Question about GE Microwave Ovens
Some of the buttons on my microwave won't work
  • GE Master
  • 9,047 Answers
You have a failing membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
So please reply back directly to me with your brand and full model number from the for free do-it-yourself tips and an estimate if required.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 27, 2009
Does this unit itself have fuses inside it? If so, how do I access them.
Shelia, A lot of microwaves do have internal fuses, Links below will show how to change them.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix Microwave Oven Simple Fuse Replacement
Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
Microwave Line Fuse Replacement Whirlpool Microwave Repair Part W10422951
Mar 21, 2016 | Microwave Ovens
Door stuck shut. Pushbutton does not work. How can I get the door open for repair?
Jo. you may have to remove the hole cover, to access inner latch mechanism, where you can manipulate the latch with long screw driver.*** before attempting this, unplug microwave for an hour***
press the helpful button. link below may help...
Microwave Door Won Open
Jan 25, 2016 | Microwave Ovens
I pushed the veg able button on my general electric microwave je1860wh04 got an error and now it won't heat
To be on the safe side, contact the manufacturer. Some GE microwaves were having problems that could cause them to start later on their own and were a house fire hazard. Please unplug the microwave now.
Feb 15, 2013 | Microwave Ovens
Microwave won't start when pressing the start botton
call Chas&son,s appliance repair at 579-379-0993 and they will come out the same day no less okay
Feb 13, 2013 | GE JE2160 Microwave Oven
Can't turn on light
That can usually be economically repaired. Details are here.
Jan 09, 2013 | Maytag 2.0 Cu. Ft. Over-the-Range...
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Door open button won't work on KitchenAid microwave model YKCMS135H
Page 3 of the exploded view here shows the door open parts 24510L and 250201 (or 23551B if your full model number is YKCMS135HSS).
What look like part numbers seem to be reference numbers.
For further help you will need to contact Kitchenaid Canada here.
Sep 05, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
MY MICROWAVE IS NOT HEATING
If the microwave is turned on and you can hear the fan working when you set the time you should make sure of those things:1. You have selected the proper programme. Some microwaves have a control desiged to use the programs on the buttons. if you want to you the buttons to set time you should select "microwave" or a similar button and then press the power level like "1", "2" or "80", "100" (being percentage) and then press the buttons for timing.2. If you have used it for a while and it suddenly stopped heating the food, than it could be that your magnetron (a spare part) has burned out. Have a specialist replace it, or just get a new microwave, the price difference won't be that great for standard issue microwaves.
Feb 25, 2012 | Whirlpool Microwave Ovens
Touch button won't work
If all buttons don't work then check that connection isn't broke through the I/O board.
If not then board is faulty.
Is you display is lightining or not.
if not then the connction is bad
thanks
please rate my work
Sep 10, 2011 | KitchenAid KHMS155L Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
