Question about LG DLE0332 Gas Dryer
My LG dryer does not spin...everything gets hot and works except either it spins VERy slowly or not at all
  • dreadog78 Sep 27, 2009
    I checked the belt and it appears to have a bad spot on it...I am wondering if that would mess up the spinning of the drum?
    Brigadier General:
  • 4,088 Answers
Open the back to get to the motor and check to see if the belt is loose on the motor pulley. Try to turn the empty drum by hand--does it seem bound up? Turn the motor pulley, does it seem hard to turn? Maybe the motor pulley is loose on the motor shaft. Run the dryer for a short time to watch the action of the drive belt.
Posted on Sep 27, 2009
  • drallim Sep 27, 2009
    It would depend on what you call a 'bad spot'. If the spot appears burned like the drum wasn't turning, but the motor was spinning in that one area, it could very well have scorched that location. However, that points to the drum being very hard to rotate especially when the drum is full of wet clothes, or the belt was not TIGHT. To replace the belt (which should be replaced as it will 'thump' every time the bad spot hits the motor pulley), the cabinet front and top must be removed to access the drum. Check the bearing at the back of the drum center and whatever supports the front of the drum--either rollers or plastic plates that the drum slides on. Belts require some sort of tension device that tightens the belt around the drum and motor pulley. There should be an idler pulley on a pivoting arm with a spring that tightens the belt. (look for a loose spring lying in the bottom) The belt will follow around the idler and motor pulleys in a sort of 'S' shape.
My lg t655th will spin only slowly at the moment how do I get to look and see if there is anything stuck I have taken filters , everything else worksit is top loader d
go to the bottom of the machine nd check if u have a swoolen or crack on ur capacitor or ur floor level is in ballance
Jan 27, 2015 | LG Washing Machines
Dryer will not start but timer ticking
If the start button is an "ON - OFF" button (meaning, you can turn the dryer off manually instead of resetting timer in order to switch it off), try turning the dryer ON...then switch it back to "OFF".
Hopefully the dryer will continue, and the thermostat will kick in.
Dec 01, 2013 | Dryers
Dryer Starts Spin but No Hot Air DLG5932W
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 31, 2010 | LG DLG5932S Gas Dryer
Power on but it won't spin.
You have a broken drive belt. To access the belt you have to remove the back metal cover.
The no heat problem could be a heating element or safety thermostat. These are also located under the back metal cover.
Jun 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Gas Dryer Heats up very little, but not enough to dry my clothes
you need to check that for vent hose is not kinked if it is not then remove it from the dryer and see if it work right if it does then the vent tube that goes thourgh the wall has a blockage
Feb 24, 2009 | Whirlpool LGR3624JQ Gas Dryer
Hello zurdo4ever
Welcome to Fixya
My name is Huum,
You said, power on , but it won't spin. hear a clicking noise in the motherboard.
Everything seems to work. except it won't spin.
The dryer was only spinning but not heating lately. need assistance
The clicking is a bad relay sound.
This is an electrical problem and it may be a need for a new cpb (Control panel Board) also.
time to get a tech in there to diagnose which problem you have and get you doing laundry again
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer Gets Hot..But doesnt Spin
I don't know what kind of dryer you have, top or front loading, but it top loading it most likely is the belt that goes from the motor & wraps around the drum.
joel
Dec 21, 2007 | Malber TD700 Electric Dryer
LG DLE0332 Gas Dryer Logo
211 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
