posted by Dilbert123 on Dec 17, 2007
I HAVE AN ID MACHINE THAT KEEPS GETTING THE ERROR MESSAGE HEAD LIFT ERROR. I'VE TRIED TURNING ON AND OFF. TAKING IT APART AND PUTTING IT TOGETHER AGAIN AND NOTHING WORKS. KEEPS SAYING ITS BUSY AND THEN WILL NOT PRINT AN ID CARD. ANY SUGGESTION?
2 Other Users Have The Same Problem
Comment by icsaruba, posted on Apr 25, 2008
I have the same issue and it seems to be the belt that drives the printhead that is worn, this is a very inexpensive part and can be replaced by a tech. Also I have contacted Fargo Tech Support and the problem may also lay in the sensor that is behind the circuit board.
Comment by Guest, posted on Jan 22, 2008
Same Problem : Getting ERROR Head Lift on a DTC500-LE -
ANY HELP WOULD BE APPRECIATED
Clarification Request
by orly2, posted on Apr 06, 2008
can you give a solution about head lift error
Suggest a new solution for this problem
Post a New problem for Fargo DTC550 Thermal Card Printer
Email this problem
Email this problem
Can you Help with these Printers problems?
FARGO PRINT HEADS
FARGO PRINT HEADS
i too am getting a white line.i... Answer This...
Repair Service
Find Printer Repairman Near You:
