Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Washer wont go through spin cycle
How can i make the washer go through the spin cycle
washer displays problen 0E
  • rroering Dec 19, 2007
    we called a real live plumber.
    we were not given a manual to assist in solving our problem as promised by the clerk at home depot.
    please send us a manual asap.
    thank you
  • Anonymous Feb 22, 2008
    thanks to this site I just solved my problem! My washer would not spin.
    I opened the little door in the front of my washer and drained the water, took the filter out and discovered an old quarter and debris. I removed them both and my washer began to spin perfectly.
    Problem Solver:
  • 6 Answers
Bent pinched or clooged drain hose. Other cause may be the drain filter in the front of the machine. (The small door on the lower left of the machine) With a pan, remove the cap and drain water from the small tube. Then open the larger cap and clean out the lint. This should solve the problem.
Posted on Dec 30, 2007
Error code 0E on LG WM1290 FHB ?
The error code 0E stands for obstruction error, meaning that the drain line is obstructed. This is why the spin fails as all the water is not being drained. Check the drain hose for kinks and clean the drain filter. If they are not the problem, there could still be an obstruction in the drain hose in or about the drain pump.
Dec 28, 2014 | LG Washing Machines
Code 0E not draining the water
Hello Faye, thank you for allowing me to assist you!
I understand that the washer will not drain; however is it making a humming noise? If so, either the drain or pump is clogged and needs cleaning. Let's try setting the washer to spin cycle on. Will water pump out? If it does not, then the unit could possibly be experiencing a communication error with the control board, faulty pump, timer or door lock assembly. If I was in your position, I would personally contact a professional for an accurate diagnosis and to assist with the repairs. You can often locate a qualified provider by visiting the manufacturer website.
Oct 14, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
LG error code is 0E...what would be the problem
Washing machine has an LE error code --> Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
wmoverloaded.jpg NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
May 18, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The wash time continues to increase on every cycle. I have a Maytag Neptune TL Washer.
Thank you my machine model number. The reason I ask is so many folks post non FAV6800A/FAV9800A issues in this forum. This forum doesn’t ask for machine model number and serial number. Here we go.
Does your machine seem to take longer than normal to fill with water?
Does the machine increase the time during the Spin Cycle of the Wash Cycle?
Are there any error codes to the LED display such as dC or uC?
Do you want to work toward a DIY fix? If not maybe we can get a solid feel for the issue that will help you in the decision process to bring in a repair company or replace.
So I can better understand the issue can you start a Quick Wash cycle with Soil and Spin settings set to lowest setting and if you could place a couple of bath towels in the wash basket for a load.
I want to see if the machine will go thru the Wash, Rinse and Spin cycle within the 27 to 29 min time of a Quick Wash cycle. I want to see if the machine is increasing Washer Cycle time in the Spin Cycle of the Wash Cycle.
You should enter the Rinse Cycle at the 20 min mark on the LED display.
You should enter the Spin Cycle at the 10 min mark on the LED display.
Watch the cycle and see if you have similar times as I do. Let me know if the washer has any off balance issues as it enters into the Spin Cycle…..Rich
Jan 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The machine will start a cycle normally, but after the timer reaches a certain point it stops counting down and the machine will continue to agitate until you force it to stop.
Thank you for verifying the model type so many folks post non FAV6800A/FAV9800A questions in this forum machine specific topic area.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
You will need the Service Manual for support. I’m an owner like you with a solid repair skills on the machine and will try to help you DIY the repair if we can ID the issue through troubleshooting.
Do you have this condition in all wash cycles? Will a Quick Wash cycle complete? Do you see the Cycle Status LED ever indicate the machine has moved to the Spin Cycle during the wash cycle? This could be a Control Board failure but we need to troubleshoot.
I want to make sure the Wash basket will spin up with a Spin Only cycle selection. Can you select a Spin Only cycle with a empty wash basket. I would release the washer top so you can observe this test. I want to rule out a broken Clutch large wrap spring.
Page 33 of the Service Manual will show you how to release the washer top from the base. In Spin Only cycle raise the top just enough to make sure the wash basket is rotating Counter Clock Wise – CCW with the Spin Only cycle selected and operated.
If the above test doesn’t indicate an issue I would like you to try the Quick Service Cycle test on page 15 of the Service Manual and see if your FAV6800A will pass that test with no clothes in the washer. When you put the machine in Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys until the machine beeps and the LED display reads 00. Then press Wash/Rinse Temp to start Quick Service Cycle test. Did the test complete with a PA indication in the display? It will only display the PA code for a few seconds. End of cycle will beep washer will unlock and Cycle Status LED will indicate complete.
Waiting for your reply….Rich
Dec 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
In spin cycle, water sometimes does not drain at all; other times the clothes are wet, other times the spin cycle works fine. Problen can be rectified by placing the washer into spin cycle a few times.
when on spin check to see if you can hear a low whirring noise {the pump} if the machine is not pumping or not pumping fast enough for sufficient water to drain out of the machine then the machine will not spin due to having to much water in. i would also check to see if all filters on the waste water output are clear of any foreign bodies as this will reduce the speed of which the water is pumped out of the machine{some machines have 2 filters } good luck
Jul 23, 2009 | Washing Machines
Maytag-Neptune stopped part way though cycle. Error code 0E shows on LCD panel. Powering down does not reset. I can't enter service mode as described in the washer manual the 0E code remains.
In general this error code is the main control.
Resetting by pulling out the plug may help, but I wouldn't count on it.
This would require a new main control board.
May 14, 2009 | Washing Machines
Washer only works on spin cycle
Sounds like u need a new control panel
Mar 18, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
209 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
