at least 6 hr's
Jan 20, 2009 | 1995 Mitsubishi Montero
Garden Logo
22 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
