Question about Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 scanner makes clicking noise
Recently changed ink and little tab in back fell off, fixed that now my scanner when turned on starts to go across then goes back to start and makes a clicking noise like stuck or going backwards how do I fix this.
  • 556 Answers
SOURCE: Lexmark X3470 All-In-One
See
http://support.lexmark.com/static/229-1-0-539.html
There are windows Vista instructions at the top if required and the
Drivers and Downloads link to the lower right contain the device drivers for various Windows Operating systems. OR this link
http://downloads.lexmark.com/static/229-1-0-539.html
Posted on Dec 10, 2007
otacon
  • 1944 Answers
SOURCE: install lexmark x3470 without disk
You can download here from Lexmark. Just pick your operating system.
Posted on Jan 19, 2008
  • 19 Answers
SOURCE: lexmark x3470 Cover open problem fixed. Now
tightly secure scanner head. uninstall printer; REBOOT
reinstall printer;
Posted on Apr 26, 2009
  • 415 Answers
SOURCE: how do i remove an ink cartridge from lexmark x3470
Power on your printer and lift the cartridge door on the top of your printer. The ink cartridges will move automatically to the center. When they stop, pull the ink cartridge towards you and up to remove it. Then, take the new ink cartridge, remove all the plastic covers and place it in the printer. Then close the cartridge door and you are ready to print again.
Posted on Feb 26, 2010
  • 20 Answers
SOURCE: Lexmark x3470 scanner feature won't work
Have you installed the scanner drivers? These are different than the print driver. You can find all of the drivers @ www.lexmark.com
Posted on Jun 17, 2010
I recently had my ink refilled using my x3470 lexmark but when trying to print it says my ink level is still low. Should I get my money back from walgreens or not.
Hi
How many time your reuse this cartridge, my cartridge life is over, pleas buy the new cartridge from Lexmark service centre..
May 13, 2011 | Lexmark X3470 All-In-One InkJet Printer
How can I scan without problems on a lexmark x3470 all in one
Hi..
To scan a document using the Lexmark Imaging Studio on ur Lexmark X3470, follow the steps given below:
1. Go to "Start," "All Programs," Lexmark X3400 series, "Lexmark Imaging Studio."
2. Click on "Scan," "Save edit or share."
3. Under "What are you scanning" choose the option as "photo," "several photo" or "documents."
4. Select the location to save as my pictures or other folder on your computer.
5. Click on "start" to scan.
To make a standalone copy:
1. Load the paper.
2. Select the "Copy quality" you want.
3. Open the top cover of the All-In-One.
4. Place the item you want to copy face down on the scanner glass. Make sure the upper left corner of the front of the item aligns with the arrow on the right of the All-In-One.
5. Close the top cover.
6. Change copy settings as needed.
Press "Black Copy" or "Color Copy."
hope this was helpful...
Apr 24, 2009 | Lexmark X3470 All-In-One InkJet Printer
Cover open is on display
put your finger on the second hole on the top from the right and press the switch (it's small, gotta try a little...), when the display changes, press copy and close the door... it just worked for me!!
good luck
Apr 02, 2009 | Lexmark X3470 All-In-One InkJet Printer
When I changed the ink cartridge on the Lexmark X3470 I got a Cover Open message even though the cover was checked repeatedly. It is closed. The power button would not go off and the machine would not...
never let a machine defeat you
tape down the little plastic black lever inside so it can not POP UP to trigger the error message. who needs a machine to say lid is up anyway?
Mar 23, 2009 | Lexmark X3470 All-In-One InkJet Printer
Scanner won't work. Says I need to install OCR from CD.
never let a machine defeat you.
uninstall. REBOOT; reinstall; invoke the scan tools menu
select SETUP click FACTORY settings to invoke mfr defaults.
go to scan and OCR tabs and make sure you have checked all radio buttons and boxes so make all preferences.
click APPLY, OK and REBOOT. happy printing.
Mar 13, 2009 | Lexmark X3470 All-In-One InkJet Printer
X3470
my printer keeps saying cover opened and won't swcith off or nothing can u please help me
Jul 03, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X3470 Printer Plastic clip (white)fell off
i pushed the little black trigger in and at the same time put a couple drops of crazy glue on it. works like new!!!!!
Mar 14, 2008 | Lexmark X3470 All-In-One InkJet Printer
Cover tab broken on Lexmark X3470
Have you recovered the tab? All the tab does is interrupt a sensor beam between 2 points. Either glue it back on (epoxy or super glue, use sparingly on one side then apply and hold down until it sets, about a min. or tape a popsicle stick into the area where the tab rested. First feel around with the stick in the area until the printer responds. then fix it there.
Jan 06, 2008 | Lexmark MFP-X3470 All-In-One InkJet...
COVER OPEN
There is a plastic lever in the back of the scanner where it comes into contact with a part made to push the lever when closed to work the switch. It is a poor design. The lever fits over the small micro-switch very loosly and the tabs wear out really quick. Lexmark will not send another lever. They state buy another printer. If you are real careful, you can put the lever back on the switch and hold it in place while you close the lid.
Oct 27, 2007 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
176 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
