Question about Harman Kardon SoundSticks Computer Speakers
Spill Not exactly a high-tech problem ... I spilled coffee yesterday, and probably an ounce or so went into the opening at the top of the sub-woofer.  I quickly turned it upside down to keep liquid away from the electronics and the speaker cone.  I think, I hope, all is well there.  But the problem remaining: is there any way to get the container open, so that I can mop up inside?
    Problem Solver:
  • 25 Answers
U can open it up....
But the speaker/Woofer may got damaged, which had to be replaced....
Contact the local tectnicians..
Posted on Dec 28, 2007
Can i wire non amplified mid-range/tweeter speaker's on the inside of an altec acs250 sub woofer directly to the woofer speaker
Probably not. Somewhere there is a filter (crossover) that only sends the lower frequencies to the sub-woofer driver. Where that filter resides (either in the pre-amp, receiver or sub-woofer enclosure is yet to be known).
Oct 27, 2016 | Audio Players & Recorders
What model sub woofer can replace JVC SP-PW100?
open corel, at top click on about- click on activate and enter code
Sep 09, 2014 | JVC SP-PW100 Subwoofer
I puchased a pioneer vsx-820 receiver yesterday , i have a sub- woofer that only connota via speaker wire ends how can get this to work?
I have the same problem, your sub-woofer is passive and you need a powered sub-Wfr, more money is the only FIX!
Dec 16, 2010 | Pioneer AVIC-D3 Car DVD Player
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Subwoofer continuous buzz/signal noise
I just bought mine yesterday and have the same problem... did you find a solution (other than throwing it out the window)?
Nov 18, 2009 | Bose Acoustimass 15 System
Sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
May 15, 2008 | Audio Players & Recorders
Harman Kardon 595
Hi, probably two things that can go dead, 1) the woofer itself and/or 2) the amplifier. I will rule out poser supply cos the other speakers are working. Normally they have a separate amplifier than that of the woofer. If you are comfortable working with a soldering iron and a multi tester, after unplugging from the mains, then you open the enclosure and check the continuity of woofer which should read between 4-8 ohms, if it is open or no reading, replace just 2 wires/terminals involve with 3 or 4 screws. If the woofer reads a continuity, then it is the amp which normally is just a single power IC attached to an aluminum heatsink. In some instances, it may be a power transistor pair. In any case you have to be familiar with component level repair. Otherwise, you are probably better off asking a qualified service personnel to do the repair job. Hope this be of some help. Pls post how things turn up. Regards.
Apr 26, 2007 | Harman Kardon HK595 Computer Speakers
Harman Kardon SoundSticks Computer Speakers Logo
73 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
