Question about Sony DAVC450 Dream System
My power combined pwb 1-720-197-13 are burner and needs repair or a new one
Erro code e7-62
Cause is a Combination trouble between the controller PWB and the engine
Check and remedy Replace the controller PWB. Check the combination between the controller PWB and the engine.
Nov 26, 2013 | Sharp MX-2300N Color Copier
Tip
DISSEMBLING AND POWER SUPPLY CIRCUIT
1. REMOVING OF REAR CABINET
1. Remove the 11 screws [1], 3 screws [2] and detach the Rear Cabinet.
2. REMOVING OF CONNECTORS, SPEAKERS, STAND COVER ASSEMBLY AND STAND ASSEMBLY
1. Remove all the connectors from all the PWBs.
2. Remove 2 screws [1] and detach the Speaker-L and Speaker-R.
3. Remove the 2 screws [2], 4 screws [3] and detach the Stand Cover assembly.
4. Remove the 4 screws [4] and detach the Stand assembly
3. REMOVING OF PWB UNITS
1. Remove the 1 screw [1] and detach the R/C, LED PWB Unit.
2. Remove the 6 screws [2] and detach the MAIN PWB Unit.
3. Remove the 4 screws [3] and detach the POWER PWB Unit.
4. Remove the 4 screws [4] and detach the INVERTER PWB Unit.
5. Remove the 1 screw [5] and detach the KEY PWB Unit..............CHECK THE LINK FOR MORE INFORMATION
Electronics Equipment Repair Center
on Feb 14, 2015 | Sanyo Televison & Video
C6400
C6400 Zero-crossing signal problem
• The engine PWB does not detect the
zero-crossing signal for the time
specified below.
At power-on: 3 s
Others: 5 s
Causes: Poor contact in the connector terminals.
Remarks: Check the connection of connectors YC7
on the engine PWB and YC2 on the power
supply PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
Causes: Defective power supply PWB.
Remarks: Check if the zero-crossing signal is output
from YC2-11 on the power supply PWB. If
not, replace the power supply PWB.
Causes: Defective engine PWB.
Remarks: Replace the engine PWB if C6400 is detected
while YC2-11 on the power supply
PWB outputs the zero-crossing signal.
Feb 04, 2011 | Kyocera Copystar CS-1820 Black and White...
C6400 error problem of kyocera printer
C6400
Contents: Zero-crossing signal problem
• The engine PWB does not detect the zero-crossing signal for the time
specified below.
At power-on: 3 s
Others: 5 s
Check procedures/corrective measures: Check the connection of connectors YC7
necessary.
Check procedures/corrective measures: Check if the zero-crossing signal is output
Check procedures/corrective measures: Replace the engine PWB if C6400 is detected
Dec 17, 2010 | Kyocera FS-1118MFP Laser Printer
My kyocera km1820 displays error code c6400
specified below.
At power-on: 3 s
Others: 5 s
Causes:
- Poor contact in the connector terminals.
- Defective power supply PWB.
- Defective engine PWB.
- Check the connection of connectors YC7
necessary.
- Check if the zero-crossing signal is output
- Replace the engine PWB if C6400 is detected
Sep 24, 2010 | Kyocera Copystar CS-1820 Black and White...
Lamp Indicator is Red
Its much more likely that your getting a 34 error which is a lamp abnormality vaused by defective capacitors on the power board. You can get the V26 DLP power PWB repair kit at the following link that should repair the issue. Chances are your old lamp is still good.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
May 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Had a solid amber light indicating a new lamp was needed.
Press the menu amd device/input buttons both in together on the front of the set and hold them both in for 6 seconds to see if the timer light will blink a two digit blink code such as 3 blinks, slight pause then 4 blinks. If it blinks that code you will need the V26 Power pwb repair kit which is available at the following link under repair kits and has step by step instructions.
Apr 22, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Red light stays on after lamp replacement and reset
if the lamp light still remains solid red its most likely needing the capacitors on the power pwb replaced very common problem with the V26 Chassis DLP. You can get the V26 power pwb repair kit at the following link which contains the replacement capacitors and step by step instructions on how to do the repair.
Feb 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 52525 dlp capacitor problem red light after lamp chang
No the board youre refering to is the Power PWB which is encased inside the metal chassis block. You can get the kit that is for your model that has the capacitors and step by tep instructions on how to disassemble the chassis to accesss the Power Pwb. Heres the link to the kit you need if the lamp led is red.
Jan 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
126 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
