My top loading frigidaire washer glws123as acts like there in no power to it. It will not run with a full load in it. CAn you assist? The unit is 6yrs old.
I would replace the cold water inlet valve at the rear of the washer (pull the washer away from the wall), it is easy to do and the part is less than $20.00
The problem is your water inlet valve has failed. It is stuck in an open position. Part # AP3267279 at www.appliancehelponline.com
cost is $37.87 easy to replace. Remove top cover to acess.
i assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
