Question about Kenmore Oasis HE 27082 Top Load Washer
Washes fine but will not drain or spin out at the very last. this is a oasis HE and we use he soap.
  • 51 Answers
Your washer will not spin or drain if pump is resricted you can clean pump. now if you clean pump yourself their is 2 pumps under there you want to clean the one on the left from the back of your washer
Posted on Sep 27, 2009
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
We have a Sears Oasis Elite Top Loader washing machine. We are constantly getting a "sd" error during the cycle. The washer drains but does not spin. Upon researching we found how to get the...
This could be easy on your pocket book, the ( sd ) is suds. Are you using a HE soap if not and this has almost been going on since getting the unit, say if you are using 3/4 of a cup you must reduce to 1/4 of a cup. this should solve you sd problem. What happen is the sensors are picking up excessive suds while washing and attempt to drain to reduce them just get HE soap or reduce the normal soap as I have directed.
May 14, 2011 | Washing Machines
First washer would not fill tried later it started got to spin stop will not empty water tried drain and spin button still wont run help thank you happy hoildays joe thomas
Suds detection & long drain error codes indicate a problem with the water draining out or too much soap is being used. If the unit is not draining good then I would suspect a problem with the pump or control board. Please see the images provided for more details. Press stop twice to reset the control.
Dec 17, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Makes a raddling noise when draining
There is stuff caught in the drain pump...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Oasis washer does not spin and leaves an "oL" message
it means over load. that could mean a few things. what you should do is grab on to the tub try to turn it. if it feels like take some force to do there is something stuck around the shaft of the washer. the only way to actually check is to pull the tub. to do that need to remove agitator. under that should have 6 philip screws pop the lid open with a putty knife in front youll see clips holding the lid down. after that the tub can be removed. sometimes it take some force to remove
Nov 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Very loud spin cycle
your bearings i the tub have gone bad. It happens usually if you use powder soap. It doesnt dissolve all the way and gets into the bearings and ruins them. Sorry but this is a pretty expensive fix. When you get it fixed used liquid soap and it shouldnt happen again.
Nov 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 80 series leaving soap behind
check for clogs in the output line (the drain hose)
Jun 15, 2008 | Kenmore 24032\24036 Top Load Washer
Smoke smell coming from my 80 series Washer
do you actually see smoke or is it you have a burning smell
if you have a smell the motor may be overloading on spin
sometimes this is due to too much soap powder in wash
and when machine spins the water cant get away due to soap suds under and around bowl
acts like a brake on motor
try no soap powder in next wash
a good way to tell is that you still have soap in washing if you lift the lid (with no soap powder added)
Dec 02, 2007 | Kenmore 15864/15862 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
132 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
