Question about Dryers
Kenmore 90 Plus Series Electric Dryer trip
I have a Kenmore 90 Plus Series electric dryer. Model No: 110.68942892. It will only run about ten minutes and the power trips. After it cools it seems to attempt to restart, but usually fails. After I trip the home breaker off and on adn allow time to cool it will restart sometimes with the heating element turned off and other times it will not. I removed the lower front panel and the cover to the heating element. This is a dryer that I obtained with the purchase of the house and know little about. It appears that the drum is off center as the gap on one side is greater than the other and the drum is difficult to turn by hand.
  • 2 more comments
  • RonnieL Dec 18, 2007
    Is there a way to check the motor? Can I measure the amps with a multi-meter? Should I take off the belt and try to run the motor on it's own? Got any other test ideas? What does a motor cost? I don't suppose there are any special tools required to change the motor. Is that correct?
  • peter12 Dec 19, 2007
    My Kenmore 90 Plus Series dryer runs fine sometimes. But often lately it may run for about 10 minutes, after which it shuts off and will only run so long as we maintain pressure on the start button. If we then turn off the power for about 10 minutes then it comes on again. But again, it sometimes only works for a few minutes before shutting off.
    Another problem (which may not be related) is that the dryer will sometimes complete a run, but the clothes will not be dry (or even warm).
    Alternatively, sometimes the dryer runs fine.
    It appears to be very moody. Can you assist?
  • RonnieL Dec 19, 2007
    Thanks for all the info. I suppose I should check the fuses before changing the motor. I will start by switching the relays and checkingthe fuse and voltage. I will try to run the motor without the belt as well.
  • Anonymous Mar 23, 2014
    usually when the display screen is thinking it does not heat up, i belive its the cooling stage.
  • 89 Answers
It sounds like the motor switch which is actually inside the motor on the model. It is very expensive to replace motor so it may not be worth fixing......
Although I stick to the above statement; I have seen cases where a thermal fuse wire has come loose and perhaps sometimes touching(allowing heat) and sometimes not(hitting something blowing the breaker.... Check all wires on blower vent area... GOODLUCK!!!
Posted on Dec 17, 2007
  • Brian Gillespie
    Brian Gillespie Dec 19, 2007
    Peter12; On the under side of the control panel there is a small black relay with four wires going to it.(if not give me model #) You may also notice another one identical to it next to the timer. Switch them! Turn dryer on and see if it will run through a full cycle (note:it may not heat but we are just checking the relay to see if it will run through the whole cycle) If it does, replace both relays...NOTE: If this does not solve problem, you may have a bad motor switch(inside motor).......
    RonnieL; No special tools to change motor, motor cost around $150..... Are you getting 240volts from wall to dryer? Did you check thermal fuse?(fuse should have zero resistance)... I will post link to a picture of whats where in a few minutes(hour or so, news is on)...
Sears Kenmore super capacity plus dryer won't heat up 90 series, about 7 years old. It heats up for the first few minutes and then gets cold
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a kenmore 90 plus series model # 11068972892............... when i push start button the dryer motor will humm and mabey start to run or it will just humm and not run at all..if it...
Check under the machine and see if the motor turns easily by hand. It could be the motor, or it could be the bearing. The switching off after a while implies that the motor is struggling against a heavier than normal force and trips because of overheating. Most likely the bearing/s is/are ceasing up.
Sep 06, 2010 | Kenmore Dryers
I just replaced the motor in my Kenmore Series 90 dryer, When I'm running the dryer with no heat it runs as quite as could be expected for a ten year old dryer, When I run with heat the dryer starts making...
It could be possibly your rear roller bearings expanding with heat causing them to not spin as freely? Im not really too sure but its an idea you dont have many moving parts on the unit. Just your idler pulley, blower wheel, and rollers. Hope this helps.
MJ
Feb 14, 2010 | Kenmore 659 Electric Dryer
My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
Kenmore 90 series electric dryer. Buzzez when you press the start. Sometimes it runs for a couple minutes then shuts off. is this the motor or a start capacitor?
Thermostat controls heat. There is also a motor centrifulgal switch, in the element circuit, that the motor closes to insure the motor is turning. Try another heat setting. There is more than one thermostat. You may have blown the 'thermal fuse' too, which requires replacement.
Tripped high limit. Must clean the lint filter and the exhaust vent tube and all the way in to the dryer. Hot air exit is restricted.
Jul 07, 2009 | Kenmore 659 Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Kenmore 90 Plus Series Model: 68942890
bald one, more than likley your even heat board has failed. I've seen this a lot on this model. It's located under the consol right next to the timer. Easy fix. part number 3402605. Catriver
Jul 14, 2007 | Kenmore 64952 Electric Dryer
Dryers Logo
1,025 people viewed this question
Top Dryers Experts
