Question about Husqvarna Garden
Lt130 ride on mower when depressing clutch motor starts release clutch motor stops.
  • 472 Answers
Sounds like one of saftey swiches is bad i would start with the seat swich thats what see the most of the time
Posted on Oct 15, 2009
2010 Troy built 42 inch riding mower with auto transmission : mower has to have brake pedal depressed to start. It starts fine - let of the brake pedal and the motor stalls out . What is wrong ???
Most of these machines have similar saftey systems.
If you apply the parking brake the engine should continue to run.
If the brake is released and the operator is not in the drivers seat then the motor will stop.
If the operator is in the seat and the seat presence switch is working properly the motor will continue to run as the brake is released.
If the weight of the operator is low (skinny little kid) then the seat presence switch will not activate the motor will stop.
If the switch is defective no matter how heafty the operator is the motor will stop.
There are other components in the electrical system that the switch connects to that could also be the problem
Start with the switch
Hope this helps?
Apr 11, 2016 | Troy Garden
How to set and release the brake
You would depress the clutch/brake pedal all the way down and then pull or activate the brake engage lever or linkage. To release it normally all you have to do is fully depress the clutch/brake pedal and the linkage or lever will automatically disengage.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_73617967471ec7c4
Jan 20, 2016 | Garden
Lt130 aws is hard to steer
Yes they get that way after a few years. To get it to steer better again you need to take the spindles out of the axles and clean and grease them.
Oct 12, 2013 | Snapper Riding Mower Briggs 23 HP ELS ES...
My lawn mower will start easily and continue running as long as the clutch brake is depressed but when I lift the clutch or try to engage the blades while the clutch is depressed the mower will stall.
This is a shot in the dark. I think you have a failed "operator presence safety switch". Rule this out by finding the switch and jumping it.
Your mower should run with no one in the seat IF THE PARKING BRAKE IS SET.
If the brake is released and no one is on it, it should shut off.
If you are on it and the brake is released you should be able to engage the blades (probably an electric clutch)
Purpose of this interlock is the shut the machine OFF should you fall off or jump off the machine. Do not disable this valuable safety feature.
Let me know what you find.
Thanks for your question @ FixYa.com
May 15, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Troy Bilt ride-on mower will not move in either fwd or reverse
Is the parking brake on? Or if it's a hydrostatic (automatic) there is a release lever to push the unit around when it isn't running. Most of those releases are on the back of the machine, and you just push it in for drive and pull it out to push.
Was this helpful?
yes
no
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Riding mower goes slow in forward speed
There is a variable speed pulley that is a double pulley....one belt from engine to pulley and one from pulley to transaxle....remove both belts...pushing in the clutch will help with removal....remove o ring on top of pulley and pull up......the middle piece of metal is stuck....this piece is meant to slide up and down.....put the middle piece of metal on your pulley in your vice...wd40 the hell out of the shaft on pulley .....grasp the top with one hand and the bottom with your other hand...work the stuck pulley free.....put lithium grease on shaft...reinstall....done
Mar 09, 2009 | Mtd Garden
Garden Logo
95 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
