Question about Stokke Sleepi Bassinet Crib
How do i adjust the base to different levels... the website says that it adjusts 4 levels
    Problem Solver:
  • 15 Answers
You can download a user guide from here:
http://www.stokkeusa.com/sleepisafety.htm
Posted on Sep 27, 2009
Adjust the water level in the bowl of a duravit toilet
You can't. Water level is set by the design of the trap built into the ceramic base. Can only adjust height of water in the tank.
Jan 07, 2015 | Duravit 0910100005 Happy D Toilet Cistern ...
How can I adjust an upright freezer door ?
Hello there,
It is always the feet and their adjustment and floor must be level
From the user guide it says
;The freezer must have all bottom corners resting firmly on
a solid floor. The floor must be strong enough to support
a fully loaded freezer.
NOTE:It is VERY MPORTANT for your freezer to be level in order to function properly. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems.
To level Upright Models:
After discarding crating screws and wood base, use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, half a bubble higher, so that the door closes easily when left halfway open. ;
User guide here
http://crosley.com/assets/product/1707/useCareGuide.pdf
Sep 24, 2014 | Crosley CFUM21LW 20.6 cu. ft. Upright...
How do I level my GE adora side by side refrigerator
Hi
With the doors fully opened, lift up the base grill. Tilt the top of the base grill away from the refrigerator. Set the base grill aside. Attach the 1/2-inch socket to the ratchet. Inspect the arrangement of the bolts located in the area where you removed the base grill. The bolts located to the inside of the door hinges are the leveling bolts. The top bolts adjust the back of the refrigerator, and the bottom bolts adjust the refrigerator's front edge. Adjust the leveling bolts as necessary with the 1/2-inch socket attached to the ratchet. Turn the bolts clockwise to raise the corner or counter-clockwise to lower the corner. If you notice the head of the leveling bolt pushing away from the face of the refrigerator as you loosen the bolt, re-tighten the bolt until the head pulls back flush. Switch to the other corresponding bolt to adjust the level of that side of the refrigerator.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 07, 2011 | GE Adora (DSF25KGTBG) Side by Side...
Pumb only pumps a small amount out of the basin. Float needs adjusting to go all the way down and empty the basin. How do you adjust the float/bulb to travel farther down without shutting off after only a...
Flotec website shows several submersible sump pumps, and pump types:
http://www.flotecpump.com/asp/productapplication.asp?AId=28
Click product, then click on 'parts and literature' to access manual
Here is a Flotec manual:
http://www.flotecpump.com/pdf/FP525%2811-1-06%29.PDF
Manual for this type of sump pump says:
Quote from manual: Automatic float switch is sealed and factory adjusted for
most home sumps. Turn-on water level is 10" - 12" above
pump base. Turn-off water level is 4" - 6".
The manual also says that running the pump when dry will ruin the seals.
This implies that the water level setting is set so the seals will not be damaged
You might be able to dig the sump deeper, but I don't know if that meets your objective.
Oct 24, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
What frequency do i need to have my speakers on??
Different speakers perform better under different frequencies.
The sound you receive also depends on the box you use, and the type of car its in. In my opinion the best sound is what "I like" not what others set.
There is two ways of finding your optimum settings.
But my favorite way is to do the following.
1) Set every frequency on radio, preamp, cross over to amp and 0.
2) Turn the volume to about 50% - 75% using a song with different types of base.
3)Adjust your base gain, sonic, boost, punch or what ever settings until it sounds it's deepest. Don't over do the gain or base boost.
4)Adjust the other setting to fine tune clear sound.
5)Add the highs to see if they match up.
6)Now fine tune the amps but remember you should only need to bring the gain up or down because you had already found your deepest base. This should be the last amp adjustment unless u realize u want it lower or higher.
7)Adjusting the equalizer or EQ on the sterio will depend on the song your playing.
Note: It's best to max out at about 80%-90% sterio volume.
"I max out at 60%, but that's because I don't like twisting and twisting to get my sound up or down." One twist and im setting off car alarms.
Mar 16, 2010 | Car Audio & Video
How do I adjust tank fill valve to increase water level in toilet?
There are many different fill valves out there so it would be a little hard to tell you how to adjust your particular one without knowing the brand and type of the fill valve.
So I will give you a generic adjustment.
Look for someway/something to adjust your float in the toilet tank.
There should be a screw, moveable metal, something that will adjust your float.
Once you locate the adjustment, you can then adjust your water level in the toilet tank.
Adjust the water level in the toilet tank to be about a 1/4-1/2 inch before it flows out of the overflow tube when the water shuts off.
Good Luck, I hope this helped.
Please rate me, Thanks
Mar 11, 2010 | Home
Hower do you do the adjusting for height on the
The dial only sets the height or the total deck, it is more of a stop than an adjuster.
If it seems too low in the front, you can adjust it by tightening the nuts on the 2 bolts/pins that are attached to the deck and the frame.
First of all, though, check your tire pressures, 10 psi in the rear and 14 psi in the front. If front pressures are too low, this will make a huge difference in your cut. You want to adjust the bolts an equal amount to maintain your side to side level keeping in mind that it should have 1/4 to 1/2 " difference front to rear.
Make your adjustments on your driveway or garage floor so you have a flat level surface to go by.
If you make these adjustments and it still scalps, you will either have to set the deck to cut a bit higher or approach the high spots from a different angle or remember to lift the deck up a bit with the handle when you get to those areas
Hope this solves your problem
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Height adjustment on my lawn mower
have the mower on a flat suface and adjust for the height you need on all four wheels then raise the rear of the mower by one hole to give clearance and reduce the loading on the blade
Sep 12, 2009 | Garden
How to adjust a David White transit level
I just assisted a friend "re-calibrate" his D.W. L6-20 Level Transit. Follow the following steps.
1. Set up the tripod & transit in the garage. Get the platform with the protractor, close to level.
2. Position the telescope at "0". The telescope should be over 2 of the adjusting screws.
3. Adjust the screws to get the top bubble close to level. Adjust with a screwdriver the spring loaded screw to get the bubble closer to center.
4. Rotate the scope 180 degrees. Note the difference in the bubble position. Split the difference from the first bubble location by adjusting the same top screw.
5. Rotate back to 0. Adjust the same top screw to split the difference in bubble position.
6. Rotate back to 180 degrees. The bubble should be off by the same amount. Adjust the 2 bottom screw to place the level in the center.
7. Rotate back to 0. The bubble should not move.
8. Rotate to 90 degrees and adjust the 2 bottom screws to place the bubble in the center.
9. Rotate to 270 degrees. The bubble should be centered.
10. From this point on, all you need to do is place the level on the tripod and position it over your reference point with a plumb bob. Adjust the bottom 2 screws at 0 and again at 90. The level is set to use.
Sep 05, 2009 | David White 44 8834 1 22x Level Transit...
The delta universal miter saw stand will not adjust to level posi
Hi, The legs on the stand should have leveling pads on it. at the bottom of each stand legs, there is a hole which the pad goes in. you can adjust the pad by unloosening the top nut. put a level on the saw base and adjust the pad up or down to level your stand.
If this doesn’t work for you, please write back. Thanks,
Nov 27, 2008 | Saws
Stokke Sleepi Bassinet Crib Logo
146 people viewed this question
Top Stokke Baby Gear Experts
ray gallant
Dorel UK
Dorel UK
Tom Chichester
Are you a Stokke Baby Gear Expert? Answer questions, earn points and help others
