Question about Maytag Refrigerators
Freezer control knob broke due to being to stiff to rotate. And this happened about the same time the freezer compartment temp began to fall. The freezer is freezing ok now however. Model # RTT2100DAE, Serial # 10352839MD. Please advise
Cerfer39
  • 709 Answers
SOURCE: GE Frigerator has intermittant Freezing
It sounds like the defrost heater is burned out. Remove the inside back cover in the freezer to see if the coils are frozen up. If so, more than likely your defrost heater has bit the dust. It is located at the bottom of the inside coil of the freezer.
Also, you could be have a clogged condensor coil. It is located on the out side back of the Fridge. You need to remove the panel from the lower part of the fridge and do a thorugh cleaning.
Posted on Nov 03, 2007
SOURCE: Freezer quits working
Solution Found! The problem is when the temperature surrounding the refrigerator in the garage falls to < 45 degrees, the thermostat regulating the refrigerator will not call for the compressor to kick in to provide cooling (it's temperature requirements are being met). Since there is no demand, the compressor will not cycle, which is how the freezer is kept cold, and the freezer eventually warms up to match the refrigerator temperature. Frigidaire makes a "Cold Kit" that I ordered and installed from RepairClinic.com for $22 (Item #: 1037646; Description: Garage kit). It's basically a strip heater that runs off the control power to warm the thermostat and causes the compressor to cycle once to twice a day to keep the freezer frozen. After installation, the refrigerator stays at 40-45 and the freezer stays around 0 degrees.
Posted on Mar 19, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Freezer temp increased slowly;ice cream/ice will not freeze
If the repairman is experienced the problem will be resolved. I have recharged refrigerators myself and it is difficult, time consuming ad tedious. Sorry the work needs to be done in your home. If he does not know what he is doing he will cause problems and make excuses for why the refrigerator does not work correctly. Hope you have the best service available for your area. Sea Breeze
Posted on Mar 27, 2009
sawdust46694
  • 398 Answers
SOURCE: freezer is not freezing,fresh food is not cold
you have a bad defrost timer or a heatting element.mif there is ice on the rear wall you will have to empty it and remove all shelves, pull the cover and you will see the heating element. it will be in a glass tube. you can see if its burned into, look for blackness inside the glass tube. when you install the new one be sure to put it so water wont run inside the tube, or it will burn out right away. good luck you can do this sawdust46
Posted on Jul 25, 2009
mrfixit3667
  • 262 Answers
SOURCE: will freezer work in low ambient temperature (i.e.
The compressors are rated for ambient temp. and most refrigerator compressors are rated for abour 50 degrees F
to answere your question yes the ambient temp is a problem.
And as for the Thawing, the refrigerator will go into defrost every 8 to 10 hrs and turn on the heater inside the freezer for about 30 min.
You can also cause damage to the seal system and the compressor because the oil will become slugish inside the compressor.
In other resarch I found that because of the ambient temp the freon gas (mostly the newer freon's) won't work corectly because they stay in liqued form.
Posted on Jan 11, 2010
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
The freezer part keeps freezing up but the refrigator side is too warm
Several things to look at. first make sure you defrost the freezer fully, (you can use a
hair dryer to defrost the coils behind the back panel of the freezer).
Then I would
replace the "defrost termination thermostat" It is clipped onto a tube and has two wires
going to it, this is an inexpensive part that often causes this failure. Model and serial
number is inside the big door usually on the left side.
Also make sure the fan operates in the freezer compartment, as well as setting the
knob in the freezer to the center and not "COLDER"-- this knob blocks off air flow to the lower compartment if set to "COLDER" and can cause freeze up.
Rotate defrost timer until you hear a click and listen for water dripping in
freezer or a hissing as the element heats up. Defrost timer is accessed by a hole under the temperature control panel that has no screw in it in the lower compartment. Rotate the timer manually with a flat screwdriver until it clicks. They sometimes stick.
Hope this solves the problem.
Jul 03, 2011 | GE Refrigerators
Admiral Model AT17M6W - Temp Control Knob Stuck - Now I Broke It?
you will have to take the inside panel off the door to get to the back of the switch..Inspect it closely for sharp edges as all should be smooth on the swtiching mechignism.. if its broken remove the out part of the switch and see if you can turn the temp switch inter control shaft either way...if it keeps spinning then you'll have to replace the entire swtich(ording parts) if it doesnt spinn freely then plut the inner pannel back on but with the swtich house off so the dial rod sticks out...Kind of **** but it would work!!! hope this was helpfull:)
May 19, 2009 | Maytag MZD2766GES Side by Side...
Heater Fan does not work
Sounds like the fan control knob has shorted out. You can check the fan "blower" relay and fuse in the engine compartment but you need to make sure the control knob is good or you will keep blowing fuses and relays. If your blower fuse and relay are good, then just have the control knob checked and replaced if needed.
May 08, 2009 | 1999 Volkswagen Passat
Whole room stunk . Refer had Ice on the back panel on the Freezer
the fact that ice was built up on back of freeezer tells me that the refrigerant system is probably ok. most likely from your description you have a defrost system problem. whne ice builds up very heavily it starts to act like insulation (think igloo) so it will allow frozen foods to thaw and fresh foods to spoil. here is how to check. in refrig compartment I need you to remove the control panel/light lens in rear, these are held in place by the control knobs and then you pull out on the cover to release. once this is removed I need you to look for the defrost timer there will be a hole to the right of the temp controls it has a grey or black looking knob in it that you can turn with a flat tip scre driver. turn this knob until the unit clicks off. now you will have to wait a few minutes but listen in the freezer compartment for a sound that sounds like water falling into a hot frying pan, you may also notice a glowing red light at teh bottom of the cover in the back of the freezer.
if the heaters don't come on then the timer is ok. teh next step is remove the rear freezer cover and defrost the ice out of the coils. you can use a hair dryer, or a wet dry vac set to the blow position. once the ice is gone inspect the heaters for burnt or broken condition. (ge uses glass rod heaters and heater breakage is very common) I suspect the heaters are the problem anyway.
be aware that you are going to get lots of water the drain pan will not contain all of the defrost form this bad a freeze up. good luck peyton
Jan 29, 2009 | Maytag MTF2156GEQ Top Freezer Refrigerator
Refrigerator stops cooling, but if I adjust the temp it restarts
temp control wire dodgy turn off take plug out of socket trace wire repair it switch back on i had one temp mate it was wire
Dec 17, 2008 | Frigidaire FRS23KF7AB Side by Side...
Hotpoint FFA70P Bottom freezer not working
HI The thermostat control is usually mounted inside the refrigerator. Its visible control knob is turned to regulate the refrigerator/freezer temperature. The workability of this control can be tested in various ways, depending on the problem. To test the thermostat control:
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Oct 07, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
I was trying to defrost this college sized refrigerator. I was using a screwdriver to try to break loose the ice build-up around the top freezer section when all of a sudden a heard a noise and steam...
Sure do you broke open the Sealed system this is where the freon (gas that cools the unit ) is you released gone forever...
Now you will need to have some one out to fix the hole vaccum down the system and recharge it but most likely just buy a new unit due to the cost involved in the repair. Live and learn never to use sharp objects in a freezer...next time use a hair dryer to unthaw
Jul 30, 2008 | Refrigerators
Dec 02, 2007 | Bosch Exxcel KGV35421 Bottom Freezer...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
