Question about Toshiba 57HX81 57" Rear Projection Television
I can not find a replacement bulb for a toshiba 57hx81. What is the actual part number? Who sells it?
    Scholar:
  • 83 Answers
For model no 57hx81 CRT bulb part no.s
Blue is   TOSHIBA     23008753
Green is TOSHIBA     23008752
Red is    TOSHIBA     23008751
If that is not the right model no post a comment here with the correct one and I'll give you the part no.
Posted on Dec 07, 2009
Red bulb nt working in model 43s7da
CONVERGENCE PROBLEM, FIND HONEST TV TECH. MAYBE A $300 REPAIR
Nov 11, 2013 | Toshiba 57HX81 57" Rear Projection...
I have A toshiba 57HX81 tv red ligth blicking.i found (2)5 amp pico fuses at F850 & F851 & (1) pico fuse 2AMP at F852 would replacing these fuses bring the tv back to life.
Too many possibilities to predict if the fuse replacements will make the set function again but I suspect your main power supply has failed so if the fuses blow after replacement, you may have to have the supply repaired or replace it.
You might check, using your model number, at the site below to see if they have a power supply 'pull' available from their stock. They part out retired sets of all kinds.
Jimmy's Parts
Nov 27, 2010 | Toshiba 57HX81 57" Rear Projection...
Based on advice here I have purchased 2 STK392-150 chips for a 57HX81 Toshiba...looking for instructions/pictures for the best way to complete the fix...
You can get a repair kit with parts and instructions from www.TvRepairKits.com . They also sell just the instructions and suppurt if you have the parts. Email them for that info
Sep 23, 2010 | Toshiba 57HX81 57" Rear Projection...
The tv doesnot turn on though the powre is on. model 57Hx81
You need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 12, 2010 | Toshiba 57HX81 57" Rear Projection...
Toshiba 57hx81 picture unrecognizable
Common problem on these sets--the board is not available--don't buy a used one--only way to get another is to remove the one in the set and send it to PTS Electronics--they repair and rebuild boards--If I have helped you take a minute and give me a vote here as I do this for free.
SD TECH
Sep 03, 2009 | Toshiba 57HX81 57" Rear Projection...
Toshiba 57HX81: Green works but Blue and Red seem to be out.
Do you still have reds? Is the image still clear though discolored? If so you ought to replace the blue bulb which has most likely failed. The part no for the 57HX81 model blue CRT bulb is TOSHIBA     23008753.
Jun 11, 2009 | Toshiba 57HX81 57" Rear Projection...
Toshiba 57HX81 is all wiggly and distorted (youtube video attached)
I don't know about that. Someone probably was rough with it and messed them up. You should have a technician look at it.
Jun 16, 2008 | Toshiba 57HX81 57" Rear Projection...
Toshiba 57hx81
was ther any damage done to the cabinet miror may be miss alinged or posible bad regulator get back to me
Aug 31, 2007 | Toshiba 57HX81 57" Rear Projection...
Toshiba 57HX81 57" Rear Projection Television Logo
172 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
