Question about Mirage OMNI S8 Speaker
Speaker keeps humming all the time - Mirage OMNI S8 Speaker
Have a humming noise in both of the speakers
Something's crossed, keep power lines and sound lines seporated double check wires in and out u could have bad sound wires and if so of home just buy new for a car get the RCA lines with a built in ground.
Aug 07, 2014 | Toymax Magnavox 37MF231D 37 in. LCD TV
Guitar amp continuous humming from speaker
Firstly, do not disconnect the speakers from the amp when it is on. Damage is possible.
You have a bad ground somewhere in the hookup. The first suspect would be your guitar-to-amp cord shielding connections at each plug, then, the wiring in your guitar. Try changing each of these to another as a trial, one at a time.
Here is Marshall's spiel on hum
http://www.marshallamps.com/support/faq/hums-hisses/
Mar 11, 2014 | Audio Players & Recorders
All speakers are humming
I have always went straight to the ground wires when a hum occurs in a speaker or speaker system. Are they in phase? Do you have the ground and lead switched?
Nov 27, 2012 | Onkyo Ht-s5500 7.1-channel Home Theater...
Mixing board hum
AC hum comes from poor grounding of components.
Jun 21, 2017 | Music
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
Mirage s8 subwoofer is emitting a constant hum
that is just the radio from the input,its normal
Jun 19, 2010 | Mirage Prestige S8 Subwoofer Speaker
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Pioneer Receiver SX-750: Getting a loud hum through the speakers
The hum you hear from the speakers and from the unit itself originate with 60hz AC power. They may not actually be related. Sometimes a transformer will hum slightly and unnoticeably. That you're getting a loud speaker hum says there is an electrical leak or a grounding issue somewhere.
Do all sources produce the hum or, say, just the phono? How about on headphones? Try rotating the AC plug. In those days they weren't keyed with one large blade as they are now.
May 17, 2009 | Pioneer Audio Players & Recorders
Constant hum when the computers are connected
Hums come from several sources. A light dimmer switch on the wall. Speakers too close to a monitor or other electrical device. Try turning off everything in the room or nearby rooms, one at a time while the hum is audible.
Apr 15, 2009 | Bose Companion II Computer Speakers
Loud hum on subwoofer.
try another speaker on that channel if you get no sound or it hums then it is time to take your set to a tech your audio out put on that side is damage along with some caps.good luck.
Mar 30, 2007 | Polk Audio RT1000I Speaker
Mirage OMNI S8 Speaker Logo
94 people viewed this question
Top Mirage Audio Players & Recorders Experts
Ben Armstrong
Rob
Rob
Are you a Mirage Audio Player and Recorder Expert? Answer questions, earn points and help others
