Question about Sakar 59379 Digital Camera
Help me.... my camera when i plug it in it says it needs a driver??
Uninstall
hi there!
I suggest that you should uninstall the drivers of those cameras. Restart computer and re-install the necessary driver for needed camera again as fresh.
To do this, you should open Device Manager ( by press Windows logo and Pause/Break key at the same time or click on Start then right-click on my computer and go to Manage then select Device Manger). On the Device Manager windows, look for images devices, click arrow at the front to expand it. Right click on the Camera name and select uninstall. Do this for uninstall the driver that you don't want to use.
Restart computer and re-install new camera driver. Remember, install software/driver first, then plug the camera after.
Thanks for reading. Hope this will help you.
Jul 29, 2013 | A4tech Computers & Internet
How to install usb camera?
You need to install the USB camera driver that came with it on a CD or mini-CD: plug the USB camera and if the camera driver is not a 'standard' type, it should prompt you for the driver location (which should be the drive assigned to your CD/DVD device).
Hope it helps.
Sep 27, 2010 | Computers & Internet
Can't get it to work on my powerbook g4
Just plugging the camera into the USB Port will not get it operational. You need the drivers for the camera to work with your operating system.
Copy this site and paste it in your web browser address bar and hit ENTER.
http://www.download32.com/webcam-diagnostics-d35065.html
to download the Camera Diagnostic Tool and run it to check out your camera and/or problem.
Be sure the camera is plugged into the USB port before running the program.
As you run the program, write down the info about the camera so you will know what model and who manufactured the camera you have
attached so you can get the proper software drivers for it.
Then let me know and I'll try and get you the download site for your camera drivers.
Hope this helps. Bud
May 23, 2010 | Logitech QuickCam Pro 9000 Web Cam
How do i get the soft ware for this web camera??
Download driver off vendors website
You will need to install driver BEFORE you plug n webcam or will not work at all.
Only plug it in when told to.
Mar 29, 2010 | Logitech QuickCam Messenger Web Camera
Labtec webcam not working why i did every thing my computer not detecting this ****** i install all the posible drivers already i used window xp. I hate this man.
ok, uninstall all related drivers to this camera,
Now using the supplied disk install the camera software but please do not connect the camera YET, if the camera is already connected,
remove the camera and reboot,
so you installed the camera software now plug the usb camera in, it will now detect the install camera software and work.
Regards
gewiz.
Dec 05, 2009 | Labtec 961307-0914 Webcam
Hi im having trouble installing my webcam to my laptop, pls help
Assuming your lappy runs Microsoft Windows XP, and has a CD drive in it, you take the CD that came with the camera, place it in the CD drive, and when the box pops up in windows, tell windows to find the driver. If the camera needs to be plugged in the computer, the driver should tell you this as it installs.
Some drivers want the camera plugged in before the driver install, and some after the driver install. If you don't have the CD that came with the camera, you can usually find the driver for the camera on the world wide web.
Jan 31, 2009 | Cameras
Driver
I lost my Powershot A470 driver. Can I download one from Fixya? Please help! Thank you!
Aug 17, 2008 | Canon PowerShot A470 Digital Camera
Samsung digimax 3000 driver
I have a dimax 300 camera but once i plug it to the pc the camera screen goes of and can not be detected by the pc. I have try driver dective with usb, nothing has helped. I aslo tried dowloading drivers for the camera. nothing has help. I need your help
Regards
Morris
Jun 15, 2008 | Samsung Digimax 3000 Digital Camera
Software and Driver Needed...
Can you provide your camera make/model to offer you a link to download your drivers. Thank you.
You could use a card reader connected to your computer and this would not require any drivers.
Dec 06, 2007 | Cameras
Webcam help
ok, you need to get the CORRECT drivers. Unistall all the drivers you have installed. Next, go to www.camera-drivers.com/drivers/230/230822.htm
Download the right drivers, you have to go thru a series of ads, just click no thanks on them. After you download, make sure your camera is NOT plugged in. Now install the new driver. Plug the camera in, Windows Hardware Manager should start up. Tell it to search for the drivers in C:\windows\system or system32, can't remember which one. It will say a different camera name, don't worry it's the driver you want. Install and your set.
Sep 10, 2007 | Micro Innovations MCNIC50C Webcam
Sakar 59379 Digital Camera Logo
Top Sakar Cameras Experts
Robert
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Sakar Camera Expert? Answer questions, earn points and help others
